Results 11 to 20 of 21
    Jan 2020
    Quote Originally Posted by istan View Post
    Bearing. Sure yan
    Hi sir, how are so sure na it’s bearing rather than the other cases? If it’s wheel bearing, why does the annoying sound only happened to be intolerable when i installed my other tires?
    Quote Originally Posted by MasterHepburns View Post
    Thanks sir doc, yun din ang number 1 suspect ko e. May solution pa ba to? I’m planning to swap my front left tire and rear left tire and see if the sound will change position. Kung wala ng solution to basura tong tire ko. Hays
    well, mine dis-appeared when i exchanged the front with the rear tires.
    but i eventually replaced them anyway, as i was uncomfortable driving around, knowing my tires were defective.
    I hope so sir. I went to a tire shop kanina. Tapos sinabi ko issue. Ang sinabi sakin baka daw wheel bearing. I’m pretty sure it’s not. So i walked away and will try to visit other shop next time.
    Anung noise pala ba? Ugong from one specific side? Alala ko may ugong yung 2008 city namin nung may bearing issue on one side. Pero hindi ko 100% masigurado na yun nga lang yung symptom.
    May rhythm ba na repetitive (assuming consistent speed) kada ikot ng gulong? kasi this would present kung may specific point nga na hindi na bilog or may "tama".
    Sabi mo din pala it looks "new" pa yung old tire pero when was it manufactured? How long ago?
    Pero curious lang ako why you have 2 different rims for the same car? or nagkataon lang may reserve 1 pc rim ka na 17s na may gulong pa nakakabit while others were sold maybe?
    Medyo nalito lang ako sa pangyayari din.
    Jan 2020
    I feel you sir. My question now is there a machine that can prove that my tires are cupped? Kac pag tinitignan mo talaga pati yung thread nya sir is bago e. I know you saud na try ko igulong sa flat ground pero mas gusto ko sana yung machine hehe
    Well, simple na lang kung bearing ba talaga or gulong kung ayaw mo magpalit. Ilagay mo sa harap, opposite side yung 17s na luma goma and kabit mo yung 16s naman sa kung san mo dati kinabit sa likod yung 17s.
    Pag yung tunug andun pa din sa likod kung san nakakabit yung 16s ngyn (dating kinabitan ng 17s) e di hindi nga gulong yung issue.
    my thoughts are,
    if it's the bearings, it will make a ruckus no matter what tire is installed.
    it might make a noise, even if one simply spins the tire while the car is jacked up and the tire is hanging in the air.
    Jan 2020
    Quote Originally Posted by 17Sphynx17 View Post
    Sorry sir. My stock rims ko po is 16s tapos bumili ako nun ng 17s rims. Bought it for cosmetic purpose hehe.
    Di ko po alam tunog ng ugong haha! Pero ganitong ganito yung sound sa video KIA Forte Koup bad tires noise while driving - YouTube
    Sa mfg naman ng tire sir it was 2015. Old?
    Jul 2013
    Sounds like you stored the tires with the wheels together. You should have stored it at around 40psi to avoid oblong-ing.
    Wheel balancing might help..
    either oblong yung tires... or worse, yung rims - a good experienced vulcanizing shop will see it
    if its a humming sound, possible na bearing
    2015 not that old kung ganun.
    Teka, directional tire ba yung sa 17s?
    Pero masuggest nga is trace kung san galing yung sound as to which side. Say 17s nga yung rear na kinabit mo nung nagingay. Try na lang kung kaya na ilagay sa harap yung 17s and 16s sa rear to test it out since andiyan na yung rims and tires.
    Re sa shop, swertehan nga kung maayos or marunung talaga yung kausap mo about checking the tires para di mapasubo agad sa bearing replace agad tapos kalaunan may ugong pa din dahil gulong lang pala issue makakasuntok ka ng mekaniko pag ganun. hehe!
    Ayun, humming sabi ni ice. ugong yung asa isip ko. hehe!
    Yung sa alignment naman, pag mabilis takbo, ang experience ko kung alignment ang issue may "nginig" manibela pag 60 above takbo mo. habang bumibilis ka, lalo din mas nanginginig manibela habang hawak mo so less likely since wala ka nabanggit na nanginginig steering wheel mo while driving 60 kph above.
    Jan 2020
    Yes sir. Directional tire. I know it’s noisier than other type of tires pero ibang tunong to sir. Narinig mo yung sa video na nasa link boss? Ganun talaga sound.
    About alignment, wala syang vibration pero it steers to the left very slightly. Which i suspect the annoying tire sound comes from.
    Di ko masyado iniisip na bearing to sir, kac alam ko tunog ng bearing kac may ganung tunog dati family van namin.
    Now kung talagang bulok talaga tong tire ko mga sirs, pwede ba na isa lang kukunin ko na tire since isa lang defective? Or do i need to buy 4 tires? (Di ready bulsa ko neto haha!)
Annoying tire sound on my honda city 2006
