Check your turbo and intercooler pipes for leaks. May oil catch can ka ba?
Check your fuel filter. Kapag may maitim na parang soft sludge, check your fuel tank. Drain ka kunti at baka medyo grayish na diesel fuel mo. Baka tumatagas na engine oil sa injection pump. Soon hard starting and stalling problem na.
IP rebuild dapat gawin.
sir kaka rebuild lang ng IP ko, kasi naranasan ko yan pag ka start makatakbo ka ng ilang meters biglang mag stall tapos hard start. Pero ngayon wala na problema na yun. Yung Turbo ko naman sir kakabili ko lang this month nag palit ako bnew. Wala ako catch can.
sirs, may i ask your advice about this? my OCI for my 14- yr old FM is every 3 months or every 4 kms. i'm using delo gold 400 and baldwin oil filter. i'm using baldwin fuel filter too and replace it every 6 months. i replace bosch air filter every 6 months also. is this alright? i appreciate highly your advice. thank you very much.
Replace every 15,000kms max. Better open the fuel filter on its 10,000kms mark to check visually muna if kaya pa nga or hindi na. If mukhang kalahati pa lang dirt, kaya 15K. I did 15K on a bosch but minsan lang, dami dumi eh. Back t 10,000kms change for the FF.
6months or 5,000kms If I were you for the Delo 400 and Baldwin filter. Baldwin FF you can go 10,000kms safely. Air filter check mo muna if kaya pa naman 1year. Masyado maaga 6 months imho.
Mga boss sorry sa question hirap na mag backread. Meron ba way or solution na hindi masyado maingay yung interior? I mean mejo maingay kasi yung mga upuan pag nalulubak. Thanks mga bossing
Sent from my GT-I9300 using Tapatalk
Mga bossing magandang araw po bago lang po ako dito saan po ba nakakapag parepair ng instruments ng FM na ganito? Sa banawe po ba nagrerepair?
Bukas din po magpapapalit ako ng mga oil para FM 2000 na 114K clock. engine oil, steering, atf, 4x4 oil ska mga filter, saan po ba maganda magpapalit na reasonable price. Taga rizal po ako. Thanks in advance :-)
Mga sirs,
Confirm ko lang po. Comparison of local Pajeros vs converted Subic Pajeros. Mas ok po ang local kaysa converted? And why po?
Pansin ko kasi mas mura ang converted vs local.
Thank you sa sasagot.
Mga sirs,
kung ok pagka convert o conversion kit yung gamit sa tingin ko wala namang problema
