Page 17 of 26 FirstFirst ... 7131415161718192021 ... LastLast
Results 321 to 340 of 509
    Aug 2008
    #321
    Quote Originally Posted by rex31angel View Post
    "check also air filter baka marumi na,or baka sa mga fuel kines or pump or filter"
    bagong palit sir ung air filter last month... never ko pa napacheck ung fuel pump and filter... thank you sa tip sir!
    #322
    I have a MItsubishi Galant 6G A/T, ano pong ang best motor oil to use with my car model? I tried Castrol & Shell oils na po. Thanks!
    Dec 2009
    #323
    I am selling my 95 Acquired 96 Model Galant Supersaloon (Red with shiny original paint),Stock Fuel Efficient Engine (16 valve EFI 2.0L 4G63) Manual Transmission, all power ( All windows and gauges are working), and with the following features: Keyless Entry with Alarm Racing Pedals Pioneer Headunit with CD, MP3 and AUX Pioneer Speakers 90% YOKOHAMA Tires Cool Aircon (New Compressor) Newly TUNE UP (New Timing Belt, Change Oil, Oil and Air Filter, Spark Plugs, Engine Supports, Brake Pads) The car is in very good running condition without Engine Leaks and has good Underchassis ( Wala po Kalampag) Pls see to Appreciate ( the car has Very good Interiors to match with its Exteriors, Latang lata pa po kasi and with low mileage) ABSOLUTELY NOTHING TO FIX Viewing is in San Pedro, Laguna or SM MUNITLUPA Only Price is 165k (Check the Car first, pag gusto niyo talaga then lets negotiate, WAG LANG BABARATIN) Pls contact me if interested 0927 6166193 PLS RESPECT MY AD. NO ASKING OF LAST PRICE AND NO TO BUY AND SELL AND LOW BALLERS
    #324
    Quote Originally Posted by lastresort15 View Post
    Please respect forum rules as well.
    http://tsikot.yehey.com/forums/annou....php?f=94&a=19
    Sect. II, No. 8
    For our 1994 Galant VR m/t, we just have the service done at our suking mekaniko. When i had the TB and stuff cleaned, it was done by Speedyfix.
    Been with us since brand new and runs well (140,000kms); 7-8km/L in the city then 12km/L in the highway and can still hit 210kph with no drama.
    Jul 2005
    #325
    tulong naman sa mga may 98-03 galant SS... totoo ba na di pwede adjust ang rocker arms pag nagpatune up? kasi dinala ng gf ko ung oto nya sa talyer and ang sabi e di daw adjustable ang rocker arms. The reason why is nagpalit kasi sya ng langis after nya nabili ung car a month ago from reg motor oil to synthetic oil then suddenly nagkaroon ng ingay ung makina na parang kelangan ipatune up at adjust ung lifters... pero sabi sa kanya is di daw un adjustable. I cant help her kasi nandito ako sa states. All inputs are greatly appreciated. BTW ang pinapapalitan sa kanya is spark plug o ring, high tension wire valve cover at gasket... pero nung pinapalitan ko ung spark plug nya e wala namang langis o di basa ung spark plug... ngayon lang ako nakarinig kasi ng spark plug o ring e...
    Aug 2010
    #326
    Quote Originally Posted by gwapito69 View Post
    This regard to your questions po! Hope this answer will help!
    Problem: 8gen SS galant tiktik sound
    mga boss nung nagpalit ako ng motul na fully synthetic oil napansin ko meron na parang tik tik tik sound coming from the engine. sabi mechanic tappets daw yun. ano magandang solusyon po dito? self adjusting ba 4g63 sohc or pwede talaga i-adjust manually? help naman po mga gurus.
    Answer of gurus:
    ++++Self adjusting ang tappets!
