Am not sure if this is the proper place to post this but I just want to share my excelent experience with *zix88 today when I brought my monty for pms, egr blanking, and filter install etc. He's the real deal. Thanks Sir Zixx. Sa uulitin.
Ps.
Memorable pa ang araw due to my freak ' accident' that I wouldn' t be forgetting for a while
Ps.
That I will be buying ha ha. Thanks again Sir *Zix888. Btw, I've decided to revise the story- rather than blaming myself and monty's rear door, it's much less shameful to just say "My wife mauled me" due to my monty expenses.
Guys, may nakapagpalit na ba ng battery sa inyo? Ano magandang ipalit? Motolite enduro or Motolite gold? Any idea sa prices?
Anyway, natuyuan yung stock battery ko. Pede kayang itop up ko muna ng wilkins hehe
sino po may alam na egr blanking here in calabarzon? thanks po in advance.
Question lang guys, pag nagpalit ka ba ng battery may irereset ka pa sa head unit para sa consumption meter. It seems mas mababa ang readings ko ng FC compared bago ako magpalit ng battery. Before usual display ko ay more or less 8 km/l pure city, ngayon 6 to 7 km/l. Same route and time yun. I havent tried FT to FT. Di ko pa ubos yung pinakarga ko last week.
I know di naman talaga accurate yung FC meter but gusto ko lang makita yung previous readings ko since less 1 km/l lang ang difference sa FT method. Thanks in advance.
Need your help guys..
Anyone can help me to locate where is the detect light wire (reverse gear signal) for montero stock AVT 6923 HU? TIA.
Back of HU.
Guys may nakapag palit na ba sa inyo ng antenna, naputol na naman yung oem antenna ng monty ko, planning to change to sharkfin atenna, di ko lang alam kung kasya.
guys share ko lang expirience ko kanina sa peak motor edsa. pinunta ko monty ko (gls-v 2013)kanina sa peak motor para papalitan ang shock suspension sa likod at sabi kc ng mekaniko ko may leak na daw then after 5 hrs bumalik ako para kunin na monty ko at ang sabi sakin wala naman daw leak ang sabi ko hindi naman ako magsasayang ng oras kung wala leak then pinakita sakin yung harapang shock suspension para ikumpara then nakita namin na may leak na din pala ang left front shock suspension ko so sabi ko sa mekaniko na papalitan yan then while im waiting for the michanic at the service room the lady said to me na normal lang daw yun nasa first level palang daw ng leak yung shock hintayin ko nlang daw munang may marinig akong tumutunog na galing sa shock then sabi ko kung normal lang yung may leak dapat yung other side may leak din at sabi nalang nya sakin ipapa check pa daw muna nila sa warranty department nila at sa planta...
sa pagkakaalam ko pag under warranty pa sasakyan mo any damage should be replace immediately!
May marecommend kayo na ok na auto supply sa cubao area? For replacement na front and rear break pads on my 2013 gls-v. Thanks!
