Results 311 to 320 of 1303
July 7th, 2010 08:32 AM #311
Okay bro.,- I just want to clarify so that those who are reading this thread know exactly what you are looking for....
Will also try to ask around if there is one lying around somewhere....
OT: A couple of former owners of Vanette, who I know removed one row of seat from the said ride, removed the last row to give them more cargo space at the back...
10.3L:sumo:
- Jun 2010
- 354
July 8th, 2010 04:35 PM #312Guys question lang po di po ba mahal singil sa ceejay`s aircon repair shop?
- Feb 2008
- 117
July 8th, 2010 06:33 PM #313-Okey lang ang presyo sa ceejay, medyo medyo on the average. Sanay na ako kasi don pag aircon repair. *RJBurgos / CVT meron ako sir nung dinescribe ni CVT.. 10.2k ba bentahan niyan? about my overheating problem: 1. pinalitan ng madaming blades ang fan. Siguro mga 1year lang nag overheat nanaman 2. relocate aircon sa pax side, doon yun sa may paanan nilalagay. it last ulit but overheat again after sometime 3. found out na nag leleak na ang radiator pero hindi siya mapapansin leak lang siya pag mainit tapos natutuyo agad kaya hindi visible so palit radiator. Evercool na 3rows. until na no overheating problem maganda temp ngayon eversince napalitan. Bumalik lang nung bumigay ang water pump. My problem now is yung intermittent stalling, 2months na ito
kaya naka bahay lang ngayon pang subdivision nalang siya
- Jun 2010
- 354
July 9th, 2010 01:37 AM #314*sir vanityq mas ok po ba removed ang thermostat?
magkano po yung 3row na radiator hehehe
question lang din po bakit po bumubulwak yung water from radiator? kahit in the morning tapos pag revolution mo umaapaw yung tubig....dahil po kaya ito sa tagas ng oil from engine? baka lang siguro wiring problems lang yung over heat pwede po ba yun?
sorry po dami ko question kanina lang ako nagkaroon ng students license hehehe
July 9th, 2010 09:13 AM #315
I do not recommend removing the thermostat, bro. It is there for a purpose. I once had an overheating problem and the thermostat was the culprit.... It does not open up.... Replaced it....
Sobra ba ang pagbulwak ng tubig from the radiator? Kung nakikita mo lang na malakas ang flow, then your pump is working okay.....
10.3K:sumo:
- Feb 2008
- 117
July 9th, 2010 08:01 PM #316*aijie
- Sobrang dami na din na modify sa overheat prob ko, tanggal na ang thermostat, pero as of CVT may purpose yun.
- May isa pa pala ginawa sakin, tanggal na ang (anong tawag don?) basta nakasabay na ang fan ko sa makina hindi na siya tumitigil kakaikot
-6k ata ang kuha ko sa rad Evercool 3rows. call mo nalang 8736054/8050107
*CVT
magkano bentahan nung 3rd row seat, i just thought na price yung last mo 10.2k 10.3k 10.3L ehehe
**Bakit di ko maedit post ko? ayusin ko sana yung next line
- Jan 2006
- 230
July 9th, 2010 11:42 PM #317pre, palitan mo na nga talaga yung rad mo kasi barado na yan...hindi na nakaka-suck ng maayos ang water pump mo nyan from rad bottom and yung coolant from engine is lumalabas na lang sa rad filler (bukana) kasi hirap na magflow sa mga rad tubes dahil sa bara. pwede mo rin pa overhaul na lang oem mong rad.walang kinalaman ang wiring unless electric fan ka lang...about thermostat, hindi na stable or regulated ang engine temp mo pag tinanggal mo...taas baba depende sa flow ng traffic sa kalsada..pero sa van ko din tinanggal ko na kasi mainit naman sa pinas at madali uminit at lagi namang mainit ang vanette e..hehe...after several months pwede ka na non-pro or pro license..good luck.
*vanityq. musta na van mo? nabasa ko pala sa kabilang thread yung update mo..sana okey na rin at di na magloko van mo.
- Jun 2010
- 354
July 10th, 2010 01:18 AM #318thanks to you guys
...mabuhay ang nissan vanette owners
tingin ko need ko nga mag change ng radiator nalang para maayos yung over heat and papatingnan ko thermostat di ko kasi alam talaga kung wala na o kung nakakabit pa.if ever na meron and it dosnt work i will replace it...over heat problem first bago ang aircon ko hehehe
anyway po ok lang kaya may tagas ang engine ko hehehe...sabi ni lolo matagal na daw yung pag leleak ng engine hmm...or can cause over heat din to?
July 10th, 2010 07:18 PM #319
- Jun 2010
- 354
Hi sir! Question lang po baka may idea kayo. 1994 GLXi Lancer Itlog 4G92 - about 10yrs na rin na...
LANCER Itlog (93-96) Owners - Please Post Here!
