Page 587 of 718 FirstFirst ... 487537577583584585586587588589590591597637687 ... LastLast
Results 11,721 to 11,740 of 14348
    May 2009
    #11721
    Ano pa kaya ang possible na causes ng blinking AT aside sa tps, dirty atf at speed sensor?
    Sep 2014
    #11722
    Quote Originally Posted by pajero02 View Post
    Sir eto ba yung nasa 15th ave sa cubao?
    Sa marikina po ako nag papagawa. Reys electrical din po yung sa cubao same lng po yata ng owner.
    Feb 2014
    #11723
    Sir alani, sa reys marikina ho ako nagpatingin nung sinabi wala raw problema. Naka tsempo lang siguro ako ng tinatamad na electrician haha ibalik ko nalang ulit
    May 2009
    #11724
    Solved na problem ko mga sir nag palit lang ulit ako atf. Thanks guys di na nagblink AT ko
    #11725
    Quote Originally Posted by kilo18 View Post
    Newbie here mga sir, same problem din po sa fm ko blingking A/T 2 front wheel blingking din tpos parang ang bgat ng gas pedal hirap mag accelerate pero pag tumatakbo naman ok nman sya nag sshift kaya lng parang hindi normal talaga.Need ur help guys.TIA!
    Pag blinking yun 2 front tires, meaning may problema sa actuators ng 4wd mo. Ang pwede mo gawin sir, bili ka electronic contact cleaner tapos linisan mo yun mga actuators. IIRC, meron ito sa lumang thread ng Pajero
    #11726
    Sirs, newbie here but I've been back reading a lot lately and I learned many things. I'd like to ask you about this sound coming from the evaporator located underneath the dash. it is like a fan turning. it will come out when I'll turn the ignition off from driving and it will come out again as I turn the ignition on. I hope you can help me. thank you very much.
    #11727
    Quote Originally Posted by Juan Martinez View Post
    Maybe its the intercooler fan.. try looking at it at the bottom of the intercooler.. I know you are referring to a different location but just a hunch.. because yan lang naisip ko na tutunog in that given scenario not unless naka-on blower mo ng a/c
    Sep 2014
    #11728
    Quote Originally Posted by specialtikoy View Post
    Hanapin nyo po si nanie.
    #11729
    Sir junerski thank you. it couldn't be the blower because that sound come out also even before I actually start or crank the engine but the key is already turned "on".
    Feb 2014
    #11730
    Napalinis ko na EGR sir at napablank. cost me 600 pesos. ngpalinis na din ako ng atf pan. sarap ng takbo ngayon hehehe
    Both cleaning and rebuild siguro ... :D
    matagal na naka blank egr ko.. ;)
    next is intake cleaning and washer mod .. hehehe
    #11731
    Juan Martinez, Junerski is correct. That's most likely the intercooler fan since you said that you had the key switch on "on" but without cranking and this is after you have driven the car; the intercooler fan is temperature /heat activated.
    #11732
    Sir Monty thank you. But is it perfectly alright for the intercooler to activate or is it a sign of a deeper, bigger problem? anyway, my rig is a 4x2 2001 FM. thank you again.
    #11733
    This is normal and a sign that your intercooler fan is working.
    #11734
    Ah ok. thanks a lot
    May 2010
    #11735
    Repost ko lang po busina concern ko:
    From cold start, wala po akong busina..
    Dati After 15-30mins, or upon half temp siya nagkakaroon ng busina..
    Ngayon it would take 30-40mins warming bago ako magkabusina..
    Once maging ok na busina, ayos na sya all trip.. Mawawala lang ulit pag lumamig makina.. Ano kaya problema?
    Please help! tia..
    #11736
    Na-check mo na ba wiring ng busina mo sir kung ok pa o hindi? Tsaka nagpalit ka na ba ng busina o yun stock pa rin?
    Feb 2014
    #11737
    guys pano magpalit ng power steering fluid?
    May 2010
    #11738
    Nagpalit na ako ng busina, mga 2years ago.. Hella pinalit ko..
    Dec 2011
    #11739
    Mga bossing,
    Saan kaya pwedeng makabili ng crankshaft position sensor para sa Pajero 4m40 engine,
    nasira kasi yung sa akin at walang mabilhan dito sa probinsya.
    Thanks!
    Dec 2011
    #11740
    Mga bossing,
    Thanks!
Mitsubishi Pajero Fieldmaster (Gen 2.5) [continued]
