Results 471 to 480 of 616
July 20th, 2016 11:29 AM #471
For the CSI300, might this be the manual?
Operating the Code Alarm CSI3 Security System
According to the manual,
To turn on the Valet Switch (helpful when getting a carwash or having the car serviced with all doors closed as well):
VALET SWITCH: The valet switch allows you to temporarily bypass all alarm functions, eliminating the need to hand your transmitter to parking attendants or garage mechanics. When the system is in valet mode, all alarm functions are bypassed, however the remote panic feature and remote door locks will remain operational. To use the valet mode, the system must first be disarmed either by using your keychain transmitter, or by operating the manual override sequence.
From the disarmed condition, turn the ignition key to the on position.
Press and hold the valet push-button switch until the dash mounted LED, turns on. The LED will remain on as long as the system is in valet mode.
To return to normal operation, press and release the push button switch any time the ignition is on.
To disable Chirps when locking/unlocking:
ELIMINATING THE NORMAL ARM / DISARM CHIRPS: As explained earlier in the manual, you can eliminate the chirps selectively any time you arm or disarm the system simply by holding the ARM / DISARM button for two seconds. If you find the normal arming and disarming chirps annoying, they can be turned off permanently, eliminating the need to hold the ARM / DISARM button for two seconds. To do this:
Turn the ignition key on then off.
Within 10 seconds, press and release the valet push button switch three times.
If the chirps were on before you started, then you will hear 2 chirps indicating they have been turned off. If the chirps were off before you started, then you will hear one chirp indicating they have been turned on.
Note: Whenever the chirps are bypassed, the 4 chirp intrusion indicator and the 4 chirp defective zone indicator will always operate. Since these are important warnings to you that something has happened, they cannot be eliminated.
- Aug 2014
- 54
July 25th, 2016 08:52 PM #472Hi mga sir.. pahelp naman po sa monty ko. 2013 GLX MT, paglabas ko po sa sasakyan hindi nagauauto lock.. ang nangyayari po armed lang po yung alarm pero hindi nagauauto lock. TIA
Sent from my ZTE B2015 using Tapatalk
- Jul 2013
- 193
August 4th, 2016 10:20 AM #473
- Aug 2016
- 1
August 7th, 2016 10:02 PM #474
- Jul 2016
- 6
August 10th, 2016 09:50 PM #475Hope it helps
[/QUOTE]
May I request for the manual as well?
rcdbyk*yahoo.com
thank you very much,
- Mar 2011
- 161
August 15th, 2016 11:22 PM #476Sir question about monty alarm. Iniwan ng kapatid ko yung monty nya (2012 glsv) problem is tunog ng tunog yung alarm. Nakakaistorbo lalo sa gabi. Ewan ko.kung nagkataon lang pero nagstart yung problem nung tinabi ko sa fort. Anyway may silent mode ba sya? Or may mali ba ako napindot? Hindi ko na lang nilock para hindi magalarm. Hope somebody can help me. Thanks
Sent from my 5038E using Tapatalk
- Oct 2012
- 3
October 3rd, 2016 09:26 AM #477======Pwd din po ba makahingi ng copy ng manual. Nag aalarm din kc palagi. arnold.versoza*gmail.com
Salamat po=====
- Jun 2015
- 2,751
October 3rd, 2016 10:56 AM #478Try nyo ganito while the vehicle is still unlocked: Press the lock button of the remote. Wait for the chirp. After the chirp, press lock again. You should hear 5 consecutive chirps.
That's for disabling the shock sensor. Forced entry of the vehicle will still trigger the alarm.
Tapatalked
- Oct 2012
- 3
October 3rd, 2016 01:06 PM #479Sa mga may alarm manual na ng 2012 MS pasend naman po. arnold.versoza*gmail.com
- Oct 2012
- 3
That's what he actually did. He also retrofitted an eps to his 1970s era beetle. Btw, now...
A/c
