Page 293 of 294 FirstFirst ... 193243283289290291292293294 LastLast
Results 5,841 to 5,860 of 5877
    Jun 2015
    #5841
    Ok lang bang palitan ang stock brake lights with LED? Ano ang potential issues sa electricals ng car, if any? Hindi ba makakasilaw sa nasa likuran kung stock housing pa rin ang gamit?
    Sent from my 3210 using Tsikot Forums mobile app
    #5842
    puede naman. but you might have to switch wires, as LED bulbs require polarity connections. one electrical contact requires connection to positive wire. it won't work if not connected so.
    one of my plate lights is LED. it's about as bright as its partner filamented bulb.
    but why would you want to replace your filamented bulbs with LEDs?
    i have been using filamented bulbs for my tail lights for ages, and they serve me painlessly, naman.
    Jun 2015
    #5843
    Thanks for the insight. I thought it was as simple as plugging in a replacement.
    My right brake light's busted for the 2nd time (after 3 years naman ang interval) and I've read LEDs last longer. But if there's going to be some change in wiring, then I'll just stick with the halogen ones.
    Jun 2015
    #5844
    May nagpalit na pa ng CVTF dito? How much was it and who can do this properly?
    Sent from my SM-A605G using Tapatalk
    What's your odometer reading? Mine's 25k km and I just checked the dipstick. The fluid still looks clean like fresh engine oil.
    Jun 2011
    #5845
    Forester dati madalas mapundi filament brake bulb.
    Pinalit ng LED na peanut T20 type na LED, plug and play naman. Kung mali ang kabit, i switch lang position ng bulb. Walang wiring ginalaw.
    Kung twist type naman na brake bulb, may natural polarity na ito sa contacts, ground body, at tenga na keys.
    Jan 2008
    #5846
    LEDs are good.. just turn them to correct polarity.. no need to split wires..
    But for brake light application, i suggest you stick with halogen bulbs.. some AT will have an error due to busted brake lights
    Jun 2015
    #5847
    Right. Been reading stuff about the Mirage having weird issues from its push start malfunctioning or CVT not shifting right.
    Come to think of it, tranny has been feeling a bit sluggish lately...
    #5848
    my (non-mitsubishi) park light was causing me problems of repeated busting (twice in a year), and it was difficult to replace her.
    when i went to the store to get a couple of replacement bulbs, the shop person asked if i was interested in the LED version. so i got it, and it hasn't gone busted yet since (3 years already).
    fortunately, the bulb base was designed in such a way that one need only to rotate the bulb 180 degrees, to reverse polarity.
    alas, i do not think the double-filament break light bulb base is designed in a similar, conveniently flip-able way.
    and yes, someone here had earlier mentioned that intelligent cars might have issues with LED replacement break bulbs. the cars might detect them as "busted bulbs".
    also, upgrading the signal light bulbs to LEDs may cause hyperflashing (very fast blinking interval).
    need for load resistors and stuff.
    googling,
    the shown LED break light upgrades were not really brighter than filamented bulbs'.
    Jun 2015
    #5849
    Yes, doc. T10 (park, plate, trunk lights) and peanut bulbs (cabin light) are easily replaceable with LEDs. It's the brake lights that I wasn't sure of hence the noob questions.
    I've decided to stick to halogen bulbs for all exterior lights. Trial and error with fancy LED bulbs is gonna be wasteful if it ends up incompatible.
    Jul 2013
    #5850
    Mitsubishi Announces Discontinuation Of Mirage Sub-Compact | CarGuide
    discontinuation has just been announced for its home market of Japan.
    Mitsubishi Mirage to be discontinued in Indonesia. What’s next for PH?
    But what does that mean for the Mirage in the Philippines? Well, it doesn’t seem likely that Mitsubishi will pull the plug on that model. The Mirage, particularly the G4, is still a volume seller in the country, and it wouldn’t be wise to axe that model from a business perspective. Given the sales and local production, the Mirage and Mirage G4 appear to be safe from being canned in the country.
    Jun 2011
    #5852
    YT fun mag search in Japanese galing Google translate.
    Positive review galing sa JDM version.
    Prefer ko current old look ng PhDM local made version. Sayang lang napag iwanan sa safety.
    https://youtu.be/Umdq3_3KgCw?feature=shared
    Turn on lang CC na auto translate.
    pwede ba mag palit or upgrade from stock to led bulbs ang headlights ng mirage?
    #5854
    the generic answer for all cars is, "yes but",
    i am wary of the increased glare that can blind oncoming motorists, if the reflector is not upgraded and/or re-adjusted as well.
    google for the pros and cons, po. there are many articles there, explaining the hows and whys, and the caveats.
    Jul 2013
    #5855
    I was thinking of doing this last year... did my research and almost went for Orion bulbs....
    Then saw this video and contacted Keon Sondra for my car... Mahal pala sya and I decided it was not worth it.
    Ok naman headlights ko, bulbs are not yet due for a replacement.
    THE GOOD, THE BAD AND THE BEST LED HEADLIGHT SOLD IN PHILIPPINES
    REAL RYAN
    #5856
    tongue in cheek,
    time and again, someone posts here that they find their current stock headlights too dark, and that they wish to upgrade.
    shooting in the dark, my advice is, "remove the front windshield tint. you may not need the upgrade if you do.".
    sometimes, may natatamaan naman.
    Jul 2013
    #5857
    tongue in cheek,
    hahaha. guilty ako dito.
    front windshield is tinted kaya bothered na bothered whenever we have foreign guests visiting.
    my driving glasses (for distance) are also slightly tinted
    Jan 2009
    #5858
    Times are changing. Oftentimes, you'll find yourself competing with other motorists with brighter LED headlights.
    LED is what halogen lamps did to sealed beams.... evolutionary improvement.
    HIDs were like the CFLs of residential lighting... became popular for about a decade or so. They were brighter than the technology they replaced, but they were fragile, contained hazardous chemicals, and operated at high voltage. It wasn't long before LEDs started to replace both these lighting technologies as well.
    Jul 2013
    #5859
    after my research (a year ago)
    if you want better headlights - retrofit
    slightly cheaper option - Keon Sondra
    if you just want white headlights and you don't care about the vehicles in front of you - search Lazada/Shopee
    #5860
    If its projector-type, its just a case of replacing the bulb. If its the reflector-type, just plugging an LED bulb may make the HLs brighter/whiter, but the light instead of being thrown onto the road in front, may just be scattered all around (glare).
    Slightly OT: my officemate is restoring a small body Corolla and it still had the original HL bulbs from 1991. Gave him a set of new old stock Osram Nightbreakers from my previous Lancer project. I was surprised the 90s H4 bulbs looked like spherical incandescent bulbs one would see used in brake or signal lights.
2013 Mitsubishi Mirage
