Results 1 to 7 of 7
October 28th, 2002 12:19 PM #1
Hi guys,
What tires/mags/brands are ok for the Mistubishi Adventure? I'm about to replace my old tires, and I need your inputs.
I'd rather have no mods to the wheels. I'm currently using Toyo 195/70/R14 tires.
October 28th, 2002 10:25 PM #2
Goma? Bridgestone is hard to beat.
Yung alloys ba papalitan mo na din? Maganda sa Adventure yung mga tipong pang-kotse na design. Yung walang higanteng center hub.
- 400
October 29th, 2002 01:11 AM #3last year's transhow, mitsubishi had an adventure with evo iv lookalike wheels. it looked good.
- 10
October 29th, 2002 11:15 AM #4pwede kaya low profile tires for the adventure. mga tipong 245/16r???? magdadagdag ka pa ba ng extended fender flares????
October 29th, 2002 06:09 PM #5
Like what otep said, bridgestone is hard to beat. Try to get the ones made in Japan though, coz sometimes, for smaller rim sizes, they're made in Indonesia or elsewhere.
Should you upgrade to 15"ers, Dunlop LMRV506 (6 ply) tires are also ok.
Tsikot Member Rank 2
- 635
September 27th, 2003 11:03 PM #6up ko lang... kailangan ko din ng suggestions about this...
ano kaya nabili ni dieseler?
September 29th, 2003 08:11 PM #7
Hi Mackieboy,
I stayed with my factory mags (I'd rather spend it on new shocks), and got myself the Bridgestone B700, 195/70/14, made in Japan. So far ok naman sya. Temperature A, and I'm assuming since its the replacement (kuno) for the B70, its Treadwear is probably around 200, and Traction A. Also assuming na pareho ang tire pressure with the B70, around 44psi ang max. The B700 kasi has little sidewall data, unlike the B70 which is halos complete.
My Toyos by the way lasted around 53K (4 years old). Nagkaroon ng singaw ang isa, via crack in the tread. The rest are still usable, since di pa umaabot sa 'change tire indicator' band.
i wonder, are the usual published suspension adjustment specifications supposed to be adjusted...
Wheel Alignment
