Results 1,601 to 1,610 of 2689
September 24th, 2014 06:58 PM #1601
Thanks po Sir miggymontero & Sir vickoy1228 sa info about sa steering issue (hissing sound)
Sana po ma-resolve po yung problems nyo sa monty, lalo na po steering and very critical part ng sasakyan.
kung meron po time, report it as early as possible..
Nagtataka lang po ako kung bakit after 1K PMS, saka ito lalabas, saka change oil and some minor adjustment lang naman ang ginagawa (nasa checklist ng service manual) yung mga nag replaced ng steering assembly, lumalabas pa rin?!
wag naman sana, siguro yung iba, instead na ayusin, reverse side ang ginagawa, maliban lang kung talagang major issue at kailangan ipa-recall ang unit. manufacturer fault. pero kung wala naman issue sa ibang bansa at dito lang nangyayari sa pinas.
no comment...
September 26th, 2014 01:09 AM #1602
WSir, I installed MBO subwoofer too. I have a sugggestion, since di ko nakita kung nag install ka ng OEM RCA Jack dedicated for subwoofer, it's sold separately from Winterpine at 1.5k free installation plus tip sa installer and a Y-jack worth Php200. Mas naganda ang blend ng bass at matimpla mo pa sa sound setting ng headunit. Walang kasamang mga cables ang headunit natin the same with Video-out RCA jack for headrest monitors is also sold separately. You can test it kung naka dedicated jack ang subwoofer mo kung na co-control mo ang volume nya through headunit, ang setup nun sa settings ng headunit. My sub was installed first sa suki kong accessories shop, tapped lang nila ang sub ko sa front speakers using an RCA adoptor. Di ako satisfied sa tunog and I wandered how come di wa effect ang adjustments sa headunit. I did my research and called Winterpine, they confirmed it has to have dedicated RCA Audio jack (Center, Rear, Front, and Sub) definitely needed also if youre planning to install amplfier. Satisfied (hopefully) now with the sound, but yet I need to put deadening because of rattling sound from doors.
- Sep 2014
- 16
September 26th, 2014 01:13 PM #1603Good pm sir zix pa pm naman ng priceng egr blanking and ac filter tnx
- Mar 2014
- 291
September 27th, 2014 09:32 AM #1604San nakakabi ng plate holder? I just got my plate 2 days ago. Almost all monty's I see uses one in front.
Wouldnt it make it prone to "sabit" specially now that cover/brackets are somewhat questionable?
Posted via Tsikot Mobile App
- Sep 2014
- 16
September 27th, 2014 02:10 PM #1605Good pm. .ask ko lng po good deal na ba GLS V 4x2 matic srp less 113k free lto. 3m tint pero sa front visor tint lng..matting. Car care kit and tools and jack. On cash basis po..insurrance compre 34 200 and tpl 1800+...thanks
Last edited by babygemma; September 27th, 2014 at 02:12 PM. Reason: forgot something
- Sep 2014
- 16
September 27th, 2014 03:13 PM #1606Ask ko na rin po saan po magandang seat cover and any idea kung how much? Thank
September 27th, 2014 06:05 PM #1607
Sa seat tailors ako nagpagawa sa may likod ng metro walk. 10k for 3 rows and door panels.
Tsikot Member Rank 1
- Jul 2009
- 4,090
BANNED BANNED BANNED
- Mar 2009
- 81
September 28th, 2014 09:20 AM #1609
- Mar 2009
- 81
September 28th, 2014 09:27 AM #1610
For the Toyota products its likely to be the case for most of their products per the service...
Wheel Alignment
