Results 11 to 12 of 12
- Aug 2009
- 7
August 10th, 2009 07:39 PM #11sir steady naman po ang temp but the idle kusa siya tumataas baba.. Hindi stable ang minor niya..
Sir saan ko makikita yung idle mixture?
Yung EFI ba dun pumapasok yung hangin? Kasi my kinalikot yung mikaniko doon after noon hindi na ngstable yung idle niya..
Salamat sir..
August 10th, 2009 10:21 PM #12
uh, EFI is a system.
i suggest you drive na lang to the nearest gas station, put 500 in the tank and be done with it. that should last you 8 hours of idle time.
check the vacuum hoses, baka may nahugot. check also the idle up switch/solenoid.
bakit hindi mapa-tino ng mechanico mo yan? he should give that to you idling and running perfectly. pag hindi nya kinaya dalhin mo na lang sa casa, wag mo na sabihin na pinaoverhaul mo. kamo na lang may problema yata sa idle. hindi tayo matatapos kung lecture ka namin sa workings ng engine mo while at the same time tinotroubleshoot yung problema based on your descriptions.
kung ako yan sinapak ko na yung mekaniko. simpleng idle hindi maayos, after ibinaba yung makina, sus... at ikaw pa namomroblema ngayon.
see my pahabol statement above. i mean, i can go on vacation anytime. but my spouse has her...
Traffic!
