guys, anyone tried to remove the backdoor handle? nasaan ang unmounting screw non? Do I have to remove the door sidings first?
magandang araw sa lahat!
Yung pajero j-top (gen 2, 4d56 tdic 4x4 manual) ko po walang diagram sa main fuse box, tapos japanese markings naman ang nakalagay sa fuse box sa loob. Patulong naman po saan pwede mag download nito, or baka pwede din pa post ng pictures.
Nakabili na pala ako ng maxxis bravo a/t (265/70/16) made in thailand * 5.6k each.
Alignment and camber at servitek marcos hway and alpha performance is * 1,150
wheel balancing 105 each, wheel weights 15 pesos/piece
Heto naman ang quotations sa akin ng ibang gulong (marikina area).
Desert Hawk (indonesia) * 5.3k
Bridgestone dueller h/t * 6.3 to 6.8k; a/t * 7 to 7.5k
Yokohama 6051 * 6.0k
Dunlop * 6.4k
Kumho road venture * 5.3k
General Grabber a/t * 4.5k
Duro * 4.8k
Here's what I did: (1) tinanggal ko yong panel sa taas, merong 2 screws sa 3rd break light, and 2 screws sa interior handle (hidden siya kasi merong cover), then (2) yong panel sa baba, 4 screws sa toll box, and 1 screw sa handle when you open from the inside (not sure of the term). Just slowly pull each panel until matanggal.
If you're not the type na magdiy, I think Php 100 - 300 is reasonable labor if done sa mechanic.
Alright thanks.. after removing screws, im assuming puro clips na lang na i can safely pull-out the sidings. DIY ko na lang yun. thanks.
The plate holder lamp can also be fixed through removing the handle diba? though merong 2 screws directly under the plate holder, pero upon removing it, parang sa cover lang yun ng lamp.
[quote=ka david;1530431]magandang araw sa lahat!
Ka David,
Eto ang fuse diagram courtesy of Promdiboy.
Monty
Ka David,
Nasa page 281 iyong fuse diagram. Punta ka sa archived section.
Monty
sayang yung DIY mo, it came in not so good timing...
http://www.gmanews.tv/largevideo/lat...rs-also-banned
ingat na lang baka harangin ka.
re: fusebox diagram
* blue_gambit - yup, ganyan na ganyan yung fusebox, hindi ko maintindihan
kung ano yung designated parts/circuits nung mga fuse..
* monty - ayun! thanks! kopyahin ko nalang for reference![]()
eto translation paps as per my japanese seller:
phpto1 cover only.
VO spare spare
10A (rear heater) 15A (door lock) 20A (dual aircon)
15A ACC socket 10A 4WD 10A 4speed automatic
20A (sun roof) 10A (power windw) 10A heater rilay
25A heater 15A wiper 10A radio
15A stop 10A horm 15A cigar
15A back up 10A meter
10A clock,room 10A turn up rilay
&nbs p; ACC
&nbs p; heater
Adjust mo na lang alignment pero basically yan yun
thanks sir monty
thanks sir jacorb for warning.. hehe
sana wala manghuli.. hehe so far... wala pa naman humaharang sakin.. and if meron man humarang.. ok lang.. since its still not working po.. hehe
monty, I think pwede makalas, tanggalin mo lang blower motor behind the glove compartment. pag tanggalin mo yung stopper ng glove compartment machecheck mo na siya kung durog na yung foam.
heto bro may pic ako dati, yung nasa passenger side na may white square na grill, pag ginalaw mo recirculate lever gagalaw yung doors, dapat both sides may foam yung doors. 2 doors with 4 faces.
weekend DIY ko, share ko lang, nilinis ko yung internals ng intercooler ko, nilagyan ko ng 1 liter of gasoline then inalog alog ko, swing ko siya from left to right hanggang mapagod ako, nakakatuwa gawin to, trust menung pumasok yung gas clear blue siya, ayun pag labas parang coke, nung pag kabalik ko di ko muna kinabit yung hose papasok sa intake manifold para mabugahan at matuyo ng todo yung loob,.
nung nakalas ko intercooler I also tested my glowplugs, buhay pa lahat,5 years and still going, also had my emission test, .5 score ko. not bad :grin
PB, do I need a specialist for cleaning the turbo. I'm bringing in my FM to our trusted mechanic to replace engine supports. Hopefully sabay ko na rin palinis yung turbo since my unit doesn't have an oil catch can.![]()
PB ang dumi ng loob ng intercooler! Ganyan na rin siguro kadumi yung sa akin.
Tapos na ikalibrate yung sa akin sa Central diesel. Butas yung bulsa pero ok na at one start nalang using yung autostart function ng alarm.
Papano pala icheck yung glow plug? Want to see kung gaano katagal yung sa akin before I replace it again.![]()