    The Culprit: motul fully synthetic oil
    ++++mga sirs the culprit was the motul fully synthetic oil na pinalagay ko several weeks ago nung nagpachange oil ako. from mobi1 fully synthetic i tried motul naman pero nung linagay yun napansin ko agad parang hindi maganda rev ng auto ko. basag ang tunog at maingay, after several days lumabas na yung tik titk tik sound ng tappets. everyday lalong lumalakas at tumatagal, kasi nung 1st pag uminit na makina nawawala na pero habang tumatagal nga lalo lumakas yung tappets ticking sound. sabi mga mekaniko dapat sa casa nalang kasi ang solusyon nila palitan ko buong hydraulic lifters ko. sinubukan ko nalang na magpatune up at change oil ulit from motul to castrol magnatec mineral oil tas sabay reset ng ecu. first start medyo meron pang ticking sound pero nung nagtagal nawala na at until now wala na talaga yung ingay ng tappets. pansin ko din pino na ulit makina at rev ko and mas lumakas hatak at tumipid pa ng onti sa gas kesa nung naka motul ako. sad experience para sakin yang motul oil na yan. siguro hindi talaga siya compatible sa 4g63 sohc. shinare ko lang mga boss!
    I've read this to the other forums! hope this will help!!!
    Im also a 99 galant SS owner!a/t
    Aug 2010
    #327
    i want to buy a galant SHARK. all stock.
    please contact me to 09178168999
    Aug 2010
    #328
    Quote Originally Posted by weedz26 View Post
    How much po is your budget? thanks
    Sep 2010
    #329
    Gandang gabi po. Need help with my 7g main power window switch. Ayaw na gumana eh, I'm hoping na may makapag turo ng good shop where to have it check, if not where I can get a replacement. Thanks in advance.
    Jul 2010
    #330
    Quote Originally Posted by Vinz0525 View Post
    sir may "tick" sound ba pag pinindot mo yung switch? kung meron, stucked-up yung bintana mismo sir. langisan lang yung goma sa gilid ng salamin.
    Sep 2010
    #331
    Rdt7G,
    Thanks sa reply. Meron naman kaso sa main left lang sa side ko lang may ticking sound and only pag pababa. The rest walang response eh.
    Quote Originally Posted by rdt7G View Post
    May 2009
    #332
    musta po ang galant as an everyday car?
    Im pertaining to 93-96 itlog galant.
    Ano po ung mga variants ng galant for 93-96 ?
    #333
    Quote Originally Posted by Whitesmith View Post
    In our case, it seems to be better off as a weekend car. FC is bearable with our m/t V6 as long as it doesnt get stuck in crazy traffic but not great either and the suspension loves eating ball joints. My brother uses his 1994 Galant on weekends/coding days now and the car runs much better (less kalampag) as compared to his driving it everyday before.
    It was sold from 1994 to 1997/98 and it came with the 2.0 Supersaloon (a/t and m/t) and 2.0 VR V6 (a/t and m/t... the a/t version came out after 1995). There were some limited edition models towards the end of the life cycle (leather seats, mesh rims).
    Sep 2010
    #334
    Mga sir, patulong naman po.. sobra n po talaga sakit ng ulo ko.. mdyo madami po kasing nangyari sa galant ko.. BTW, A/T 92MPI SS po yung sa akin..
    Eto po yung story.
    Nung una, dinala ko po sya sa shop na malapit dito sa amin, kasi ngbabago-bago yung idling.. from 800rpm nagiging 450-500rpm kapag nilalagay ko sa Drive, with A/C on. Tapos bigla nalang namamatay yung engine.(Kahit deretso yung takbo ko) Then they have suggested the following:
    1. Tune-up
    2. Palit spark-plugs and hi-tension
    3. Change oil
    4. Palit Engine and tranny support (Kasi daw malakas daw ung lagabog pag nilalagay sa Drive or Reverse)
    So after this, kinuha ko na yung car since sabi nila ok na daw. Which is wrong on my side kasi sobra ako nagtiwala sa kanila. Result, halos walang nagbago. Then binalik ko sa kanila the day after kong makuha kasi ganun pa din yung problema. Eto naman dw yung ginawa nila:
    1. Nilinis ung throttle valve (im not sure kung yun ung tawag)
    2. Nilinis yung air filter
    3. Nilinis ung servo
    4. Nilinis nila yung mga parts na hindi ko po sure yung mga tawag (basta eto po yung mga nakakabit malapit sa ECI na box)
    5. Palit ATF
    6. Sinabay na din nila yung mga bushings, axel boots, basta yung mga pangsuspension.
    Okei, na daw. Dahil halos 3weeks yung sasakyan sa kanila, akala ko po naman okei na talaga. Tinestdrive namin, halos ganun pa din yung problem. Namamatay pa din tapos nagbabago pa din yung idling. Dahil sa inis ko, kinuha ko nalang yung sasakyan. Kasi ayoko naman makipagtalo pa sa kanila. Result, ngbayad ako ng halos 14K para sa walang nangyaring sasakyan.
