like engine oil, you should get slightly smoother running/shifting from the full syn atf's vs regular ones.
Thanks.
What about mineral atf vs another mineral atf? Will different brands have different performance, say one will provide better protection against transmission breakdown and fluid failure? Or since they are both mineral and pass the Dex III standard, they will be the same?
yung b bossing na Honda ATF-Z1, mineral ba yun o synthetic?Ano kya magandang alternative dito.Ang mahal kasi, 500/ltr nun last ko bumili.Tnx
hard to say for sure what the differences are between different brands. we only use castrol and motul in the shop tho...
afaik, honda fluid is mineral lang.
links to info about Honda ATF Z1
http://www.popularmechanics.com/how_...87.html?page=3
http://www.artsautomotive.com/GenuineFluids.htm
It seems that you can use Dex III as a substitute but may experience harsh shifting. Also if your car is still under warranty, Honda will void it if they find out that you used a different fluid.
Redline full synthetic ATF sa superior motors Dr Garcia st bet Q ave and panay pagkatapos ng Pegasus.
i just used Quaker State synthetic blend on my last atf change in the crv.
Name brand I'd go for. You can use ATF for your power steering, this is what my mechanic said tried it, it works.
yup, and kung up-to-spec ung ATF sa tranny mo, bakit ka bibili ng mura na ndi ka sigurado?
mga bossing OT lang. may expiration ba ang ATF? bumili kasi ako ng mobil 220 Dexron II mga oct last year kaso may natira pang 11 liters nung magpa ATF flushing ako sa autotechnika.
Jaemess bro pwedi ba kahit hindi Diamond SP II for the Mitsubishi like your eclipse? Di ba Dextron III ang Mobil 1 full synth. Nabasa ko kasi sa ibang foreign site like thegalantcenter.net. Maselan daw tranny ng Mitsubishi and dapat oem fluid gamitin or equivalent like Amsoil atf. Tagal ko na nag reresearch nito if pwedi ba talaga Dextron III sa Mitsu. Pati sa Casa Dextron III nilalagay. Sa other countries may hinahalo sa dextron III para mag match sa Diamond SP II. Dextron III will work daw but it will kill the tranny in the long run..Ano masasabi nyo dito mga Ser? Ako nga gamit ko redline high temp. Swabe din pro nung nabasa ko yun parang na alarm ako..Sana enlighten nyo po ako..Yung kasi Mitsu atf ng casa for newer models lang daw like the trptonics. Di daw pwedi sa Galant 7g.Thanks!
