Page 195 of 197 FirstFirst ... 95145185191192193194195196197 LastLast
Results 3,881 to 3,900 of 3938
    #3881
    meron na po bang nagpalit ng head unit. ng ms natin? talaga bang sirain yung touchscreen niya? 22 mos / 18k old pa lang yung unit ko so hindi ko rin masyadong nagagamit yung h.u. ko pero madalas ayaw na magrespond yung touchscreen.
    ano pong magandang replacement na gagana yung stock tpms & 1-din dvd player?
    salamat po sa sasagot
    #3882
    Quote Originally Posted by boytsiks View Post
    Hi guys, just wondering, how often do you have your AC cleaned?
    I had my old 2010 GLS A/C cleaned every 60,000 kms together with drier and expansion valve replacement. It will prolong the life of both your compressor and evaporator.
    Sent from my SM-G920F using Tsikot Forums mobile app
    Jan 2016
    #3883
    Sir/s, ask ko lang pag nag papa-carwash ako always need to turn off the alarm ni monty. everytime bubuksan yung doors nag alarm siya. pano nga ulit mag disable ng alarm para hindi tunog ng tunog? thanks again!
    #3884
    Quote Originally Posted by 99gil99 View Post
    If your Monty is 22 months old or almost 2 years then your head unit is still under warranty. Bring your Monty to Winterpine Service Center, Aurora Blvd cor Hemedy for a warranty check. They will replace it if needed.
    #3885
    Sir bayen musta naman response ng petron trekker sa monty mo? Yan din gamit ko sa old d4d innova ko from 5k kms to 75k kms. Di pa naman ako nag ka problem sa engine
    Sent from my SM-J500G using Tsikot Forums mobile app
    Petron Trekker 15W-40 API CI-4 is a very good oil. I used it for 10 years in both my old 2001 Strada and 2010 Monty.
    Sep 2016
    #3886
    Anybody tried to disable beep sound when opening or closing the door? 2013 GLSV. Ty.
    Sent from my ONEPLUS A3003 using Tsikot Forums mobile app
    Aug 2017
    #3887
    Hi guys,
    I'm planning to buy a used Montero Sports. Currently looking on 2013/2014 GLS-V models.
    Hingi lang sana ako ng tips on what to consider and important things to check before buying.
    MS Newbie here,
    Thanks in advance!
    Aug 2017
    #3888
    Please help. I was crusing aroung 100kph at nlex when suddenly my montero GLS V jerks and begun to lose power. upon checking i notice the transmission monitor shows "D" is blinking. anyone experience this? already change ATF problem still exist.
    ^ ilan kms na tinakbo bos? Regular naman ang change atf nya?
    when you look into the abyss, the abyss looks into you
    Sep 2016
    #3890
    Quote Originally Posted by Chris29 View Post
    Probably the inhibitor switch.
    #3891
    May nakaka experience ba ng same issue sa montero sport namin. How much kaya pag ipapa ayos?
    1. Pag mabilis yun takbo at malubak ang kalsada, lumalakas ang volume ng speaker.
    2. Sa reverse, tutunog kagad yun continuous sound ng sensor kahit clear naman yun aatrasan at wala naman naka harang.
    #3892
    Quote Originally Posted by markysan View Post
    1. is that not an automatic volume compensator for the increased road noise?
    2. is that a distance sensor, or just a simple reverse alarm/reminder?
    they may be just how there are, and not "defects".
    1. speed dependent volume? i have 3 levels sa headunit
    2. dirty reverse sensor? mine beeps also even when i dont see anything. it doesnt happen when car is clean
    #3894
    I had my 15KKm PMS at the casa last Saturday.
    One of the recommendations is to clean the EGR,- I waived it.
    EGR was blocked by bro.Zix at 1KKm...
    Tama ba ang ginawa ko o kailangan pa ring linisin ang EGR even if it was blocked?
    Nov 2014
    #3895
    Yes. Ok to waive it since naka-blank ka na. But even if hindi ka naka-blank, I find it too early to clean EGR at 15K kms.
    #3896
    1. The volume will jump from <10 (my usual setting) to about 15 or 20+. There's no fix increment, sound will just be loud when i drive the car a bit fast on bumpy roads.
    2. It just happened recently. Car is now about 5 years old. It will have the continuous sound the moment I shift the gear to reverse.
    Sep 2009
    #3897
    Yes, tama. You're no longer using it (EGR), and I'm pretty sure it's still clean.
    #3898
    By blocked, do you mean that egr blanking was done to your unit?
    Nov 2017
    #3899
    mga boss tanong lang, ano format ng video ang okay sa head unit ng montero 2013? tska ano resolution para mag full screen? tia
    Nov 2017
    #3900
    Quote Originally Posted by byronjjjjj View Post
    normally sa mga luma HU wala problem pag AVI format mo. Sa mga bago HU lang pumapasok yung mp4 at MKV.
2013 Mitsubishi Montero Sport owners
