Mga sir, ano kaya possible cause pag niliko ko ng pakanan minsan may tumutunog sa ilalim? last month nagpa greasing ako. Thank you
Pacheck mo mga ball joints, idler arm, pitman arm at bushings. Baka din maluwag ang bearing. Mahahanap yan ng matinong mekaniko. Ipapaikot-ikot niya lang manibela sa iyo. Yung iba ginagamit mahabang bakal para itutok sa mga usual na joints, tutunog talaga yan if may problema.
Hi guys,
do you happen to know an updated list of reputable pajero service center/autoshop where i can have my Pajero FM 1999 model repaired. it's been sitting in our garage for quite sometime now. From what i remember, i stopped using the car due to the ff problems:
1. Always discharging if not started within a day.
2. Loose compression and it's smoke belching already.
3. Aircon(which is already bad for this particular model haha) is always breaking down for some reason.
Anyone kind enough to share their opinions? Thanks in advance!
Hi,
Newbie here and I hope anybody can help.
I saw a Pajero for sale in one of the Buy and Sell FB groups in my area:
Says it's 2004 AT 4x4 3.2L 4m41
ODO at 160k+
Selling at 650k
I hope I can get feedback from here before engaging the seller..
Is this too good to be true?
TIA!
Ask if converted, mukhang converted at surplus.
aio....
Sent from my mobile phone using Tapatalk
Hello masters,
Ilang liters of ATF ang kailangan for Pajero Fieldmaster? Drain and clean filter po kasi ang gagawin. Not sure id ilan.
Thanks
Sent from my ONEPLUS A5010 using Tapatalk
nag kamali ako dati sa gear ratio. palit whole diff with lsd ginawa ko dati. iba pala yung ration sa harap. kaya binalik ko oem pinion and ring gear. yung lsd lang ang nilipat pala dapat. ngayon ok na uli 4x4 ko![]()
nelany, di mo. magagamit 4x4 pag di same ang gear ratio.
high gear yung nabili ko dati na rear diff. mas mabilis takbo ko kaysa sa speedometer ng mga 10 percent. mas ok si high gear sa expressway cruising Mas mababa rpm![]()
Di naman po sirgoing to bagyo 8 pax no problem naman
Mga sir,
May nakapag try na ba ng akebono brakes from lazada? Ang mura kasi compared sa casa na 3-4k ang isa.
Mga paps, warning light came up in the dashboard. Comment naman kung ano possible error and where to fix. Have not used my pajero for 7 days, biglang umilaw kanina.
