Results 11 to 20 of 61
August 23rd, 2006 07:50 PM #11
Tsikot Member Rank 5
- Nov 2003
- 3,848
August 23rd, 2006 11:43 PM #131500 sa autoplus is the labor palang. they have a nice new machine and will be able to suck up everything. figure 6-10 liters of atf so you have a good flush.
- Aug 2006
- 337
August 24th, 2006 06:00 AM #14Not sure kung torque converter ng stares have drain plug.Kung meron it's very easy.let me know.
Tsikot Member Rank 4
- Jun 2006
- 2,605
August 24th, 2006 10:09 AM #15Just wondering why you need to flush your entire ATF system. I thought the normal procedure is to drop the pan and replace the 3 or so liters of ATF and replace filter if needed.
August 24th, 2006 10:25 AM #16
Sa Pilipinas naging 'normal' na iyan kasi wala tayong equipment. hehehe. Pati sa dealer iyan na ang 'normal' nila.
- Jun 2006
- 2,605
August 24th, 2006 10:40 AM #17I see. So how often should you drain and replace the system. I know usually every 2 years or 24,000 kms or whatever is stated in the manual. What I'm asking is should ATF "dialysis" be performed every 2 years or every other ATF flush, so in effect one dialysis per 4 years, or is it ok to just do the "normal" replacement?
August 24th, 2006 10:44 AM #18
Naku sir, intervals depend on your vehicle. Yung sa Starex hindi ko pa nacheck ang intervals. But this will be the first time na papalitan yung fluid since the unit was acquired in 2003.
Boy, am I glad I never bought an Ecosport!
BYD Philippines
