Page 357 of 588 FirstFirst ... 257307347353354355356357358359360361367407457 ... LastLast
Results 3,561 to 3,570 of 5877
    #3561
    mga sirs, question lang po. How sensitive are your brake and gas pedals? With just a slight press by your foot, does the brake engage immediately (for brake pedal) and speed increases (for gas pedal)? In my case, I have to press slightly harder (almost halfway) before I can feel the brakes engaging or speed increasing resulting in a not so smooth stop or acceleration. Kindly confirm or baka may mali lang talaga sa driving style ko (newbie)...
    Jan 2010
    #3562
    Quote Originally Posted by calix0305 View Post
    constant follow up na lang gawin mo bro at alamin mo kung sino yung manager ng branch dun ka magtanong.
    Tumawag ako mismong carworld, after 2 minutes tumawag si SA. Next week daw. Intransient na raw yung mga sasakyan. Nung tinanung ko saan galing if sa planta dito sa pinas walang masagot.. Hayzzz disappointing indeed.
    #3563
    Quote Originally Posted by jinstan View Post
    mataas nga talaga yung clutch yun din comment ng brother ko nakakangawit daw lalo pag traffic haha. Baka pwede yun ipa-align sa casa ewan ko lang kung magkano charge.
    Pwede namang isabay yan sa PMS lalo kung sa province ng pwede mong makita yung car during PMS. Ipadamay mo lang, hindi naman mahirap yun unless nasa pinakaloob yung adjustment.
    Personally pwede no ring I-adjust, trace mo lang yung linya. Karaniwan nasa likod lang halos yun nung apakan ng clutch gawing taas.
    Sep 2008
    #3564
    Quote Originally Posted by Noel Salisipan View Post
    yes sir pwede nilang pihitin yon ng counter clockwise,madali lang syang e trace then after pihit e check nila kung okey na sa timplada.
    Sep 2008
    #3565
    Quote Originally Posted by noob*cars View Post
    sir nasa driving style lang yan konteng tyaga pa magagamay mo rin yan cguro na ninibago lang.
    Dec 2004
    #3566
    Quote Originally Posted by egaieskie03 View Post
    Actually I already did the adjustment you described to my preference. Mas maganda na ang engagement point at mas smooth na shifts ko at di na gaano namamatayan.
    Kaso mataas pa rin yung pedal at its resting position. Eto gusto ko ibaba ng konti. Kapantay lang sana ng brake pedal.
    Sep 2008
    #3567
    Quote Originally Posted by Alpha_One View Post
    sir kailangan mo ng silipin under the steering kasi meron pang knot doon para ma adjust mo ung clutch pedal but not sure kung meron ang mirage nito.
    #3568
    langya kick ako sa facebook, mirage pilipinas keep up the good work
    #3569
    From FB Group Admin
    "Narrowed down to 2 choices, see below. Now apparently, you can't change the group name anymore after it reaches 250 members. This means I'm going to have to remove members manually to go under 250 members and be able to change the name. (Facebook is retarded.) If you find that you've been removed from the group, just ask to be added back - that means you were one of the unlucky people. My apologies! I'll start the purge on Friday."
    #3570
    Quote Originally Posted by Vjers Santiago View Post
    From FB Group Admin
    Dapat naging maingat sya sa pagtanggal ng member don sa facebook kasi ang nangyari yong mismong may unit ng mitsubishi mirage ang natanggal e paano naman yong wala namang unit nagsspy lang ata don sila yong mga lucky people
2013 Mitsubishi Mirage
