Page 3 of 3 FirstFirst 123
Results 41 to 42 of 42
    Aug 2004
    #41
    May nabasa rin ako sa one of the DSM forums that Diamond lang talaga ang pwede for Mitsu ATs. Something to do with allowable clutch slippage and such.
    I know someone who uses Dexron III in his Invecs II tranny. No reported problems yet. BTW this tranny is coupled to a 6A12 MIVEC engine.
    Ended up using Mitsu ATF on my own ride just to be safe.
    #42
    Quote Originally Posted by romtrt View Post
    Jaemess bro pwedi ba kahit hindi Diamond SP II for the Mitsubishi like your eclipse? Di ba Dextron III ang Mobil 1 full synth. Nabasa ko kasi sa ibang foreign site like thegalantcenter.net. Maselan daw tranny ng Mitsubishi and dapat oem fluid gamitin or equivalent like Amsoil atf. Tagal ko na nag reresearch nito if pwedi ba talaga Dextron III sa Mitsu. Pati sa Casa Dextron III nilalagay. Sa other countries may hinahalo sa dextron III para mag match sa Diamond SP II. Dextron III will work daw but it will kill the tranny in the long run..Ano masasabi nyo dito mga Ser? Ako nga gamit ko redline high temp. Swabe din pro nung nabasa ko yun parang na alarm ako..Sana enlighten nyo po ako..Yung kasi Mitsu atf ng casa for newer models lang daw like the trptonics. Di daw pwedi sa Galant 7g. Thanks!
    sbi skin d best DAW n atf yung synchromesh(imported) pero mas mahal cguro, Autoplus ata meron.. pero basta gud brand na dextronIII mpa mobil, redline, castrol, motul etc. ok
    wala p nman nagiging problem sa a/t tranny nmin..
ATF Fuilds
