Page 14 of 44 FirstFirst ... 410111213141516171824 ... LastLast
Results 261 to 280 of 866
    Feb 2011
    #261
    *Spat This is the direct line sa service 721-6727 then mobile ni Bong 0929-7761833
    Aug 2011
    #262
    Thanks.
    Mar 2011
    #263
    Hi Raf!
    Philips XP ba yung ginagamit mong fogs for your Grandis o yung stock pa rin? Good AM!
    Feb 2011
    #264
    *J I still use the stock bulbs sa fog lights ko. Ok naman so far since the purpose of the fogs for me is additional lightinglalo na sa peripheral. Yung XP is what I used sa iba kong car
    Kamusta na pala yung hids mo
    Mar 2011
    #265
    Raf,
    So far so good. Thanks for asking. Maganda at malakas talaga yung output nung pagkaretro ni Sir Gary. My two bosses who saw were convinced that their ride (Monty & CX7) needs to be retrofitted too. Not experienced any harsh reaction from oncoming vehicles dahil adjusted yung cutoff ng ilaw pag naka-low beams so very minimum yung glare.
    Is there a Philips XP for the fogs? Parang masyado na kasing malakas kung pa HID ko pa yung fogs pero parang balewala na rin pag nakalow beams ako. Gusto ko sana maimprove kahit konti hehehe...
    Bad news for me since tumawag yung sister ko and tinatanong kung kelan daw ako papagawa ng spare key (around 5K as I read here) dahil pag nasira daw yung gumagana kong susi, hindi ko siya mapapatakbo. If that happens, papalitan na daw yung buong assembly which would cost more so I guess I really need to have a new duplicate...
    Feb 2011
    #266
    J
    Nawala mo ba the other key? If not your 2 keys should work fine and yung alarm lang ang hindi gagana. I tried using my spare key and it works. Yung alarmlang ang hindi ko mapagana. I don't think you need to change the whole assembly kasi Mitsubishi should have a record of your immobiller chip details based on your car's din so kaya nila magpagawa ng computer cut keys with the chip.
    I remember when I asked for a quote sabi lang is hindi ko na kailangan dalhin yung kotse and the only time I need to bring it is when I pick up the keys to be sure na gumagana the new keys.
    Mar 2011
    #267
    Raf,
    The 2006 model comes with 2 keys only but both have the remote (door open/close) function. As I had the other key checked with casa, the chip is already defective that's why it can do everything except start the engine. As I use the defective key, the engine turns off after a second or two because it is not recognized by the immobilizer...
    Feb 2011
    #268
    Ah ok good luck na lanag dyan. Medyo pricey lang nga
    Nov 2011
    #269
    hi, question lang po, how much a second hand grandis would cost today?
    Model po: 2005
    Mileage: 72.5k km
    Nov 2011
    #270
    Model po: 2005
    Mileage: 72.5k km
    Mar 2011
    #271
    * Raf,
    Thanks...
    *Spider,
    A second hand 2005 Grandis' price starts at around Php 550K. You could compare the actual price at ayosdito...HTH
    Oct 2011
    #272
    Quote Originally Posted by Spiderenan30 View Post
    Model po: 2005
    Mileage: 72.5k km
    450K at most.
    Feb 2011
    #273
    Model po: 2005
    Mileage: 72.5k km
    PM mo si J4ever and I believe he recently bought a 2nd hand unit. As for the price better check ************** para may prive reference ka.
    Mar 2011
    #274
    * Spider,
    Based on ayosdito, a 2005 model ranges from 580-650K
    Feb 2011
    #275
    *J what model year is your unit?
    I think tama yung quote ni J and saw ads on Sulit for about that range. Mahal the Grandis when it was first introduced nasa 1.5M although I think the first units came from Japan and beginning 2007 came fro Thailand. Correct me if I'm wrong
    Aug 2011
    #276
    mga boss, ano ba ang sukat ng wiper ng grandis?
    700mm yung mahaba at ano yung miksi?
    may nagpalit na sa inyo? anong brand, saan binili at magkano ang bili?
    thank you in advance
    Feb 2011
    #277
    Spat, I replaced mine immediately because nagskiskip agad. The shorter one is around 21"-22" while the longer one is 26-28". Medyo mahirap hanapin the longer one because the opening needed for the hook is wider compared to sedans kaya dapat pasukatin mo muna. NWB is the brand and I got it sa Concorde sa may Greenhills mga 1.2K for the longer one and around 800 for the shorter one
    Aug 2011
    #278
    Quote Originally Posted by rafmac View Post
    ok noted...thanks...papalitan ko na din siguro kasi hindi ako satisfied sa paghagod e
    Feb 2011
    #279
    same here kaya palit ako agad. No other options nakita ko aside from NWB di kasi kasya yung Bosch and others sa longer arm, but I am satisfied naman
    Aug 2011
    #280
    Hindi kasya, dahil dun sa hook o kulang sa haba yung mga binebenta ng ibang brand?
Mitsubishi Grandis [Merged]
