Page 467 of 718 FirstFirst ... 367417457463464465466467468469470471477517567 ... LastLast
Results 9,321 to 9,340 of 14348
    #9321
    Monty with the engine noise in the FM as well as road noise you can get from our tyres, a little but of sound deadening mat goes a long way.
    #9322
    Thanks, KILL. Sige, isabay ko na lang pag install ng speakers.
    Quote Originally Posted by K.I.L.L. View Post
    #9323
    Himabol sa pasko, dalawang aux fan na bumigay. Need to change with an original denso.
    #9324
    How much score mo sa orig sir?
    Sent from my GT-I9300 using Tsikot Forums Mobile App mobile app
    #9325
    4.8K yung malaki at 3.8K yung maliit. 9K lahat kasama yung na installation dyan sa RAE auto electrical sa Marikina.
    #9326
    Sir Nelany eto na po pala ang upgraded headlight ko.... :D
    #9327
    I feel you nelany. Ako rin, sumabay pa ngayon yun sasakyan ko. Brake pads naman dinali. Silat ang 7k :um:
    #9328
    Hehehe pareho lang tayo, just replaced yung brake pad ko sa likod at nag renew ng brake fluid.Ngayon lang ako nag karoon ng time ulit. Feel mo yung difference ng bagong pad at ng bagong fluid.
    #9329
    BG, ganda. DIY yan lahat? Magkano gastos mo?
    #9330
    Thanks Sir, D.I.Y. install + parts 6K din inabot
    Kamusta yang Remsa pads, tahimik ba sir? How much?
    Dec 2013
    #9331
    Share ko lang mga sir para may reference ang iba. Replaced my alternator belts and a/c belt, air filter, right side na peanut bulb yung sa park light, water reservoir cap, nag pa flush rin ako radiator and refill new coolant. 2385 lahat nag patawad ng onti 2300 na lang sa motorix sa banawe.
    #9332
    Oo ramdam ko yun bagong brake pads. OEM pinalit ko at nagpalit ako ng brake pads sa lahat ng gulong. Compared sa Bendix, medyo mahina ang OEM/Akebono pero ang tahimik! Di na ko nagpalit ng brake fluid kasi last month lang eh nagpa-flush ako ng fluid ke Wheelers. Bleeding at top up lang ginawa.
    #9333
    KILL, may I ask, how's your Mastercraft? I am seeing worst on mine. Sobra bilis ng deterioration niya. I'm seeing some cracks and chippings already. Also noticed that the date of production is 4410, means 44th week of 2010. I now have a 3 year old tire pero last year ko lang nabili. I am not expecting this kind of deterioration so much on a 3 year old tire.
    I am so itching to replace them by next year lalo na the gf gave me a go signal :diablo:
    #9334
    Malaking mura kung 6K lang gastos mo. Nag babalak akong mag pa retrofit kay gary ng stage 3 per wala pang budget.
    Sa labas ko binili yung remsa pad. Yung dating nakalagay ay bendix kaya lang ma ingay siya. Combination ng akebono yung harap at remsa (akebono/remsa) yung likod at totally walang ingay. Pag na pudpod yung harap palitan ko na rin ng remsa pad (spare ko). Mas malakas ang kapit nung bagong pad as compared sa dati na akebono/bendix ang tandem.
    #9335
    Ang bilis naman yan mag deteriorate. Yung Cooper tire ang thread wear warranty ay 55, 000 miles para sa AT3.
    Tread Wear Protection
    The following Tread Wear Warranty is a prorated warranty (there is no free replacement period) based on mileage received, and is separate from the Standard Coverage & Extra Coverage Warranties just covered. No manufacturer or retailer can guarantee you a certain number of miles from a given tire. Driving habits, driving conditions, tire and vehicle maintenance all play a part in the tread life of a tire and all differ with each purchaser. The following replacement Cooper radial tires only are warranted against tread wear out prior to the applicable indicated mileage:
    CS4 Touring (T rated)..........................................80 ,000 miles
    Discoverer CTS (T/H rated)................................70,000 miles
    Lifeliner GLS (T rated).........................................65, 000 miles
    CS4 Touring (H/V rated)......................................60,000 miles
    Discoverer H/T................................................. .....60,000 miles*
    GFE............................................... ..........................60,000 miles
    Discoverer A/T3................................................ ....55,000 miles*
    Cobra G/T................................................. .............50,000 miles
    Lifeliner GLS (H/V rated).....................................50,000 miles
    Trendsetter SE................................................ .....40,000 miles
    Cooper Zeon RS3-A............................................40,00 0 miles/20,000 miles**
    Cooper Zeon RS3-S............................................20,00 0 miles/10,000 miles**
    #9336
    Yun nga. Considering 3 years palang yun gulong at nasa less than 30k kms palang natatakbo eh nagchi-chip na siya at ang bilis mapudpod. Kaya papapalitan ko na ito next year at di ko na patatagalin habang may tread pa at pwede pang ma-trade in.
    #9337
    Boss saan ka nakabili ng Akebono pads? medyo me ingay na rin kasi yung Bendix ko... plan ko palitan na rin pag di makuha ng linis.. Magkano bili mo sa Kanila?
    Malambot siguro ang Tire compound ng Master Craft kaya mabilis mag deteriorate... ? Sa Hankook 3 years na saken ayus pa rin.
    #9338
    I'm travelling later to Manila. I'll take a look at my tyres tomorrow morning and let you know. Where did you buy yours? They should have given you new stock or given you a hefty discount for selling old stock. I heard from some friends that the best budget tyres are Savero GTs.
    #9339
    Naka Savero GT yung kumpare ko... ok daw yung wear, prob daw is maingay lalo na on hi-way
    Best budget tire nga IMHO ang Savero GTs AT. Thread pattern is the same halos with Bstone AT.
Mitsubishi Pajero Fieldmaster (Gen 2.5) [continued]
