Results 21 to 40 of 45
    Nov 2004
    #21
    san kayo nag papa replace ng oil? mahal ba nagastos nyo? im planning to have my pajero replaced those oils.. ty!
    #22
    Gas station. Usually Shell. Just check if they have the correct fluid in stock.
    Mar 2003
    #23
    Quote Originally Posted by the_possessed View Post
    sa petron ako nagpagawa, total cost 1,100. front and rear diff, transfer case plus yung nipples pinagrease narin. sabi sa manual gl4 dapat sa diff. tapos gl5 sa transfer case, kaso gl4 lang meron sila yun narin pinalagay ko, i'm not sure kung meron bad effects to. hth
    Nov 2004
    #24
    medyo mahal din pala.. but i think i need to replace mine.. 96k na ung mileage.. hehe
    Nov 2003
    #25
    minsan minsan lang yung gear oil palitan. it's much cheaper to maintain the tranny than the engine.
    #26
    Guys,
    For M/T, is the front differential oil shared with the manual transmission oil?
    #27
    Quote Originally Posted by mazdamazda View Post
    Guys,
    The differentials are separate from the transmission and the transfercase (if applicable)
    Sometimes, you're even required to use different grades for them (GL4 for the tranny and GL5 for the diffs and t-case)
    Check your manual with regards to type and grade just to be sure.
    In my case, all of them can use GL5 which simplifies logistics and fluid storage for me.
    YMMV.
    Hope this helps.
    Nov 2003
    #28
    in a front wheel drive vehicle the gear and diff oil are normally together.
    in a 4wd car you have the gearbox and both front and rear diffs or in some cases the front transfer case.
    #29
    hardcharger & speedyfix,
    The reason why am asking if that is because there is no recommended oil for the front differential only in the manual of the Rav4:
    Manual Transaxle oil
    Gear oil API GL-4 or GL-5
    SAE 75W-90
    3.4 litres
    Transfer oil
    Hypoid gear oil API GL-5
    SAE 90
    0.9 litres
    Rear differential oil
    SAE 90
    0.9 litres
    P.S. Speedyfix, do you have lubricants with the specific oil viscosities (as stated) in your shop?
    Thanks
    Nov 2003
    #30
    yup,it's probably included na ithe front transmission.
    my royal purple gear oil meets gl4 and 5 requirements but is multigrade 75w90.
    #31
    speedy... sayang... sa Royal Purple website may SAE90 gear oil kc... will just outsource it then sa inyo na lang ang labor.
    Nov 2003
    #32
    no problem... better to get multigrade though imo
    #33
    speedy, yup... pwede yata multi-grade oil... been reading up in rav4world.com
    wouldn't it be too thin compared to the single viscosity that the manual is recommending?
    #34
    I concur with speedyfix with this one.
    I guess that it may have something to do with being a FWD?
    #35
    full-time AWD yung Rav4... nagtaka lang ako kasi iniba pa nil yung recommended oil viscosity for the transmission/frontdiff & transfercase/reardiff.
    #36
    depende din kasi sa load and metal components ng tranny, diffs and xcase kaya need iba ibang grade of oil for protection and lubrication.
    May 2004
    #37
    m2; sa trooper ko ordinary oil(engine oil) ang nsa transmission at transfer case. front and rear differential is lsd. common na rin talaga magkaiba.
    Nov 2003
    #38
    mazdamazda, nope not really... multigrade just means it flows differently depending on the temp, pero here in manila you don't really get the full benefit of that since we are predominantly hot so your oil will flow mostly like the 2nd number
    #39
    i think due na rin for maintenance ang differential oil ko. 76K reading na sa odometer but will check din sa manual.
    sir speedy..
    how much would it cost for a rav4.1 for this maintenance sa shop nyo? labor and materials. including transmission oil. A/T po ung rav.
    thanks!
    Nov 2003
    #40
    you can call or text me. or call me in the shop for the estimate just specify the type of fluids you want... kung mineral or our RP full syn ones
4WD Maintenance
