Page 256 of 294 FirstFirst ... 156206246252253254255256257258259260266 ... LastLast
Results 5,101 to 5,120 of 5877
    Apr 2013
    #5101
    *cesz_24:
    Thanks for the heads up about the Reverse issue. observe ko din yung saken, 1 month mahigit pa lang naman yung auto saken, sana naman wag magkaganyang issue.
    My bad about the central lock issue. Kala ko lahat ng doors ang hindi mo na ma-i-manual lock. Check ko mamaya kung kaya ma-i-manual lock yung hatchback ng saken. sabihin mo sa kanila magtanong sa Winterpine! Dun sa Quezon Ave ako nagpagawa, not sure kung sa lahat ng mitsu CASA e winterpine ang nagkakabit ng accessories. wala silang karekla reklamo. Pagkatanong ko pa lang kung magkano yung pa-install ng Central Lock, sila agad nagsabi na kasama na yung 5th door/hatchback sa central lock. Saang CASA yan? di ko magets bakit di nila kaya gawin yun kung nagawa naman ng iba.
    Dec 2012
    #5102
    *cesz_24,
    yun pagsabit (notchy sound) during shifting sa reverse is normal kasi na experience ko rin yan. You can try shifting to other gears 1-4 first before ka mag shift ng reverse. Do it while clutch is engaged.
    Bout the 5th door hatch lock, mine can be lock manually or centrally. Perhaps hinde pa capable ang installer ng casa mo. Ask them to get help with winterpine para mabigyan sila instruction. I can lock all my doors manually or centrally FYI.
    Apr 2013
    #5103
    *cesz_24:
    just checked my car. Nala-lock ko naman manually yung hatch (using the car key). Since nag-fail yung central lock na ininstall sa unit mo, baka pwede mo ipatanggal na lang yan at refund na lang. or kung ayaw, dapat yan maayos nila.
    Mar 2013
    #5104
    I had the same experience about that grinding sound when shifted to reverse gear (GLX mirage). I brought my car to the casa and had it checked, the clutch cable was adjusted, they told me everything was fine. But the grinding sound continued to be observed intermittently. Since I was not satisfied, I brought the issue to the attention of Mitsubishi Head Office. The representatives from Mitsubishi head office brought with them a mirage manual test unit. I drove test the unit, I observed the same grinding sound on the reverse gear shift. I was told by them, that prior to their coming to the dealership where I bought mine, they tried to put down the transmission of five mitsubishi mirage units, to see if the grinding sound in the reverse gear shift would result to grinding the engine. So, they found zero indication that a grinding is taking place. To sum it up, that grinding sound is normal and it comes with the mirage built, being a subcompact car. By the way, complaint on such gear issue prompted the Mitsu representatives to try putting down the transmission of five mitsu mirage. As of now, I feel assured able to get rid of worry on that gear issue. However, the Mitsu representatives advised me to continue observing my unit. So far it operates normally.
    Jul 2013
    #5105
    Goodmorning to my fellow mirage owners. Pa help naman po sa concern ko. may mga instances kasi na nag fa-fail mag start ung engine ng GLS CVT a/t ko. tapos may deafening sound na sobrang nakakairita, parang umiiyak ung makina. Naka experience na din po ba kayo ng ganito problem? Medyo problema din yung central lock ko, minsan hinde agad sya nag aapply sa lahat ng pinto, paisa isa. Pag nag lock din ako gamit ung remote. isang pindot lang pero 2 - 3 times sya tutunog. Ask ko lang po if anu ang mga pwedeng gawin. sorry 1st time lang kc na mag ka tsikot.
    Apr 2013
    #5106
    sa mga naka GLX manual, ano pong gas pinapakarga nyo sa mga auto nyo? may improvement ba sa mileage nyo? thanks
    Jun 2009
    #5107
    Quote Originally Posted by delacruzjv View Post
    Sir, known issue na ang hard starting sa CVT variant ng Mirage. May kailangang palitan na pyesa..I advise to go directly sa casa.
    For additional info on this issue: http://www.miragepilipinas.com/Threa...ge-won-t-start
    HTH
    Jul 2012
    #5108
    [ame=http://www.youtube.com/watch?v=HNc2LTgFhow]Mitsubishi MIrage 2012/2013 Push Start Problem (SpaceStar) - YouTube[/ame]
    Parang ganyan ang description sa nag post sa youtube.
    Feb 2013
    Feb 2013
    Sep 2012
    #5111
    sir....question...ano po ba fuel consumption ng glx.....casa claims 21km per liter.....were planning palang na kumuha ng unit....thanks in advance...
    Jul 2010
    #5112
    Quote Originally Posted by emo View Post
    bro depende sa driving habit mo kung maintain mo ang speed at rpm (maybe with 1.5 - 2.5) it is achivable BUT on a stop and go baka nasa 14 km/l ka lang. when we drove our mirage to baguio (break-in) i got 18.2 km/l balikan at a speed of 90km/h - 110km/h. lumakas lang consumption ko paakyat kasi kennon
    Jan 2003
    #5113
    I can do 13~14km/li on EDSA rush hour traffic. pero nung sobrang traffic dahil sa ulan at baha, nasa 12 lang.
    Sep 2012
    #5114
    thanks mga sir:-)
    Dec 2009
    #5115
    long distance drive cruising at 80kph max, in a race track where there are no other cars, driven alone, no aircon youll probably hit the 21km per liter mark
    Aug 2012
    #5116
    Reporting on our FC consumption.
    After 11,000++ Kms. our glx m/t yielded a FC of 17.53 km/li.
    Conditions:
    Hiway & city driving
    80-100 km/hr lang pag sa hiway
    aircon on
    2 tao ang malimit sakay
    And as for any problems encountered. Wala pa naman po..
    Jun 2006
    #5117
    *a121
    Manual sya o cvt?
    Mar 2013
    #5118
    Bro, di ba nahirapan umakyat sa Baguio ang Mirage. What gear usually nagamit mo paakyat? I am Planning also kasi to go to Baguio. Thanks/
    Mar 2013
    #5119
    We are five in all (me and my wife; 2 daughters and one lola). kaya kayang akyatin ni Mirage ang Baguio. Comments please. thanks.
    Apr 2013
    #5120
    accurate ba yung FC display sa dashboard? Kahapon kasi byahe ko from Jaen to our place, nag NLEX-SCTEX ako, FC displays 20.8 KM/Liter. GLX Manual.
2013 Mitsubishi Mirage
