Oo nga e. Naka high na kasi kaya malakas at mataas yung abot ng ilaw. I think around 150 meters yung layo ng poste sa tantiya ko. There were even posts that on highways abot sa fourth lane yung width ng ilaw. Sa Star Tollway abot sa kabilang lane at sa fence yung liwanag though you can see na during LOW beams mababa yung cutoff ng ilaw kaya no blinding sa oncoming vehicle/s...
*J did your Grandis come with HID's as OEM? I like the results and mukhang maliwanag, but currently satisfied naman ako sa buga ng HID's ko although hindi sya naka projector.
Pansin ko na R yung plate mo so I assume sa Central Luzon naka register yung car. Sa selling sites nga may nakikita na akong ilan na converted units ng grandis na katulad ng sa akin
* Retz,
Here's the address of Gary #30 Jennifer St. Vermont Royale Village, Bgy. Mayamot, Antipolo. You can view his website at Home - HIDRetrofit.Net
*rafmac,
Sir by HID I would presume that the latest model of Grandis is already equipped with Xenon bulbs as it's stock am I right? The retrofit setup of the HLs was OEM. Almost the same output as the aftermarket (the FOG lamps) but the bulbs lasts almost twice longer (also costlier) and has better output and intensity. You can also view the website if you would to see the retrofit options of Sir Gary.
The unit was locally bought at Citimotors Bulacan hence the R plate number by the big boss of Viva films which is also the first owner...
*J - yes the newer Grandis units came with the HID's or xenon type of bulbs. If you open the hood you will see a pair of ballasts kaya satisfied ako sa buga since maliwanag naman, but not as bright as yours because pinalitan mo ng projectors while sa unit namin reflector lang.
*Spat - DRL means daylight running lights. Sa US and Europe kasi by law you need to turn on at least your parklights especially kasi foggy sa kanila. So sa kanila once you start your car naka bukas na the park lights. Audi popularized this by using LED bulbs inside the headlamps
DRL=Daylight Running Lights. This is a safety standard in Europe to maximize the visibility of your vehicle. It is commonly stock to Audis and the latest Kia Sportage...
*Raf,
If mine does also have the HID already, hindi na rin siguro ako nagparetrofit. Mahina kasi talaga yung ilaw ng stock na halogen lalo na pag highway driving at gabi...
*spat,
You're welcome bro...
