Results 1 to 10 of 12
- Aug 2009
- 7
August 10th, 2009 02:38 PM #1I have a nissan sentra series 3.. After ko magpaoverhaul lumakas na kumain ng gas.. 4 liters of gasoline ubos agad ng less than an hour.. Nakabukas lang ang makina.. Any idea kung ano problema nito? I need your help guys.. I need your suggestions..
August 10th, 2009 04:07 PM #2
ano engine mo? carb of fuel injected.
pag carb yan you're overfueling, baka hindi maayos alam ko medyo tinotono yan. masama yan sa bagong overhaul, i suggest you bring it to a competent mechanic kung hindi maayos ng nag overhaul (kung hindi nya maayos yan, i'm sure hindi din maayos ang overhaul mo. bye bye bank account).
- Aug 2009
- 7
August 10th, 2009 05:30 PM #4
bro, how did you figure out that it consumes 4 liters in less that an an hour?
August 10th, 2009 05:30 PM #5
woah sobrang lakas yan! ako tumaas idling medyo me problema ako di ko mababa (me post ako) pero nakakaatain parin ako ng 12km/l sobra laklak yan di kaya idling mo nasa 1500rpm na?
August 10th, 2009 05:53 PM #6
Pa check mo kung tama ang timing . tignan mo iyong sunog ng sparkplug mo . Kung maitim hindi masyado nasusunog gasolina . Tignan mo bawat isa spark plug kung hindi maganda sunog . Hindi maganda ang pagkaka overhaul nito.
- Aug 2009
- 7
August 10th, 2009 05:57 PM #7
- Aug 2009
- 7
August 10th, 2009 06:29 PM #8
- Aug 2009
- 7
August 10th, 2009 07:08 PM #9
August 10th, 2009 07:13 PM #10
in my experience, huminto dati yung 4d56 na newly overhauled ko after about 30 minutes on the 1st start after putting the engine back together. the reason wasn't overfueling, but oil starvation (patay! pag tanggal nung top rocker cover tuyong tuyo!).
how's the temp? steady ba? hows the idling? choppy? try loading more fuel, and don't run it at idle so you can break it in. it's a bad idea, because the gas goes nowhere and washes down the bores, preventing the rings from sealing. where do you think all that gas goes to? it's not all going to the compression/ignition process, thats for sure.
your spark plugs turning black is a sign of too much fuel, too little air. either that or its oil fouling the tips. try adjusting the idle mixture until the exhaust doesn't smell like petrol. if its oil fouling you are in for some more bad news, sir.
my top 4 things to check:
1. air/fuel mixture (yes even EFIs have the screw adjuster thingy)
2. gas blowby (see if there's excessive vapor from the oil filler cap while engine is running)
3. timing
4. leaks in the fuel line to the fuel pump (baka maluwag nung kinabit)
4.
most Grab cars are no longer driven by the owner. all Grab cars that I've ridden lately are now...
MG 3 (3rd Gen)
