Results 1,001 to 1,010 of 2048
- Jun 2012
- 21
November 5th, 2013 09:58 PM #1001Last November 1 na stucked yung gear ko and can't move or shift in any from 1st to 5th gear and revise.masyadong matigas.i tried yo turn off the engine and tried Kung ganun din pag patay makina and it was working.again tried to start the engine...talagang ayaw mag shift sa kahit anong gear.turn off the engine again put the gear sa first and started the engine.kumadyot sya and tried to put to neutral kaso ayaw na din ang togas talaga.ending pinalo ng Malakas para bumalik sa neutral and started the engine again.it worked already!before that Mahabad by ahem ko Mga 2 hrs matraffic and park the car naka incline.i don't know what went wrong and what caused the problem.help!
I went sa casa yesterday Monday and had it check, initially sinabi nila clutch system either may tagas or hangin...ending, bleed lang nila yung car at wala daw nakita ng problem.gosh pwede ba yun walang problem walang explanation?anyone can help me understand pls?nakita ko pinalitan plug dunsa ilalim engine plug yata yun.btw montero 2012 po unit ko but it's only 1 year and one month old sa akin.manual transmission.i asked Baka transmission..sabi sa akin Hindi daw kasi Kung transmission...even patay makina ko Hindi ko sya malilipat ng gear.hay.anyway, at least May record an din ako sa kanila for future regencies which of course I hope Hindi na maulit.first time daw nila naka encounter nun.
- Nov 2013
- 2
November 6th, 2013 03:45 PM #1002
November 6th, 2013 05:49 PM #1004
if there is air or water presence sa filter casing, you have to bleed it out. now kung magpapalit ka na, after ma-install ng technician o mechanic yung filter, may knob sa ibabaw ng fuel filter casing at pina-pump nila yun para i-priming yung fuel filter bago nila ikabit yung fuel line.
Registered User
- Mar 2011
- 276
November 7th, 2013 02:11 PM #1005There is a grinding sound in the engine on start up up especially when not used for a day or more. Sounds like a bearing that is linked to the pulley system.
- Sep 2010
- 53
November 7th, 2013 08:35 PM #1006
- Jan 2009
- 31
November 9th, 2013 06:08 AM #1007
Registered User
- Mar 2011
- 276
November 9th, 2013 05:56 PM #1008
- Sep 2010
- 53
November 10th, 2013 08:35 PM #1009
- Sep 2010
- 53
November 10th, 2013 09:50 PM #1010Old Fuel Filter At 13k Km Photo by ROVER2027 | Photobucket
Share ko lang po.
Yung extra AUX Fan is useful sa mga naka montero. Mag improve daw yung AC system since may extra...
