Page 583 of 588 FirstFirst ... 483533573579580581582583584585586587 ... LastLast
Results 5,821 to 5,830 of 5877
    Jul 2013
    #5821
    R5 with the Evo X engine did pretty good! And there's a hillclimb car with a 4G63T
    Placed 2nd in NC2/R5 in Rally Hokkaido a few years ago. Sayang walang works support to develop the car further.
    Final results Rally Hokkaido 2?17
    only the "body" is a Mirage
    everything else was replaced
    Dec 2019
    #5822
    It's an Evo X chassis on top of Mirage's body.
    Dec 2019
    #5823
    the conversion is not difficult, pero making it look "clean" will be a challenge
    tapos the Mirage platform is really bad, this car will only be good for drag racing.
    They should use Lancer instead. It will some have clearance issues on the transmission. The V6 engine has more power than the existing engine, although it is heavier.
    #5824
    No it's actually not.
    Check out the suspension orientation. It's completely different from the Evo X which uses conventional upright struts. On the Mirage R5 the shocks are actually angled backwards. It's a completely new bespoke design that has little to do with the Evo X aside from the Engine.
    No Evo X shell here
    I'm sure the Evo X strut tower isn't angled like this
    Even the front struts are angled backwards. From a full on side view this is even more pronounced.
    Dec 2019
    #5825
    No Evo X shell here
    I've just figured, there's no Evo X floorpan and other parts there.. This is more like the GR Yaris and their rally versions. They took a Yaris chassis with some modifications and to adapt AWD.
    Someday if Mitsubishi will response to Toyota's GR Yaris to create the ultimate Mirage...(Mirage Evo?)
    Jun 2011
    #5826
    Ready na para sa unang service ng bagong luma. Iyong brake fluid pang flush sa shop na lang kukunin.
    DIYer dream engine bay. Madaling maabot ang service items. 70s/80s vibe iyong airbox snorkel, parang sa di-karburador.
    Banawe shopping ulit.
    Jun 2015
    #5827
    Quote Originally Posted by bxr monkey View Post
    NS40 yang battery mo? Wala bang issue kung undersized at naka-CVT?
    Jun 2011
    #5828
    Yes tama, N40 battery size. 1 click start naman, no issues sa CVT, alternator malamang nagdadala.
    Xpander 4AT namin naka N40 din from factory, no issue din sa 4AT.
    Jun 2015
    #5829
    NS40 din sana ipapalit ko sa batt ko pero ayaw pumayag nung shop na tinanungan ko.
    Sent from my Nokia 6.1 using Tsikot Forums mobile app
    #5830
    bakit daw kaya?
    in my former cars,
    when it came time to replace the battery, i would replace it with the next smaller size (if one such were available).
    wala namang pagbabago sa battery life at sa starting power.
    and yes, the battery is just to start the engine. once running, the alternator provides the electricity for everything.battery also provides trickle current for the toys when engine isn't running.
2013 Mitsubishi Mirage
