Page 79 of 138 FirstFirst ... 296975767778798081828389129 ... LastLast
Results 1,561 to 1,580 of 5877
    Quote Originally Posted by youngrider View Post
    Is the paint of white Mirage, metallic white or pearl while, I noticed that you can see glitters when you look at it closely, it is actually not the plain immaculate white as my SA described. The Specs said it is savanna white but the predelivery specs of Mirage is unreliable, like the absence of remote trunk opener and keyhole barrel light. The underside is also practically littered with plastic coverings, large gaps and openings where dirts and water can easily enter or they may break if hit with stones as you pass graveled roads.
    Afraik the absence of remote trunk opener is normal for hatch back kasi sa hb nakarelay na sa power door lock the hatch door is consider 5th door kaya ipapa power door lock mo iyan at ing key hole barel light wala talaga iyon even thailand and japan version because the higher variant push button start na iyon may iluminated na pero since low end variant ingnition key traditional with out lamp iluminated.
    Jan 2010
    with 727 on the odometer the mirage wont start anymore
    Omg. What happen?? M/t ba or A/t sir?? Of A/t check if nakalagay sa P or N yung stick. Ako din kasi nabiktima sa previous A/t na ginagit ko.
    Dec 2012
    Unti-unti nang naglalabasan ang mga defects ng Mirage. Masamang senyales. Sana walang mga ganito ang makukuha kong unit. (Fingers crossed)
    Dec 2012
    Quote Originally Posted by blitzboy420 View Post
    Same here.. anu kaya nangyari?? however the posts here are very useful.. pag ka dating ng unit, check agad ung back seat..hehe
    Aug 2012
    Ba't mo naman sinisisi tita mo sa di pag-start ng auto mo. :-* At ba't mo naman naisip na sasakay siya sa kotse mo para lang takutin ka. =B)
    Ecclesiastes 9:5, 6
    For the living are conscious that they will die; but as for the dead, they are conscious of nothing at all, neither do they anymore have wages, because the remembrance of them has been forgotten. Also, their love and their hate and their jealousy have already perished, and they have no portion anymore to time indefinite in anything that has to be done under the sun.
    OK, para di OT, kung may problema unit mo at intermittent, sigurado babalik 'yan.
    Sent from my GT-N7000 using Tapatalk 2
    Dec 2009
    ^for the record im not blaming her, lighten up dude
    im still observing the car & will share whatever findings i get capish
    Jan 2011
    mirage owner kumusta po FC nyo? sa city at highway?
    Apr 2012
    Ano ba talaga principle ng START STOP sa Mirage natin?
    As per what i understand START STOP should be like this right:
    The new Volkswagen Jetta Stop/Start system - YouTube
    Ang lumalabas PUSH to START/STOP lang naman si MIRAGE.
    Can anyone clarify??? Bka meron lang ako na miss?
    Quote Originally Posted by nrthstr View Post
    what i saw on the clip parang same lang din kay mirage. Need to press the brake pedal pa din kung mag stop. Then kung ayaw mong mangawit paa mo kaka diin dun sa brake pedal need mo i shift yung stick to N or yung hand brake then release the brake pedal naka full stop kana nun. Yung start/stop button kasi pang start at pang off ng engine yun.. Can't imagine lang kapag naka red light then press mo yung start/stop button..
    Push button ignition on/off lang yong Mirage natin. Only for the sole purpose of not inserting the key into a keyhole then turning it clockwise to start the engine and turning it counterclockwise to turn off the engine. That's all. Convenience lang because no need to get the key out of your pocket or bag. Same is true for locking and unlocking the doors - no need to insert the key in the keyhole.
    We do not have the engine start/top system for fuel economy wherein the engine completely amd AUTOMATICALLY turns off (as in zero RPM) when at full stop (red traffic lights, talking to an MMDA officer, buying cigerette, etc.) then the engine turns back on AUTOMATICALLY when you remove your foot from the brake pedal.
    Apr 2012
    Quote Originally Posted by happymeal View Post
    As what i assumed din pla, anyways happy naman ako sa unit, misinterpreted the advertisement akala ko AUTO START/STOP engine ni Mirage kya fuel efficient.
