Page 6 of 11 FirstFirst ... 2345678910 ... LastLast
Results 101 to 120 of 215
    Feb 2011
    #101
    *sir tom guts, thanks sa advice..
    Jan 2011
    #102
    Diesel engine here in europe can easily reach 1 million mark w/o even changing piston rings.They use synthetic oil to achive this,cause they know what they are doing.Just do the math guys about this additional 50-500% i mentioned.
    Quote Originally Posted by dagol View Post
    IMO it's not just the oil, the fuel there is also way better in quality compared to Pinas euro 2 level.
    Jan 2011
    #104
    Nothings wrong with our fuel in the philippines,in fact,its even better for injection pumps & injectors because fuel(diesel) there have better lubricity than european diesels.Besides fuel have nothing to do with the length of service of an engine.Its maintenance thats matters
    Jan 2011
    #105
    Quote Originally Posted by bobby.saint View Post
    anytime chief! update lang kung anong brand ginamit mo on your 4d56 and share us your thoughts and experience of using it.
    - IMO higher quality fuels in europe does have an effect in the performance and longevity of the car. There is something wrong in our fuel here, because inferior quality of fuel produces more pollutants (we shoudl be eco-friendly) and soot that degrades the performance of engine oil. Esp. for those with egr installed.
    Jan 2011
    #107
    its the use of mineral oil that will foul the EGR most thats why Scania highly recommend fully synthetic oil to there new diesel engines as they use EGR system to control emmission unlike Volvo that uses Urea for exhaust after treatmment.Normally,we can easily clean EGR.As with our fuel in our country,its not that dirty as what we think.JUst change your air filters religiosly.Dont run with dirty air filters as engine will emit black smoke because of richer air/fuel mixture.In additon,motor oil will be drawn up towards combustion chamber if the air filter is clogged as diesel engine have greater air suction compared to gas engine.You will consume more oil & fuel at the same time.
    OT lang, are there any 4d56 engine still running there? TIA
    Apr 2010
    #109
    Yup, my gen 2 pajero still has the 4d56
    Jan 2011
    #110
    yes,plenty of them still exist but they are already rusty specially vans & pick-ups.Japanese cars are prone to rust.
    You mean in europe there are still 4d56 equipped cars? You're from EU right?
    Jan 2011
    #112
    Yes,they are still around with the old L300(exceed body),delica,L200 and pajeros(1st & 2nd gen).These old diesels are pretty much reliable.The new common rail diesels are very powerfull but the pump & injectors cost too much to replace.Besides,once they broke,no ordinary technician can fix it and parts are not available everywhere.The cleaner emmision is the main purpose for these engines as manufacturers need to comply EU & US standards.
    May 2010
    #113
    good day gurus!
    hope to have your comments on the ff:
    1. mineral engine oil ba ang nakalagay sa engines ng mga new 2011 monty?
    2. after 1K km, Casa recommends to use mineral oil muna. After 5K km, synthetic naman daw ang ipalit. is this the proper way of servicing the monty in terms of changing engine oil?
    TIA!
    Quote Originally Posted by makunochi View Post
    good day gurus!
    TIA!
    Sir Makunochi, usually the proper oil to use is in the manual. But I strongly suggest you use semi or fully synthetic oil na agad kahit sa 1K PMS pa lang Also, you might want to check monty thread. It is the thread that is ideal for your queries.
    Jan 2011
    #115
    up ko lang to mga ka-tsikoteers! any 4D56 engine owners
    using other oil brands?
    May 2010
    #116
    What we use in our Mitsubishi Spacegear 4D56 Turbo are:
    >Martini Fully Synthetic Oils 5w-40 every 20,000km PMS
    >Valvoline Fully Synthetic Oils 5w-40 every 10,000km PMS
    >Mobil1 Delvac 15w-40 every 5000km PMS
    we regularly have the car's pms every 5000kms and the car is not used daily kasi until now
    56,+++kms palang ung spacegear though its a 98 model.
    #117
    for our 4d56 versa van
    mobil1 delvac mx 15w40.
    Jan 2011
    #118
    Quote Originally Posted by SiRbossR View Post
    Quote Originally Posted by junerski View Post
    chiefs how's the performance and "feel" in terms of using Mobil Delvac MX 15W-40 on your 4D56 engines? I might wanna try it out in the future as I'm having a hard time looking for Shell Helix diesel plus 10W-40 semi-synth (blue bottle)-bit by bit I think Shell is trying to phase it out due to their "repackaging thing" for their entire motor oil line up.
    Quote Originally Posted by tom_guts View Post
    Used this also for my L200 4x4 strada and advie. No prblem encountered and even if you change the oil at 7,500km, it seems the same performance pa rin with 5K interval. Change oil filter lang ako noon ha. API CI-4 compliant siya. It is that good IMO.
    Nag-rerepack nga shell. Hirap hanapin yung pang-diesel.
    Jan 2011
    #120
    I strongly recommend that you continue using semi-synthetic oil rather than going back to mineral oil.May mga semi-syn naman ang ibang brands ng langis
Best engine oil brand for 4d56?
