Page 7 of 718 FirstFirst ... 345678910111757107 ... LastLast
Results 121 to 140 of 14348
    Mar 2003
    #121
    nelany, easy lang yan pare .
    remove intercooler
    disconnect positive side battery terminal
    remove bus bar ng GP, ito yung metal na nagdidikit sa 4 GP.
    tester mo isa isa yung GP, dapat may continuity yung body and top ng GP. pwede rin set sa resistance, mine reads 1.5 ohm per GP, dapat same sila lahat. yung natest ko na bnew na hkt pm -165 1 ohm siya.
    May 2008
    #122
    reep, bakit mo kailangan palinis turbo?
    Actually hindi naman siya broken or something. Feel ko lang parang ang bagal niya (or nasanay lang ako sa CRDi performance). And besides 10y/o++ na yung unit.
    #123
    remove intercooler
    PB, TY. I check ko nalang pag me naramdaman akong kakaiba sa pag start niya.
    Mar 2003
    #124
    reep, baka mas makatulong yung paglinis ng intercooler sa pagpapabilis, kasi mas lalamig hangin, yung turbo oil lang naman ang nakakalat diyan, hindi siya gaano makaka affect sa performance, unless may sira ang turbo, yun nga lang yung oil pag binalik sa manifold, itim na usok lalabas.
    totoong totoo yan, pag hawak mo bagong diesel, minsan nakakawawa ko pajero ko sa kakapiga.
    #125
    Quote Originally Posted by jacorb_88 View Post
    sayang yung DIY mo, it came in not so good timing...
    http://www.gmanews.tv/largevideo/lat...rs-also-banned
    ingat na lang baka harangin ka.
    lagyan mo nalng ng cover.
    May 2008
    #126
    Sige try ko muna sir. Gasoline lang talaga pwede pang linis diyan?
    Mar 2003
    #127
    reep, kerosene siguro pwede rin, or brake cleaner kaso mas mahal.
    kakapalit ko lang pala new battery, 4,800 less 300 trade in. 3smf na motolite excel, ganda ng sound ng starter pag new battery. ang bilis ng redondo.
    Jul 2010
    #128
    hi guys im somewhat new to this thread. i own a 2003 fieldmaster and i need your help in finding the best place to buy replacement tires for the fieldmaster.
    any suggestions of where to buy would be greatly appreciated. thanks!
    Jul 2010
    #129
    woops 1999 fieldmaster pala, 2003 was the purchase date. sorry mali.
    #130
    Sir PB gusto ko rin diy pagtanggal ng dashboard. Na try ko dati pero di ko tinuloy para kasing may kulang ako na di natanggal. Correct me if Im wrong, may dalawa bolt from each side, sa ilalim at sa vent, & 1 sa center, a total of five. Meron pa ba I have miss.
    #131
    [quote=promdiboy;1534047]monty, I think pwede makalas, tanggalin mo lang blower motor behind the glove compartment. pag tanggalin mo yung stopper ng glove compartment machecheck mo na siya kung durog na yung foam.
    heto bro may pic ako dati, yung nasa passenger side na may white square na grill, pag ginalaw mo recirculate lever gagalaw yung doors, dapat both sides may foam yung doors. 2 doors with 4 faces.
    PB, maraming salamat. Subukan ko ito this weekend. Salamat din sa photo. Parang may photo file ka ng mga DIY mo.
    Mar 2003
    #132
    vlackhole, cant remeber exactly kung ilang screws, hindi naman siya mahirap hanapin. parang naalala ko meron sa ilalim pa dalawa sa gilid ng aircon controls. before dash kalas mo muna ilalim ng driver and passenger side, yung sa pillars, instrument panel, multimeter, radio and aircon controls. pati yata center console may screw rin yata sa ilalim. ang pinaka mahirap diyan yung cables ng aircon controls ang tigas niya tanggalin at ibalik. wag ka matakot, madali lang siya once nasimulan mo na, magisa ko lang siya ginawa, nagpatulong lang ako nung nilalalabas na yung buong dash sa kotse, sumasabit kasi sa steering wheel.
    #133
    Thanks PB. Tingin ko nga ung dalawa na sinasabi mo sa gilid ng aircon ang na miss ko. Try ko ulit pag may long weekend.
    Aug 2007
    #134
    Magandang Araw Paj people!
    Need to replace my front rotor disk, ano ba maganda replacement maliban sa OEM.
    maraming salamat po!
    Mar 2003
    #135
    ikawngaba, may nag offer saakin dati ng performance part na rotors, cross drilled siya, forgot the brand, pag naalala ko post ko . 7k each
    #136
    Sir PB, di ba nag palit ka na ng ATF filter? yun ba yung pag binili is parang square(with diagonal cut sa lower corner ) plate ng me filter sa loob at me kasamang Gasket na around 12-13 inches ang sides? I asked aroud sa suki kong suto supply and iyon ang pinakita nila sa kin na filter ng ATF. Yun ba yun?
    #137
    if im correct, rectangular sir yung para sa FM natin... tapos may screen sa opposite side... para siyang "cylinderhead gasket" na may screen at covering.hehe.hirap ng walang pic!hehe
    mga 800 to 900 pesos ata sa casa ang bago... nagpalit ako nyan 1 year ago.
    #138
    Quote Originally Posted by junerski View Post
    Yun nga yung pinakita sa kin, nasa 600 pesos ang offer nila sakin. Although di sya japan, asian country mada daw. Guess I'll have to bring a sample to be sure. Thanks sir junerski
    Jun 2004
    #139
    there's this weird sound on my FM.
    pag umaandar kahit between 20-40kph lang, meron biglang "woooooooooooo" na malakas.
    ok naman belts ko, ok 2 aux fans. biglang nawawala pag binubuksan ko na hood, di ko matsempuhan.
    hmmm..bearings? timing chain?
    Mar 2003
    #140
    BG, same ba AT ng FM and imported?
    archi, more details, afaik bearing, pag jinack mo, ikutin mo kung may maririnig ka, or alog mo gulong left to right. timing chain from what i read is tunog sayad "chaf chaf chaf" putol putol na sound. cant imagine yung woooo sound, but power steering pag walang fluid ganyan tunog, sabay nga lang sa steering.
Mitsubishi Pajero Fieldmaster (Gen 2.5) [continued]
