Page 193 of 197 FirstFirst ... 93143183189190191192193194195196197 LastLast
Results 3,841 to 3,860 of 3938
    Feb 2007
    #3841
    El Dorado, Cubao
    Larry +63 943 234 0470
    Dec 2013
    #3842
    Quote Originally Posted by lazza View Post
    guys share ko lang expirience ko kanina sa peak motor edsa. pinunta ko monty ko (gls-v 2013)kanina sa peak motor para papalitan ang shock suspension sa likod at sabi kc ng mekaniko ko may leak na daw then after 5 hrs bumalik ako para kunin na monty ko at ang sabi sakin wala naman daw leak ang sabi ko hindi naman ako magsasayang ng oras kung wala leak then pinakita sakin yung harapang shock suspension para ikumpara then nakita namin na may leak na din pala ang left front shock suspension ko so sabi ko sa mekaniko na papalitan yan then while im waiting for the michanic at the service room the lady said to me na normal lang daw yun nasa first level palang daw ng leak yung shock hintayin ko nlang daw munang may marinig akong tumutunog na galing sa shock then sabi ko kung normal lang yung may leak dapat yung other side may leak din at sabi nalang nya sakin ipapa check pa daw muna nila sa warranty department nila at sa planta...
    sa pagkakaalam ko pag under warranty pa sasakyan mo any damage should be replace immediately!
    Yung left rear shocks ko napalitan under warranty. Normal lang na may langis pero yung tumutulo na langis galing sa shock absorber, abnormal na yun. Compare mo din sa ibang shock absorber mo. Para mavheck pumasan mo shock before magbyahe. Check mo after gamitin. Bantayan mo din kapag papalitan. Better have it replaced kung under warranty. Marami na issue dyan before dahil pangit ginamit na brand.
    Jun 2013
    #3843
    Quote Originally Posted by Geronimo Valino View Post
    salamat sir pag uwi ko pinas icheck ko
    #3844
    egr blanking
    occ
    ac filter
    Jul 2015
    #3845
    The same thing happened to me yesterday. I tried clearing the fault twice using Torque2 unsuccessfully, but it disappeared by itself on the third cold start. It mentioned something about grey codes needing several attempts. Maybe it's time to change transmission fluid?
    Feb 2013
    #3846
    Nawala yung screw cover ng rear wiper ko. Do you have any idea guys kung san ako makakabili nito?
    Mar 2013
    #3847
    Good pm mga ka-monty. Ask ko lang kung may naka encounter na sa inyo ng touch screen problem. Di sya respond pag pinipindot,so di mailipat FM station, etc. may epekto kaya 3rd party rear cam? Within warranty pa sya, pwede kaya ipa check sa casa? Thanks sa advise
    Posted via Tsikot Mobile App
    Oct 2015
    #3848
    Magandang araw mga tol! May tatanong lang sana ako, yung kaibigan ko kasi nakakuha ng monterro 2013 gls v. ang tinatakbo is 10-15 KM sa odometer. Kaso may lumalabas sa radio niya, preventive maintenance 55KM. Ano yun dinaya siya ng pinagbentahan niya? Posible ba dinaya yung odometer niya? Wala daw kasama na maintenance records. Ang pinagtataka lang namin, sariwang sariwa yung kotse. Malinis na malinis, yung egr blanking mahigpit, yung loob sariwa. Ano pa ba way para macheck? salamat po!
    Oct 2015
    #3849
    or nagloloko lang yung radio niya? madalas kasi nawawala yung screen niya pag nagplaplay ng dvd. thanks po sa magrereply!
    Sep 2008
    #3850
    Quote Originally Posted by zix888 View Post
    egr blanking
    occ
    ac filter
    Sir pa pm po nang price saegr blanking.TIA
    Sep 2008
    #3851
    egr blanking
    occ
    ac filter
    #3852
    Re-post ko lang from the 2011 MS Owners thread...
    Bros, planning to buy a(n) ms gls v SE at.
    For those who bought a brand new MS, did you find a need to have the tyres corrected for camber and alignment? (There's a popular brand who is infamous about this, based on a couple of personal experiences with them).
    I am planning to use Unioil diesel,- anyone who's using this too? Any issues?
    How about the regular Shell diesel? (The service personnel was encouraging me to use the Shell Nitro diesel with a higher cetane rating to be on the safe side)
    Do I need to have a spare tyre lock installed? (Like the Fort)
    Any other things that I should be on the lookout for?
    Thanks for the input/help. More power!
    27.9K _/_/_/_/_/:matrix:_/_/_/_/_/
    Jun 2012
    #3853
    Unioil user here dahil sabi dito sa forum. No problem naman. Di ako nagshshell kasi wala less e. Either petron (dahil sa bpi) or unioil lang ako. Ok naman
    No need for spare tire lock dahil may cover naman
    Wala namang issue ang montero namin. I just change fuel filter every 10k pms. Sakit ata ng montero na bumabara agad fuel filter. Kaya maaga na lang ako nagpapalit. 350 lang naman isang filter
    #3854
    Quote Originally Posted by dct View Post
    Thanks bro.,- am happy for your ride and experience with it....
    Kaya bang i-DIY ang replacement ng fuel filter (thanks for sharing the price),- or isabay na lang sa regular PMS..... I will keep this in mind.....
    #3855
    Boss CVT, mine is 2009 3.2 and no issue naman sa wheel camber and alignment mula stock till 20s...
    Nung wala pang Euro 4 ang Unioil Seaoil ang gamit ko then Petron Turbodiesel and la ring naging problem sa SCV... EGR blanked na rin after 20K kms. Palit fuel filter naman every 15K kms.
    Yun ang maganda sa Monty, no need na lagyan ng spare tire. Yun nakausap kong tire/mags dealer na kuwento nila na bihira nagbebenta sa kanila ng paisa isang mags/spare kadalasan set..... mahirap daw kasi nakawin.
    Jun 2012
    #3856
    Another is walang aircon filter ang new unit so buy one pag release
    Sep 2014
    #3857
    Sir magandang umaga po, tanong ko lang balak ko kasing mag upgrade ng INTERCOOLer, para sa Montero Sport MT 2014 model,meron po bang pagkakaiba sa performance sa original intercooler at sa upgrade bigger intercooler? Ano po ba ang benefit nito sa engine?
    Maraming pong salamat!
    Sent from my iPhone using Tsikot Forums[/QUOTE]
    #3858
    Quote Originally Posted by Eddie22 View Post
    [/QUOTE]
    7-9 WHP gain
    1million pogi points
    Dec 2015
    #3859
    pm sent sir, pacheck na lang. thanks
    Good guy's! I am just a newbie here.. Been back reading for quite a time now and I was waiting for my request to be accepted. Thank you! Sir zix888 I want to know the price for EGR blanking material and K&N filter. Kindly pm me sir. Thank you!
    Jan 2013
    #3860
    Guys,
    May idea ba kayo on how much mag pa duplicate ng susi kasama yung alarm remote remote sa casa? meron din kaya nag reprogram ng remote other than casa?
2013 Mitsubishi Montero Sport owners