    Dec 2009
    Quote Originally Posted by timrev View Post
    driving conservatively at below 60kph on the city & below 80kph on the hiway
    12km/li on a moderate to heavy traffic condition
    18km/li on a light to moderate traffic condition
    if fuel cost is that important to you, then you can look at it at (fuel cost/distance traveled) of (P2900/698km) = P4/km
    Nov 2012
    I agree w/ kissmet.... If FC ang batayan, tama lang
    Na maghahanap ng fuel efficient vehicle para ma
    Satisfy ang "cost". In short.... Investment with roi.
    Sa akin... Sa old vehicle ko, i spend 2,600 for my
    Fuel for a week...
    Acquiring mirage, 1,300 na lang....
    Of course, di pa kasali other incidentals... which is,
    another story... and point of argument
    Just my one-cent worth experience... Sa iba
    di Ko masasaklawan...
    - - - Updated - - -
    Fuel for a week...
    Aug 2012
    Dude, I'm as light as helium. Tu capisci?
    Back on topic. For those asking about functionalities of the Mirage, have you investigated whether these are features that can be programmed using an OBD2 cable?
    Nov 2012
    Quote Originally Posted by LaFleur View Post
    Hi, question, if ever makakita ako sa ibang dealer ng preferred color ko, pwede pa ba magpalit ng dealer kahit naka settle na yung downpayment sa bank (bank PO)? puro white daw kasi dumarating sa dealership ko, medyo natatagalan na ako. I was able to reserved and got the pre-order reservation, btw. TIA
    Actually sir nagpareserve din ako sa iba kaso wala yung top colors na gusto ko.(almost month and weeks na)
    At nakuha na ng dealer na yun ang PO from bank eh kaso sobrang tagal na at tinanung ko banko what if Palit ako dealer ok lang daw ayun edi nagpalit nako. Just inform your current dealer naipapacancel mo na (at ask mo refund mo sir kung nakapaglabas kana pera for reservation) at bago ka lumipat yung assurance mo sa new dealer na kaya nila ibigay ang unit asap (or as good as days yung hindi another pila) and color na gusto mo..
    Tapos irerefund mo yung cash na pinareserve mo (3weeks bago makuha til now sakin wala pa pero nasa 1week palang naman). And there will be another PO to that new dealer.
    Sana di nakakalito mga sinabe ko haha.. Antok na kasi.
    Thanks
    Aug 2012
    Quote Originally Posted by Babnoy View Post
    104k all in DP tapos 10.8k for 5 years quote sa akin ng mitsu marcos hiway for GLX A/T mirage.
    Good deal na ba ito mga sir? Thanks
    Sa bangko ka kumuha ng loan, 'wag in-house dahil taga ang interest rate d'yan.
    Dec 2012
    Quote Originally Posted by Pipefish View Post
    Medyo bilisan mu lng.. this is the best time para kumuha at mag pa approve ng bank auto loan.. marami naghahabol ng quota until end of year kaya mas mabilis at madali mag pa approve, make sure na you have the requirements, ITR, payslip, cert of employment. At the most one to two days approval lng yan.
    Also, sa bank, mag ready ka ng addiitonal Php 18-20K para sa CMS (Mortgage), fee for the insurance/ comprehensive, registration (LTO).
    Am not sure kun sa ALL in package ng mga dealer eh pwede through bank financing, typically inhouse lng yan.
    Good luck
    Aug 2012
    Quote Originally Posted by ChiquitoMeister View Post
    Good luck
    Drawing lang 'yang all in-all in. Pag approved na bank loan mo at may pang-down ka na, ibibigay din sa'yo 'yung freebies na sa simula ay pang-in house lang daw. Basta marunong ka makipagusap.
    Aug 2012
    Case in point: Nakuha ko 'yung free MacBook Air (ASX promo), 3-year LTO registration at free insurance (c/o bank) na sa una ay pang-in-house financing lang daw. Nadagdagan pa ng free sunvisor at na-upgrade pa 'yung tint to 3M. Mag-inquire ka sa ibang dealers para makumpara mo.
    Ang dami na galit sa MMPC. Based on what mitsu have posted on their fb page eh mukang next year na nga talaga maccater ung ibang nag pre-order reservation
2013 Mitsubishi Mirage
