Results 3,691 to 3,700 of 5870
- Dec 2012
- 13
December 18th, 2012 01:22 AM #3691you better ask your contact from the bank - pumapayag nman sila and you just only have to coordinate it to the new dealer. I know you have to be definite first na un na ung dealer na pupuntahan mu. When banks process your loan/ application (whether its approved or not), naka dikit palagi ang dealer name dun. Most of the time, may mga specific contacts ang dealer sa bank that when you inquire sa bank na lilipat ka dealer, ini-inform nila ung dealer of your plans and the dealer will try to win you back.
Remember that you are the buyer and you have absolute power over the dealer and the bank. Kikita at kikita pa rin nman ang bangko kahit lumipat ka ng dealer.
Also, may mga dealer/SA na nagbibigay ng mas mababang down, it can even out dun sa initial reservation na ginawa mu. It just depends on your "negotiation skills".
- Jan 2008
- 380
December 18th, 2012 07:01 AM #3692Is the paint of white Mirage, metallic white or pearl while, I noticed that you can see glitters when you look at it closely, it is actually not the plain immaculate white as my SA described. The Specs said it is savanna white but the predelivery specs of Mirage is unreliable, like the absence of remote trunk opener and keyhole barrel light. The underside is also practically littered with plastic coverings, large gaps and openings where dirts and water can easily enter or they may break if hit with stones as you pass graveled roads.
- Oct 2012
- 49
December 18th, 2012 09:34 AM #3693Afraik the absence of remote trunk opener is normal for hatch back kasi sa hb nakarelay na sa power door lock the hatch door is consider 5th door kaya ipapa power door lock mo iyan at ing key hole barel light wala talaga iyon even thailand and japan version because the higher variant push button start na iyon may iluminated na pero since low end variant ingnition key traditional with out lamp iluminated.
- Nov 2012
- 16
December 18th, 2012 09:42 AM #3694Ung mga owners jan na knuha sa diamond motors ung mirage nila. nabigyan ba kayo ng ORCR ng sasakyan? ung sakin kasi mag 2 weeks na wala pdn hndi ko tuloy madrive sa c-5 at marcos highway bka mahuli ako.
December 18th, 2012 12:50 PM #3696
Ano ba talaga principle ng START STOP sa Mirage natin?
As per what i understand START STOP should be like this right:
The new Volkswagen Jetta Stop/Start system - YouTube
Ang lumalabas PUSH to START/STOP lang naman si MIRAGE.
Can anyone clarify??? Bka meron lang ako na miss?
- Jun 2012
- 105
December 18th, 2012 12:51 PM #3697Guys got my Mirage gls mt yesterday will post pics soon .Tanong ko lang in changing gears ano recommended and sama mga first owners ganun ba tlga medyo malalim ang clutch nanibago ako kasi Avanza and Sportivo other cars namin medyo visibility medyo lumiit pero nung tumagal naging ok na din. Wla pa ako seatcovers and matting sabi to follow nalang. tanong ko san ok mag pa seat cover and sensors and hindi ba mavoid warranty kung magpalagay ?"
- Oct 2012
- 11
December 18th, 2012 01:13 PM #3698From MMPC Facebook Page
We deeply apologize to all our Mirage customers who are still waiting for the delivery of their units reserved under the Pre-Order Exclusive promo. We solicit your patience as we try to fulfill the Pre-Order reservations based on the units that we receive from Thailand, and match them with the required Mirage variant and exterior color.
We ensure you that our dealers are carrying out the deliveries based on the queuing of the Pre-Order reservation list. There may be cases that Mirage units are being delivered ahead to others, for reasons that the intended customer for these units have either cancelled their reservation or changed to another color or variant.
Rest assured that we will honor the Pre-Order Exclusive incentives (P25,000 discount and P15,000 worth of genuine accessories) until we deliver the Mirage unit reserved under the Pre-Order Exclusive. We shall also be extending the raffle draw date for one Mirage GLX manual transmission which is part of the Pre-Order Exclusive promo, until we have served all Pre-Order reservations.
Meantime, our dealers will be calling you from time to time to update you on the status of your reservation.
Thank you for your kind understanding.
- Nov 2012
- 13
December 18th, 2012 02:29 PM #3699To aamd....
Thanks for sharing.... i suppose this is the least we can extend
to mirage buyers/owners so that when those would-be owners
will have to know what to do or expect...
so far, ang nabago ko palang sa unit ko (gls m/t) ay yung busina.
(pot pot kase yung original) .... DIY din ginawa ko... Worth 500
Pesoses lang na bosch na busina ang nabili ko... Ok naman....
Bagay sa unit yung tunog.... Tunog matapang tapang...
- Oct 2012
- 31
December 18th, 2012 04:44 PM #3700what i saw on the clip parang same lang din kay mirage. Need to press the brake pedal pa din kung mag stop. Then kung ayaw mong mangawit paa mo kaka diin dun sa brake pedal need mo i shift yung stick to N or yung hand brake then release the brake pedal naka full stop kana nun. Yung start/stop button kasi pang start at pang off ng engine yun.. Can't imagine lang kapag naka red light then press mo yung start/stop button..
Cabin Air Filtre Carbon activated, interchangeable with 27277-4JA0A/B P190 only. Almost P3k ito...
Nissan Navara NP300
