Hi Promdiboy,
I just used my trusty dremel to do the dirty work. DIY lang po. Kung di po kayo masyado sanay, I suggest having a banawe boy install it.
In any case, the hardest part of it all is cutting the holes in the bumper extension. You may use my 'bangga' pic as reference to where the hole should be cut. Di ko lang sure saan mo lalagay yung additional 2 sensorsHere's what i can remember about my install.
1) I mounted the central unit beneath my cd changer. under the carpet. So if youre looking at the Paj from behind, it should be at the right side.
2) the wires from the sensors, i think i had to remove the right taillight and pass the wires through there. Pinagapang ko lang underneath the weather seal (rubber grommet).
3) connected the sensor wires to the central unit.
4) gapang the wires from the central unit to the indicator. The indicator was mounted in the blank space with a circular cap on the bottom plastic shield covering the underside of the steering column (labo no?)
Basta, look for a circular plastic 'cap' remove it and mount the indicator there. Im not sure what a 4 sensor indicator looks like though. Baka hindi kasya. If that's the case, you simply have to find another spot for this.
I recall, i had to file down my indicator to make it fit. But the location I selected was perfect (for me at least). It's clearly viewable at most any position.
I'll get some pics over the weekend to help you out.
RC tayo! hehehe
![Google Play Mitsubishi Pajero Fieldmaster (Gen 2.5) [ARCHIVED]](https://play.google.com/intl/en_us/badges/images/generic/en_badge_web_generic.png)
