Page 161 of 269 FirstFirst ... 61111151157158159160161162163164165171211261 ... LastLast
Results 1,601 to 1,610 of 2689
    #1601
    Quote Originally Posted by miggymontero View Post
    bro playplugg nag occur ito after 1K. on/off siya kahit from startup and during driving. nawala lang after 5K and then ang pumalit yung clicking sound during hard turns.
    Hopefully hind mag occur sayo bro.
    Quote Originally Posted by vickoy1228 View Post
    Sir already doing that, kaso talagang lumalabas pag da drive na tas on & off. Hopefully mawala din sya pero will report it on my 5k PMS, based kasi sa pagbabasa ko ng mga forums may mga ganto ng problem since 2010 ang MS and the culprit is the rack & pinion kaya pinapa replaced nila sa casa, the other source of the problem is the steering column. Though based sa testimony ng mga nagpapalit lumalabas ulit ...bakit kaya di na resolve ng Mitsubishi to???
    Thanks po Sir miggymontero & Sir vickoy1228 sa info about sa steering issue (hissing sound)
    Sana po ma-resolve po yung problems nyo sa monty, lalo na po steering and very critical part ng sasakyan.
    kung meron po time, report it as early as possible..
    Nagtataka lang po ako kung bakit after 1K PMS, saka ito lalabas, saka change oil and some minor adjustment lang naman ang ginagawa (nasa checklist ng service manual) yung mga nag replaced ng steering assembly, lumalabas pa rin?!
    wag naman sana, siguro yung iba, instead na ayusin, reverse side ang ginagawa, maliban lang kung talagang major issue at kailangan ipa-recall ang unit. manufacturer fault. pero kung wala naman issue sa ibang bansa at dito lang nangyayari sa pinas.
    no comment...
    Jan 2014
    #1602
    W
    Quote Originally Posted by BMGregorio View Post
    Oo nga pala, prior to the arrival ni Sir Zixx kanina samin, nasa Banaue ako para tumingin ng tweeters para sa aking monty. Akala ko walang nakalagay sa loob ng tweeter pod sa may pintuan pero nung buksan ng installer meron pala pero it was so small and even if lakasan mo yung volume ng radio, ang hina pa rin ng dating nya.
    So I asked yung dealer kung meron syang pair of tweeters that would work with the stock 45w radio. She recommended I try JBL w/c costs about Php 1,200.00, meron nang kasamang pair din ng crossovers w/ free installation. After nya isalpak ayun medyo ok na... audible na yung kalansing pero still meron pang kulang since kapag naka "on" yung "Loud" eh talagang garbled yung audio. Pina try sakin nung dealer yung kanyang MBO self contained and powered (built-in amp na) sub-woofer. Ayun APRUB! Happy nako sa tunog nya clear na yun High & Low frequency handling ng monty... hindi ko na pinapalitan yung mga stock speakers sa pintuan since ok naman ang pag handle nya ng Mids...(maybe some other time).
    Total project cost to improve audio quality:
    1.) JBL tweeters w/ crossovers = 1.2k
    2.) MBO self contained & powered sub-woofer = 6k
    Total install time: 1:30
    Tip sa installer: 100.00
    I'm sure there are other ways of improving the audio quality, this just happened to be the most convenient for me since I'm not really a DIY person.
    Sir, I installed MBO subwoofer too. I have a sugggestion, since di ko nakita kung nag install ka ng OEM RCA Jack dedicated for subwoofer, it's sold separately from Winterpine at 1.5k free installation plus tip sa installer and a Y-jack worth Php200. Mas naganda ang blend ng bass at matimpla mo pa sa sound setting ng headunit. Walang kasamang mga cables ang headunit natin the same with Video-out RCA jack for headrest monitors is also sold separately. You can test it kung naka dedicated jack ang subwoofer mo kung na co-control mo ang volume nya through headunit, ang setup nun sa settings ng headunit. My sub was installed first sa suki kong accessories shop, tapped lang nila ang sub ko sa front speakers using an RCA adoptor. Di ako satisfied sa tunog and I wandered how come di wa effect ang adjustments sa headunit. I did my research and called Winterpine, they confirmed it has to have dedicated RCA Audio jack (Center, Rear, Front, and Sub) definitely needed also if youre planning to install amplfier. Satisfied (hopefully) now with the sound, but yet I need to put deadening because of rattling sound from doors.
    Sep 2014
    #1603
    Good pm sir zix pa pm naman ng priceng egr blanking and ac filter tnx
    #1604
    San nakakabi ng plate holder? I just got my plate 2 days ago. Almost all monty's I see uses one in front.
    Wouldnt it make it prone to "sabit" specially now that cover/brackets are somewhat questionable?
    Posted via Tsikot Mobile App
    Sep 2014
    #1605
    Good pm. .ask ko lng po good deal na ba GLS V 4x2 matic srp less 113k free lto. 3m tint pero sa front visor tint lng..matting. Car care kit and tools and jack. On cash basis po..insurrance compre 34 200 and tpl 1800+...thanks
    Last edited by babygemma; September 27th, 2014 at 02:12 PM. Reason: forgot something
    Sep 2014
    #1606
    Ask ko na rin po saan po magandang seat cover and any idea kung how much? Thank
    Feb 2014
    #1607
    Sa seat tailors ako nagpagawa sa may likod ng metro walk. 10k for 3 rows and door panels.
    #1608
    shiny teeth!!!
    #1609
    Quote Originally Posted by iwanttime View Post
    Genuine leather or leatherette sir?
    #1610
    Quote Originally Posted by babygemma View Post
    That's a huge discount, absolutely great deal, guess I bought mine a little too soon. Which dealer by the way?
2014 mitsubishi montero