    After all of this, another problems came out. Eto na po yung mga problema ngayon:
    1. Nagshishift na yung sasakyan from 1st-2nd gear pag 4000rpm na. Tapos biglang lalagabog yung halos buong laman ng makina sa lakas ng impact.
    2. Merong mga instances na from 2000rpm biglang bababa yung idling ng 1200rpm kahit nakaapak ako sa accelerator. Tapos mahihirapan na ulit kumagat yung accelerator parang umaapak tapos walang nangyayari.
    3. May ilaw na din yung "check engine".
    4. Unang start, pag pinatakbo na, tatakbo ng 100meters (BTW dito na po simulang lalabas yung "check engine) tapos mamatay na yung engine. Yung second start medyo okei na. Lumalabas lang yung Problems 1-3.
    5. Meron ding mga times na kakadyot ng kakadyot dahil hindi sya nakakapagshift.
    Hayyy.. hindi ko na alam yung gagawin.
    Pasensya na guys medyo mahaba po ahh. I just wanana share my story kasi feeling ko hindi na titino yung sasakyan. And i really want this car to be in his very mint condition. Coz i really love the car.
    Tanong ko lang po sana kung san ko po sisimulang idiagnose yung sasakyan. Back to zero nanaman ba ako? Please help me. I really need that. Thank in advance po.
    Nov 2007
    #335
    Hello mga PAps Galant USer,
    Good day to all.
    Its been a year na di ako nakakauwi ng Pinas. Maybe this coming december 2010, it will be come true..
    Favor naman, can you suggest a good shop and mechanics about my car MItsubishi Galant 92 GTI 2.0 model (4G6) for maintenance and services, kasi almost a year kong hindi nagamit (January), always ang lagi kong encounter na sira ay yung break ko, stock-up lahat, pero lagi try kong palinis pero as in laging nag-iinit lalo na yung sa rear side, tapos laging ubos ang break pad, once yung handbreak ayaw mag release so it make sound scratching.. And aslo the clutch sometimes i have to replace the rubber kits sa engine side.. Steering fluid may konting leak.. Engine tune-up. And last are my axle bearing front should be to replace, kasi pag nagturn right or left ako meron nang sound..Bearing as usual.. Help me naman kung saan puwede kong pagawang shop and also availability nung mga parts. Location namin ay dito sa Pila laguna.. Thanks in advance...
    Jan 2009
    #336
    Hi sirs,
    I own a galant gti din, sir register ka dito kung di naman bawag mag send ng ibang link mga mods/admin:
    http://pris.mymitsuph.com/index.php?...3;action=forum
    See you there sir!
    #337
    hello sirs/mams...
    im new here.. im glad to knw this cite.. tnxs for the questions and advices from d members.. its really helpful to us who own a galant.. i heb a galant mpi (gti look), '92 model, m/t. ryt nw shes under going repaint. change color frm silver to white. we've been together for 10 years nw. kaya magkasama kami to ups and downs.. lots of experience na rin, kya ako na lng minsan ang gumagawa pag nasisira ang ktse ko and nagtuturo sa mekaniko kung ano dapt nyang gawin sa kotse pag wala akong time gawin ang sira..
    Q sirs, activated na po ba ang CAGE? tnxs
    #338
    sirs, any idea kung ano ang brand or type ng paint ng new toyota white camry or grandia. un sana ang plan ko i-paint sa 6g ko. any comment with d color, bagay kaya sya sa 6g's? tnxs..
    #339
    boss 4g63 san madali makahanap? change engine for galant rayban :D
    Aug 2010
    #340
    Quote Originally Posted by galantrayban View Post
    ano hinahanap nyo po sir engine ba?
    try this link:
    http://pris.mymitsuph.com/index.php?...91.0;topicseen
Mitsubishi Galant Car Forum
