Results 971 to 980 of 2048
July 11th, 2013 02:25 AM #971
*babynos01 - sir u mentioned sa orig thread, naglalagay po kayo ng 2T sa fuel for several months na.. pardon my ignorance pero kung SCV man ang problema, hindi kaya may factor yung additive na 2T or long term effect sa fuel system natin?
- Aug 2003
- 317
July 12th, 2013 03:54 PM #972babynos01, try mo hold accelerator to try and maintain a certain RPM. Test the following: idle, 1.5k, 2k and 3k RPM for around 15-20secs each. If you see the RPM needle fluctuate, possible na SCV.
July 12th, 2013 04:15 PM #973
- Feb 2007
- 122
October 10th, 2013 12:55 AM #974Its been a month since nag check engine montero ko. Twice na ni reset sa Casa.
First, EGR lumabas na problem, Reset lang.
Second, clean EGR, Reset.
Ganun pa rin, bumalik pa rin check engine.
Ok naman takbo, parang lumakas nga lang sa krudo.
Sabi ni SA, palit EGR na, Php8000.
Di kaya, mag check engine pa rin kahit palitan na EGR?Last edited by don2x; October 10th, 2013 at 12:57 AM.
- Feb 2007
- 122
October 10th, 2013 09:49 AM #976
- Sep 2011
- 626
October 10th, 2013 03:45 PM #977Sir do you hear a clicking sound sa engine compartment, particularly sa egr, upon shutting down the engine? If there is, ibig sabihin nagana pa yung motor ng EGR. You can remove the whole assembly and test if the motor is still running. Nasa SMV yun pero wala na akong copy e.
Try also to clean the intake manifold. Nung nag CEL (1st time) sa amin before, nilinis egr and yung intake manifold.
The second time na nag CEL, ayun sira na yung motor.
- Feb 2007
- 122
October 10th, 2013 06:56 PM #978*babynos01
Nalinis na rin intake manifold.
Dahil pagkatapos malinis sa casa, sabi pag bumalik CEL, palit na EGR, Kaya pinalinis ko ulit EGR sa neighborhood talyer, pati intake manifold.
Ayun, nawala CEL, pero after 1 day, umilaw na naman.
Kanina, nakakuha ako EGR sa El Dorado ₱6700.
Pagkatapos makabit, naglaho na CEL after 30 minutes hours of driving.
Sana di na bumalik.
- Apr 2011
- 109
October 11th, 2013 03:07 PM #979mga bossing, donot really understand kung anong function ng egr but i have been reading also about zix888 egr fix which they call egr blanking. dun sa mga may problema with their egr, just would like to ak if you have also considered this option?
- Sep 2011
- 626
October 13th, 2013 12:19 AM #980Sirs question lang. Not really a big issue.
Does anyone know how to remove yung console underneath the radio? (yung may 12v adapter and rear aircn switch) Ayaw umilaw ng rear aircon indicator light, pero nagana naman yung rear aircon kapag sinwitch mo.
A relative of mine in Canada had his Scion FR-S PPF'd and then had it ceramic coated. He says it's...
Ceramic Coating vs PPF (Paint Protection Film)
