Page 1 of 15 1234511 ... LastLast
Results 1 to 20 of 436
    Aug 2005
    Frontier owners, kamusta na ang mga rides nyo? Mine is still doing good. 5 years na at wala pang problema.
    Here's a pic of my ride, taken yesterday at Paseo de Sta.Rosa :
    I know theres a lot of Frontier owner on this board like quiksie, wildthing & vinj. Hopefully we can share tips, tricks and wallet saving DIY solutions sa mga problems ng rides natin. Also it would be better if you can post pics of your rides din.
    Umpisahan ko na :
    Anyone with an open type K&N filter on their Frontier? I've talked to quiksie regarding this(good input pare! Salamat ulit.). Im really interested in changing the stock filter to this one kaya lang medyo nagdadalawang isip ako kasi magiging maingay ang makina. I was quoted around 7-8k for the K&N filter including the Simota tubing. Is this a good investment o I just stick to drop-in type filter?
    OT : I was browsing the Top Gear Magazine Oct. issue and I saw an article regarding the Frontier. Im assuming si vinj un Vinci Jayme? Nice article pare. Ganda ng Frontier mo. I ended up buying the magazine because of that article.
    Anyway looking forward in your replies.
    Thanks for looking.
    hi Lemon
    we still have our frontier.
    4x4. manual. 03model.
    still doing good.
    had a problem with the aircon compressor a few months ago.
    brought it to UMC pasong tamo.
    they replaced it with a bnew one, no charge coz of the warranty.
    hehehe.
    for me its a good investment. atleast better airflow in the engine.
    i dont mind having a bit noisier engine. have you seen an actual unit with this set up already?
    thanks
    jappy
    dont know how to put the picture like you did.
    Aug 2004
    Jappy,
    Nagkaproblema ka rin sa compressor?
    Got similar problem for that batch. 3 out of 4 frontier mdl 2003 were already replaced with new compressor by Univelle at no cost. sabi daw ng service advisor sa mga paggamit daw pero ....
    Quote Originally Posted by jappy
    hi Lemon
    still doing good.
    hehehe.
    thanks
    jappy
    May 2004
    Eto naman yung sa amin. 4x4 manual, 2002 model
    hi Lemon
    still doing good.
    hehehe.
    thanks
    jappy
    how much usually inaabot mga ganyang kalaking rims?
    swerte mo naman jappy humabol pa sa waranty ang a/c mo....my 03 4x2 Elite didn't make it kasi ang odometer ko exceeded na kilometer reading although it was 1 month short to 2 years old.
    Anyway it cost me around P13k for the brandnew compressor and another P2 to 3K to have the A/C system cleaned and installed.
    I think pangit na xecel/calsonic compressor lately unlike the original calsonics. (AFAIK Xecel bought calsonic).
    Kung nagkataon pa nga I planned to convert the compressor sana to SANDEN which was way cheaper (P6k brandnew).
    As for the ride I have no qualms and problem...my odometer is beyond 85,000 km na and barely 2.4years old. It is a black elite 4x2 with an alpha rear shell.
    Aug 2005
    Thanks for the reply Jappy & wildthing.
    Mukhang compressor nga ang nagiging problema sa Frontiers. Pero parang lagi ang case ay dun sa mga models na facelifted na, 2001 & up?
    wildthing, sayang hindi ka pa umabot sa warranty. Mahal ng bagong compressor.
    jappy, nice pic pare! 17's ba yang gamit mo? Bagay na bagay.
    To post pic, kailangan mong mang-upload muna sa host un picture. Try www.tinypic.com. Then pag-na upload na use the link from the IMG box. Then just post the link on your message. Pa-post ulit nung pic mo, para mas malaking pics makita natin.
    Regarding the conetype filter, sa pics palang ako nakakakita ng nakakabit sa Frontier, pero sa 3.2 engine nakakabit. Here's the pic courtesy of doclloyd from teamrage.ph :
    Any more insights on using it on a TD27 engine? Naka-schedule na kasi akong magpalit ng air filter. Kung bearable naman un added noise, might as well go with the conetype.
    Thanks!
    May 2005
    Quote Originally Posted by Lemon
    Thanks!
    Di maingay pag conetype filter?
    Lemon, ganda ng ride mo dude. Very clean and I like those rims... pa-nakaw. Hehehe. Mine is already due for a visit to Big Berts for a much needed detailing… dami nang asphalt marks and small scratches sa paint. I also need to have PDR work because of those parking lot door dings/dimples and some small “na-sabitan” dents.
    I noticed your headlamps are already darkening though. Pretty common with the Frontier after some time but some cleaning can cure that. Using UV Block bulbs like Philips will also help keep the headlights from darkening (I have upgraded headlight wirings and use 90/100W Philips all-weather bulb: very good combo sa Frontier IMO).
    On the compressor, if you experience any compressor problems, try to have the a/c system tubing checked as what I found out with a friend before (who went through 3-4 compressors in one year on his Exalta) was that the clogged a/c system tubing caused his compressor(s) to self-destruct.
    If anyone likes to upgrade the intake system and you have a 2.7L m/t model, you can also use the off-the-shelf Simota intake system designed for the ’93-’95 Honda Civic ESi. This will fit in and all you need to make is some custom mounting brackets; it’ll cost only around Php1.5K for the intake. Just make sure the mounting points are still on the engine so the filter will still move with the vibration of the engine (unless you do some tube cutting and install some flexible rubber hosing). I tried this on my Frontier before but I didn’t keep it as I found the noise beyond my taste. The one pictured above on the QD32 engine is the one i'm referring to (this will also fit the TD27 as the manifold locations are similar).
    Yup, I contribute for TG (last month and this month so far); I decided to use the Frontier as my debut used car article.
