Page 23 of 27 FirstFirst ... 13192021222324252627 LastLast
Results 221 to 230 of 264
    #221
    Quote Originally Posted by meldred0519 View Post
    Mga boss tanung ko lang may bago ako nabili nissan sentra gx 2010 43k pa mileage. Anu po fuel consumption nito na series 2010? City and highway and anu po rpm ko dapat mag shift gear salamat mga boss
    sa akin up to 2,500 rpm before shifting - - sa highway or open highway 3,000 para hindi bitin sa overtake
    when i went north (Ilocos Region) almost 11.99km/liter
    I used Shell Racing
    #222
    hindi dapat maingay yan sa pagdaan sa lubak.
    have the entire suspension system looked over, po. ball joints, rack ends (outer and inner! the inners tend to be forgotten because they are hidden).. tie rod ends.. shocks including shock tower ends.. rubber bushings! when the rubber loosens, there may be squeeks, or the metal parts may hit each other.. and bearings, just in case..
    also, the exhaust tube running under the car's floor might also cause some noise, if it is loose.
    crawl under the car or have it lifted in the gas station, and look for loose fittings underneath.
    and don't forget to inspect the rears, too. they also make noise when worn..
    good luck.
    i bought mine last year 2010 model GX... here are some of my problems
    - i did changed the all the rubber bushings, entire rack ends and i had the tie rods ends checked kasi everytime nalulubak ako malakas din yung galaw ng manibela - - after changing these problematic parts, naging ok na yung galaw ng steering wheel however pag nalubak ako meron pa ding konting galaw sa manibela - no noise but the response of the steering wheel is annoying me - - ang nabanggit na lang sa akin baka sa steering na ang may problem
    Mar 2015
    #223
    Quote Originally Posted by black panther View Post
    Maybe yun steering clamp rubber? Yun humahawak sir sa rack&pinion may rubber bushing dun baka worn out na po or yun shock mounts?
    #224
    Quote Originally Posted by SkyFlakes88 View Post
    thank you sir sa reply
    will try that next time if i have spare budget - - -
    Mar 2015
    #225
    Just check it lang sir baka yun ang culprit. Have somebody look at the rack&pinion while you are moving your steering wheel to the right and left position. The rack&pinion should not move too much as the clamp bushing will prevent that movement.
    #226
    I have a nissan sentra gs '07 M/T. 6-7km/liter city driving. Malakas ba un compared to normal?
    Aug 2015
    #227
    Quote Originally Posted by frosthemlock View Post
    Mukang malakas nga yan sir, us is getting a 9 - 10km/liter city driving 1.5cc M/T, petron 93 ang gamit
    #228
    Guys need your help.d kc ako makapost ng topic e...anyway.
    Nissan sentra 2004 gx M/T 1.3
    120k.no aircon.90k plus mileage nya.
    What do you think?
    #229
    Quote Originally Posted by reirocel View Post
    What do you think?
    depends..
    if an ex-taxi, you'll lose.
    the aircon alone, may set you back anywhere from 2K to 20K. at bakit hindi inayos ng seller? dahil alam na niyang mahal pagawa..?
    suspension is fix-able, whatever is wrong with it. but do check it well, so as to avoid possible fixins' here. also, inspect for possible lousy collision repair.. the suspension geometry may have been altered. take it for a spin.. dapat walang kabig nang kahit kaunti.
    the engine.. that is the big question.
    so, is the price good? kung wala nang aayusin pa.. ok na yan for me.
    but i still am wary of that aircon..
    good luck.
    #230
    Mga sir need your help.planning to buy a nissan sentra lec ps 1998 for 89k.makinis p sya.ok po b ang price
Nissan Fuel Consumption Database
