The the ball joint ends are still right side up but the pitman arm end (which used to be in the right side) has been turned or flipped so that now it is already on the left side where the (transferred) pitman arm is.
You mean angle between the pitman arm and drag link vs angle between idler arm and drag link? might have to check that as well.
Would you know what steering box (brand and part no.), whether mitsu or Isuzu, should have been installed?
Or maybe Sir you know of a shop that could check, and hopefully fix, my steering problem?
