Results 21 to 40 of 42
    Jun 2006
    #21
    Quote Originally Posted by speedyfix View Post
    most atf's available locally are mineral based.motul, redline and mobil have full syn variants which will be able to take more abuse.
    I understand that syn will be better and take more punishment. But is there a big difference between the different mineral based ones?
    Nov 2003
    #22
    like engine oil, you should get slightly smoother running/shifting from the full syn atf's vs regular ones.
    Jun 2006
    #23
    Thanks.
    What about mineral atf vs another mineral atf? Will different brands have different performance, say one will provide better protection against transmission breakdown and fluid failure? Or since they are both mineral and pass the Dex III standard, they will be the same?
    Feb 2006
    #24
    yung b bossing na Honda ATF-Z1, mineral ba yun o synthetic?Ano kya magandang alternative dito.Ang mahal kasi, 500/ltr nun last ko bumili.Tnx
    Nov 2003
    #25
    hard to say for sure what the differences are between different brands. we only use castrol and motul in the shop tho...
    afaik, honda fluid is mineral lang.
    Jul 2006
    #26
    Quote Originally Posted by DRIV3R View Post
    mahal naman nyan. unknown to many, CASAs use cheap-dirt oils. they always try to say that it's the best to your machines. but it's a mineral-based only. bili mo na lang ung MOBIL ATF FULLY SYN. around 600-650 php.. mobil oils are tried and tested na..
    Jun 2006
    #27
    links to info about Honda ATF Z1
    http://www.popularmechanics.com/how_...87.html?page=3
    http://www.artsautomotive.com/GenuineFluids.htm
    It seems that you can use Dex III as a substitute but may experience harsh shifting. Also if your car is still under warranty, Honda will void it if they find out that you used a different fluid.
    #28
    Redline full synthetic ATF sa superior motors Dr Garcia st bet Q ave and panay pagkatapos ng Pegasus.
    Dec 2003
    #29
    i just used Quaker State synthetic blend on my last atf change in the crv.
    #30
    Name brand I'd go for. You can use ATF for your power steering, this is what my mechanic said tried it, it works.
    Feb 2007
    #31
    yup, and kung up-to-spec ung ATF sa tranny mo, bakit ka bibili ng mura na ndi ka sigurado?
    #32
    mga bossing OT lang. may expiration ba ang ATF? bumili kasi ako ng mobil 220 Dexron II mga oct last year kaso may natira pang 11 liters nung magpa ATF flushing ako sa autotechnika.
    Feb 2007
    #33
    mga tsong mag MOTUL nalang kayo the best un.
    Jul 2006
    #34
    Quote Originally Posted by n5110 View Post
    matagal ang expiration ng mga lanigs. 3 years na nga ginagamit ung lanigs maganda pa rin ang quality, edi lalo na kapag hindi ginagamit. hindi namn sila tulad ng pagkain na napapanis..
    Jun 2006
    #35
    Quote Originally Posted by motul_oil View Post
    How much ba Motul? And is it mineral or full synth?
    May 2005
    #36
    ayos sa handle.nag bebenta po ba kayo ng Motul Oil?
    I heard kahit sa MC maganda din daw gamitin ang MOtul
    Nov 2003
    #37
    motul atf 1a full syn atf is 600+ per liter.
    #38
    Quote Originally Posted by 2Dmax View Post
    ok sir thanks. reserba ko na lang ito on my next atf change.
    #39
    mobil atf full synthetic.
    toh gamit nmin ng bro ko. swabeng swabe.
    Sep 2005
    #40
    Quote Originally Posted by jjaammeess View Post
    Jaemess bro pwedi ba kahit hindi Diamond SP II for the Mitsubishi like your eclipse? Di ba Dextron III ang Mobil 1 full synth. Nabasa ko kasi sa ibang foreign site like thegalantcenter.net. Maselan daw tranny ng Mitsubishi and dapat oem fluid gamitin or equivalent like Amsoil atf. Tagal ko na nag reresearch nito if pwedi ba talaga Dextron III sa Mitsu. Pati sa Casa Dextron III nilalagay. Sa other countries may hinahalo sa dextron III para mag match sa Diamond SP II. Dextron III will work daw but it will kill the tranny in the long run..Ano masasabi nyo dito mga Ser? Ako nga gamit ko redline high temp. Swabe din pro nung nabasa ko yun parang na alarm ako..Sana enlighten nyo po ako..Yung kasi Mitsu atf ng casa for newer models lang daw like the trptonics. Di daw pwedi sa Galant 7g. Thanks!
ATF Fuilds
