Page 450 of 718 FirstFirst ... 350400440446447448449450451452453454460500550 ... LastLast
Results 8,981 to 9,000 of 14348
    #8981
    Nagpafull tank ako kagabi sa Seaoil. Mukhang improving FC ko. 30% highway, 70% city driving, with hataw runs FC is 6.67km/L.
    #8982
    Jul 2013
    #8983
    *blue_gambit
    Sir anong 6 spokes po un tinutukoy niyo? Di ko kayo ma message.
    #8984
    Quote Originally Posted by zairus View Post
    *blue_gambit
    Huh ako? Me pm ba ko? Di ko matandaan bro... hehehe
    Malamang puno na inbox and sent mgs mo. Delete ka
    Sent from my GT-I9300 using Tsikot Car Forums mobile app
    Jul 2013
    #8985
    *blue_gambit
    Ako po dapat mag message, nabasa ko po kasi nabanggit niyo un 6 spokes. Baka matulungan ko kayo paghanap
    #8986
    Ah, ok na sir. Ayus n ko sa stock ko. Hehehe
    Thanks for the offer
    #8987
    Salamat CB, pinaalala mo sa akin ang nag-iisang bad experience ko sa Speedlab. I have decided to pull out yun plan ko sa kanila. Buti nalang na on the spot nila gagawin yun fabrication. Called Brodeth and researched at ang daming good feedbacks sa kanila. Doon nalang ako pupunta sa Sabado early morning. Kaya naman daw nila tapusin yun fabrication.
    #8988
    Congrats and good luck testa! Hehe full exhaust na yan
    May 2010
    #8989
    Guys, tanong lang. From cold start, i have screeching sound when i accelerate.. Siguro mga 50-300meters from parking, then mawawala.. If i warm my fm for 10-15mins before acceleration, wala na yun screeching sound.. Ano kaya yun? Fan belt problems?
    Salamat in advance..
    Sent from my iPhone using Tsikot Car Forums
    Quote Originally Posted by romeocharlie View Post
    Pa-check mo nga mga belts mo.
    Sent from my Lenovo using Tapatalk 2
    #8991
    Most likely belt yan, either fan or aircon. Check mo lang yun tension kung ok pa. Kung matagal na yun belts mo, papalitan mo na yan
    #8992
    I recently had an experience similar to Testament's. I was driving to megamall on Edsa when I noticed that my a/c seems to have lost its coolness. I checked my gauges and my temeprature was slowly but surely climbing. I immediately turned off my a/c and slowed down and turned right into Pioneer then started looking for a place where I can get it looked at. As it was a Sunday, I wasn't very optimistic that there would be garages that would be open. I was able to chance upon a Petron that had a service area. I just barely made it as my temperture was getting really high. Upon opening my bonnet, there was a loud hissing sound. They dismantled the intercooler and we all saw that my hose had ruptured and after checking, it seemed to be the only problem. Luckily, there was an auto parts shop called Archie's on Shaw that was open so I was able to get a new hose, clamps and whiz coolant from them. Funnily enough, they had one last OEM hose left. Petron installed it, filled up my tank with the coolant mixed with distilled water and went on my merry way. Whew!
    Jan 2011
    #8993
    Whew talaga sir! Hehe
    Ask pala ako mga sir kung ok lang ba mag change oil diretso to top1 sdo from regular oil?
    Thanks!
    #8994
    Baka maging tunong syento bente na sasakyan ko pag ginawa ko yan. Syento tunog, bente takbo, wag naman
    Quote Originally Posted by K.I.L.L. View Post
    Oh, lucky you that you got an OEM hose and that your problem was only a busted hose. Unlike mine wherein my thermostat got busted in the middle of heavy rain.
    Hmmmm, 20 years na rin yun JDM ko. I should start looking for a new radiator. Saan ba may mabibiling full aluminum radiator at magkano bentahan nito ngayon?
    Tsaka, anong magandang brand ng pulley tensioner ang maganda? Ok lang sana kung mababaklas ko yun bearing para yun lang papalitan ko, kaso ang hirap baklasin. Nung bumili kasi ako dati, sabi yun sa 4M40 at sa FX pareho lang daw.
    #8995
    Quote Originally Posted by tata_ismael View Post
    Thanks!
    Oo ok lang. Pero kung OC ka konti o para lang maging safe, pa-flush mo nalang.
    #8996
    full aluminum as in same sa mga ginagamit sa mga race cars? tanongin mo si joseph kung meron ba siya. sa HK nakakita ako last time.
    #8997
    Yep. Meron bang ganun para sa atin? May nabasa ako dito na nasa 8k daw nakuha nung isang tsiktoeer sa Kaiser. Hmmmm...
    Advisable lang na full aluminum yung intercooler pipes kapag naka-devilsown right?
    #8999
    Nope. Kahit di ka naman naka-Devilsown, pwede naman naka aluminum pipes ka.
    #9000
    If 8k, mura yan. Kasi replacement plastic top aluminum core rad nasa 12k up na e.
    Pero meron full aluminum para sa 4m40.
Mitsubishi Pajero Fieldmaster (Gen 2.5) [continued]