    Here's a pic i took at Calaruega before:
    Aug 2005
    Thanks vinj. NIce pic, very dramatic...hehe
    Rota at AMS pinagpilian ko sa mags, pero I ended up with AMS because Auto Options gave me a good price. Tapos binenta ko na lang sa labas un OEM mags ko.
    Yup, dark na nga talaga un headlights ko. Im planning to go din sa BigBerts for headlight cleaning and interior/engine detailing. Sa exterior DIY ako para tipid. Sir san po kayo nakabili nun 90/100W Philips all-weather bulb? Nahihinaan ako sa ilaw lalo na pag-gabi. DIY ba un headlight wirings mo? Medyo wala ako alam sa ganyan baka makuryente ako....hehe. Also san ka nakabili ng OEM na foglights? OEM din ba un switch na nabili mo? Im planning to go to Kapalangan to look for the foglights, pero kung konti lang difference ng price, dito sa Manila stores na lang ako bili.
    Mukhang mag-stick na lang ako ulit sa drop-in air filter. Baka hindi ko din matagalan un ingay.
    Ano nga pala un bagong article mo this month? I haven't checked the new issue yet.
    Keep the replies coming.
    Thanks!
    Oct 2004
    ang mods ko lang sa are ray brig na spot lamp sa driver side na naka mount, backup spot lamp na nakalagay sa fashion bar, shackle mods and crank, carryboy roller up, roof rails.
    Frontier model: 4x2 titanium edition
    susunod na pics
    Dec 2013
    Good day mga kafrontier, I ownd a 2nd hand 4x2 model 99, nbili namin last 2007, so far ok naman pero lately my npapansin n ako n mausok na sya, ano kaya dpat palitan, d.i.y person din kc ako mhal sa casa e. nagpalit kmi ng fuel filter last 2008 p,
    •isa kya po ito n cause ng usok?
    • dpat n din po b ako magpalit ng trans fluid at anong klase po
    • dpat n din po b plitan ng diferencial fluid at anong klase din po
    Another isue is ung may tunog n parang barya sa ilalim, lalo pag medyo nbitin k sa 4th gear.. Ung mga guages dati pumapalya, tataas bababa, kahit tap mo yung dash di xa magbinigay na ng correct reading, ano kaya po ito?. Hope nagbigay kayo ng mga coments nyo at malaking bagay po saaking business ang sasakyan na ito.. Maligayang pasko sa inyong lahat..
    meron pa ba nabibili na brand new ganitong model? para mas mura kesa sa current model
    Dec 2008
    hey good p.m. sa lahat i like your cars in its condition i like nissan cars in fact i have a nissan navara 2008 good performance but recently i realized gusto ko pala yung mag downgrade to td engine npick up nway good day to all ya.
    lemon
    will try the picture upload. la pa lang ako time.
    ganda nung air filter ah. parang gusto ko magpalagay.
    hehehe.
    18 na lenso yung kinabit ko. hindi na nga lang chrome kasi 18 lang naman.
    mahirap kasi pag 20. minsan may karga ako na mga engines and differentials.
    vinj
    may nakita ka na kabit nung pang esi na simota.
    try ko din pala yun. mukhang ok din eh.
    katsudon_ph
    yep. compressor daw talaga sira. nung dinala ko nga sa umc, alam na agad nila eh.
    buti na lang meron pa silang stock, kasi kung nagkataon, maghintay ako ng new batch ng supplies nila.
    109
    wala na ata eh. puro 2ndhand na nakikita ko.
    gusto ko sana lagay HID both sa headlight and foglight area, kaso sobra mahal naman.
    ok kaya yun?
    kung 3 out of 4 sa 2003 ang meron problem sa compressor before reaching 2 years old baka ng factory defect yun...
    Sayang nga yugn 2003 models wala ng ung heater ng A/C system....
    BTW 109 kung type mo low priced you can always get a Frontier Standard...upgrade mo na lang tires to 15" rims...eto na pinaka mura na presyo....yung friend ko na ahente ng Nissan Balintawak gives me out a P40,000 discount whenever we buy a pick up from him (para sa office)...
    Sa standard ang amenities lang naman na nawala ay yung power windows, lock, sideview mirrors and antenna...all of which pede naman mong mai-upgrade latter on (marami na rin sa Capalanga nun by this time).
    Aug 2004
    Quote Originally Posted by wildthing
    Just to clarify it,
    3 out of 4 units that we purchase for the year 2003 ang nasiraan na ng compressor.
    Also for the discount mababa pa ang 40k na discount. We were able to get as much as 80K.
    never pa ako nagpalit ng compressor at feeling ko may sira. lumalamig pa sya pero kapag natraffic ako ng sobra, nawawala na ang lamig. ganun ba ang sira ng compresor nyo? ano kaya sira ng akin?
    Quote Originally Posted by jvandanne
    Baka naka todo high lang ang thermostat mo? Another is that madumi na ang fins ng evaporator mo. Time for cleaning ng A/C system mo.
    May 2005
    I'm using a '99 4wd Frontier and the only "mod" I did was to install a roof rack and change the rims...
    san ba nakakabili nung plastic thing (di ko alam tawag) dun sa may tip ng hood ng truck mo, lemon? how much kaya yun and ano function nun?
    also, san pwede kaya pakabit nung window visors? how much kaya?
    I'm thinking of taking out my truck's tail gate and installing the stretchable net/mesh instead... also, I'm scouting around for a hook so I can haul trailers (my truck has its hook at the right side and medyo mahirap humatak ng trailer using this)... when I install the hook, I'll have to replace my rear bumpers (with tubular types na ginamit sa power eagle) kasi it'll get in the way...
    hehe wish list ko lang, la din naman ako budget kaya paisa-isa lang siguro bili ko hehehe...
The Nissan Frontier Thread
