Results 11 to 20 of 21
September 4th, 2007 10:31 AM #11
center link=drag link. When you flip it the ball joint will be wrong side up. Check kung may tinatamaan.
Usually they use a mitsubishi steering box (LHD). But it should still turn full unless may tinataam ang mga lings or the angles dont match.
hand brake is self adjusting. if i recall you mentioned overheating brakes. If this is the same wheel, the asbestos lining on the shoe might have been dislodge because of the the extreme heat. Just a wild guess.
September 4th, 2007 12:13 PM #12
The the ball joint ends are still right side up but the pitman arm end (which used to be in the right side) has been turned or flipped so that now it is already on the left side where the (transferred) pitman arm is.
You mean angle between the pitman arm and drag link vs angle between idler arm and drag link? might have to check that as well.
Would you know what steering box (brand and part no.), whether mitsu or Isuzu, should have been installed?
Or maybe Sir you know of a shop that could check, and hopefully fix, my steering problem?Last edited by bigcawa; September 4th, 2007 at 12:19 PM. Reason: spell check
September 4th, 2007 01:09 PM #13
The drag link has an offset as regards to holes for pitman and idler and the 2 ball joints that if you turn it left side to right and vice versa, something will face in the wrong way. Just a gut feel though not sure.
Wala ako kilala that is into conversion.
September 4th, 2007 02:40 PM #14
ok. Thanks again 4JG. Hirap nito di ko kasi makita yung car. Will try to check everything when I get back na lang.
Would you happen to know a place where I can get surplus steering geabox and draglink for a Bighorn? Pareho ba sila nung mga nakakabit sa mga local units? Kung ayaw talaga maayos mukhang ito na lang ang paraan.
September 4th, 2007 04:51 PM #15
Bro,
Have a suggestion pero medyo mahirap. If you have relatives near SF there is a recycling for hyundai/isuzu. They have units na pwedeng for parts. Pump, fittings/hoses and steering box is what you need. Bolt in sana ito.
Kung ganahan ka pa steering column na rin at linkage.
September 4th, 2007 05:34 PM #16
September 5th, 2007 01:45 AM #18
Hmmm... if you like the oem isuzu gearbox punta ka sa mga autosupply that caters to isuzu parts. sa caloocan may isuzuparts, 4th or 5th ave ata yun. or you can have a competent mechanic check out your steering system and see what is stopping it from making a full turn.
September 5th, 2007 08:33 AM #19
Maraming salamat sa mga suggestions sir. I will update this thread kung ano na nangyari sa Bighorn ko.
September 6th, 2007 03:16 PM #20
I was checking the archives and found this thread. The post by garyq caught my attention. Is possible that the idler arm (or the pitman arm) is causing the problem? What did he mean by "you can buy the orig LHD para walang welding or should I say minimal welding"?
http://tsikot.yehey.com/forums/archi...hp/t-5728.html
I have changed the idler assembly (?) but i think did not change the arm itself. Hindi kasama at bakal lang naman yun, hindi nasisira
personally, i'd think thrice, before buying that toyota brand new rack and pinion, to fix my 2003...
rack and pinion repair
