Page 631 of 718 FirstFirst ... 531581621627628629630631632633634635641681 ... LastLast
Results 12,601 to 12,620 of 14348
    Jun 2015
    #12601
    Hi to All pajero owners, im new here sa tsikot.com
    I just want to share my problem re: Brandnew Pajero model 2015 na binili ng father ko last Dec 19, 2015. Palaging drain yung battery ng pajero for no reason. 5x na nmin sya dinala sa dealer for repair pero until now andun parin yung issue. Tntry nmin mag ask ng replacement ng unit pero nag refuse ang dealer. As owner kc ng brandnew
    Jun 2015
    #12602
    I just want to share my problem re: Brandnew Pajero model 2015 na binili ng father ko last Dec 19, 2014. Palaging drain yung battery ng pajero for no reason. 5x na nmin sya dinala sa dealer for repair pero until now andun parin yung issue. Tntry nmin mag ask ng replacement ng unit pero nag refuse ang dealer. As owner kc ng isang brandnew car ndi kc nkaka happy ung xperience nmin cmula nung nabili nmin yung unit eh halos every month nsa dealer for repair. Bka nmn pwede nyo ako matulungan, here is my number 09178354598
    Okay kaya ito?
    P4,600 per piece bigay sa akin eh.
    #12604
    Quote Originally Posted by gdelu View Post
    Sir, bawal po text speak dito sa tsikot. Pwede kayong ma-ban nang wala sa oras.
    Regarding your problem, try nalang ninyo humingi ng bagong battery. Baka defective agad yun battery na nakakabit sa sasakyan ninyo.
    Also, may dedicated po na thread para sa Pajero ninyo dahil pasok yan sa Gen 3. Punta lang kayo dito at mas madami kang matutunan dito
    http://tsikot.com/forums/mitsubishi-...nued%5D-73530/
    Jun 2015
    #12605
    Good day sirs,
    2003 FM owner po ako. Im new here sa forum pero two weeks na din ako nagbabasa ng thread na to. I started reading from the first page and i've learned a lot from you guys. Pag may topic na interesting i make a screenshot for my reference and if i have time i note it down. Now i know ano magandang brands, saan pwede mag source ng parts at trusted shops/mechanic.
    Im still out of the country right now and i already made a list of things to do on my rig since its almost 80K kms.
    Here are my plans:
    1. Change oil,oil filter,fuel filter,air filter
    2. Pull down AT oil pan, change filter and gasket
    3. Change power steering fluid and check for leaks in the hoses
    4. Change brake fluid and check brake pads
    5. Change coolant
    6. Change differential oil
    7. Greasing of joints
    As of now medyo mahaba na yung list ko for maintenance sa susunod na yung upgrades. 😆
    Baka may input pa kayo mga sir welcome na welcome po sakin. Thanks in advance. More power to our beloved pajero. 😊
    Quote Originally Posted by king333 View Post
    Good day sirs,
    Here are my plans:
    5. Change coolant
    Twice a week dapat pinapaadar kahit 5 mins lang yung pajero. Tapos atras abante din sana kung hindi nagagamit. Para mag-circulate ang oils sa transmission at sa differential gears. Pati electronics dapat nagagamit din para hindi masira agad lalo na kung bihira magamit.
    Jun 2015
    #12607
    Yun nga po sir eh last week lang na-stock na yung antenna nakataas ayaw na bumaba. Tignan ko nalang paguwi ko baka kaya ng DIY. Nagagamit naman po sya regularly sadyang mababa lang mileage dahil may alternate na sasakyan. Thanks for the info sir RT.
    Nakuw, mahirap baklasin yan. Try mo muna patuluan nang wd40 baka makuha sa ganun. If hindi, matrabaho ayusin yan.
    Dec 2013
    #12609
    Mga sir bigyan ko lang kayo update regarding sa FM ko yung rattling problem. Ang culprit ay rocker arm. Nung na adjust wala na yung ingay tapos ganda pa ng takbo tumining ng makina at gumanda ang hatak. Natuwa talaga ko nung naayos. Grabe halos lahat na kasi pinalitan ko.
    Aug 2007
    #12610
    Ayos sir! Enjoy ur ride
    Apr 2015
    #12611
    Quote Originally Posted by pajero02 View Post
    Nice sir. Buti naman naayos na.valve clearance?
    Aug 2009
    #12612
    Will there be any prescribed pm for those valve clearance adjustment pls.?
    Quote Originally Posted by 9701 View Post
    You mean standard schedule when it should be performed? Afaik dapat sa heavy maintenance yan or every 20,000kms ata sa 4d56 na engine. 4m40 self-adjusting kasi.
    Dec 2013
    #12614
    sir anong ibig sabihin nyo na self-adjusting?
    Aug 2009
    #12615
    Thanks Sir RT. Mine is 4M40 so relief sigh hehehe since its self-adjusting.
    Dec 2013
    #12616
    sir ibig sabihin ba nito hinde kelangan ng adjustment ng rocker arm ng 4M40? Bakit yung sakin inudjust?
    Yung Valve-clearance pala self-adjusting. Maybe the rocker-arm can be adjuted. Do you have the right specs for the adjustment made in your pajero?
    http://tsikot.com/forums/other-troub...ustment-13945/
    Apr 2015
    #12618
    Mga sir good day, ilang psi nilalagay nyo sa gulong nyo? Stock rims paj 2nd gen
    Quote Originally Posted by paulomik View Post
    28 frnt 30 rear
    Apr 2015
    #12620
    Nagtataka lang ako kasi nakalagay sa door jamb parang 40psi dapat ilagay pag naka stock tires. Kaya ang nilalagay ko 38 front and rear. Masyado ba matigas?
Mitsubishi Pajero Fieldmaster (Gen 2.5) [continued]
