Results 1 to 20 of 21
    Quote Originally Posted by MasterHepburns View Post
    Hi sir, actually different mags din. Yung stock ko is 16s tapos ang nakalagay ngaun na maingay is 17s. So you think sir no need to buy new tires? Kelangan ko lang pa balance para mawala yung tunog? Yun din kac plano ko. Mahal kac tires tsaka sayang to kung di ko gagamitin. It looks new since 6 mos lang nagamit.
    Sounds like you stored the tires with the wheels together. You should have stored it at around 40psi to avoid oblong-ing.
    Wheel balancing might help..
    Jan 2020
    I hope so sir. I went to a tire shop kanina. Tapos sinabi ko issue. Ang sinabi sakin baka daw wheel bearing. I’m pretty sure it’s not. So i walked away and will try to visit other shop next time.
    Anung noise pala ba? Ugong from one specific side? Alala ko may ugong yung 2008 city namin nung may bearing issue on one side. Pero hindi ko 100% masigurado na yun nga lang yung symptom.
    May rhythm ba na repetitive (assuming consistent speed) kada ikot ng gulong? kasi this would present kung may specific point nga na hindi na bilog or may "tama".
    Sabi mo din pala it looks "new" pa yung old tire pero when was it manufactured? How long ago?
    Pero curious lang ako why you have 2 different rims for the same car? or nagkataon lang may reserve 1 pc rim ka na 17s na may gulong pa nakakabit while others were sold maybe?
    Medyo nalito lang ako sa pangyayari din.
    Jan 2020
    Quote Originally Posted by 17Sphynx17 View Post
    Sorry sir. My stock rims ko po is 16s tapos bumili ako nun ng 17s rims. Bought it for cosmetic purpose hehe.
    Di ko po alam tunog ng ugong haha! Pero ganitong ganito yung sound sa video KIA Forte Koup bad tires noise while driving - YouTube
    Sa mfg naman ng tire sir it was 2015. Old?
    2015 not that old kung ganun.
    Teka, directional tire ba yung sa 17s?
    Pero masuggest nga is trace kung san galing yung sound as to which side. Say 17s nga yung rear na kinabit mo nung nagingay. Try na lang kung kaya na ilagay sa harap yung 17s and 16s sa rear to test it out since andiyan na yung rims and tires.
    Re sa shop, swertehan nga kung maayos or marunung talaga yung kausap mo about checking the tires para di mapasubo agad sa bearing replace agad tapos kalaunan may ugong pa din dahil gulong lang pala issue makakasuntok ka ng mekaniko pag ganun. hehe!
    Ayun, humming sabi ni ice. ugong yung asa isip ko. hehe!
    Yung sa alignment naman, pag mabilis takbo, ang experience ko kung alignment ang issue may "nginig" manibela pag 60 above takbo mo. habang bumibilis ka, lalo din mas nanginginig manibela habang hawak mo so less likely since wala ka nabanggit na nanginginig steering wheel mo while driving 60 kph above.
    Jan 2020
    Yes sir. Directional tire. I know it’s noisier than other type of tires pero ibang tunong to sir. Narinig mo yung sa video na nasa link boss? Ganun talaga sound.
    About alignment, wala syang vibration pero it steers to the left very slightly. Which i suspect the annoying tire sound comes from.
    Di ko masyado iniisip na bearing to sir, kac alam ko tunog ng bearing kac may ganung tunog dati family van namin.
    Now kung talagang bulok talaga tong tire ko mga sirs, pwede ba na isa lang kukunin ko na tire since isa lang defective? Or do i need to buy 4 tires? (Di ready bulsa ko neto haha!)
    of course, you can buy and replace only one tire. but if your treads are already in the advanced wear stage...
    how's your spare, po?
    perhaps you can do some tire rotation...
    experts say, the tires with good tread be installed at the rear.
    Jul 2013
    either oblong yung tires... or worse, yung rims - a good experienced vulcanizing shop will see it
    if its a humming sound, possible na bearing
Annoying tire sound on my honda city 2006
