Guys, I need to clarify the following 4WD maintenance items:
1. Re-torque drive shaft bolt
- how is this done?
Tighten until zero clearance then balik 2/3 turn.
2. Replace rear differential oil
- a few months ago, I had the rear oil seal fixed * autotechnika then had the mechanic * speedyfix to top-up the "gear oil" near the front of the engine (he had to lift the car to access it btw). is this the rear differential oil or the transfer case oil?
Nearest the engine will be the front differential beside the transmission is the transfer case. Easy to spot dahil may properer shaft going front. Meron din transfer case na may front and rear propshaft. Always look for the front prop shaft sureball.
3. Replace transfer case oil
- how is this different from the rear differential oil?
Usually same grade as the transimission oil. Sa rear differential depends on the type or the OEM recommendation.
3. Replace front differential oil
- is this connected with the rear differential oil?
In 4WD you have two differential except in trucks where in you have 4wheel drive but in the same/one axle.
Thanks!
