Results 3,561 to 3,570 of 5834
- Oct 2012
- 73
December 14th, 2012 09:27 AM #3561mga sirs, question lang po. How sensitive are your brake and gas pedals? With just a slight press by your foot, does the brake engage immediately (for brake pedal) and speed increases (for gas pedal)? In my case, I have to press slightly harder (almost halfway) before I can feel the brakes engaging or speed increasing resulting in a not so smooth stop or acceleration. Kindly confirm or baka may mali lang talaga sa driving style ko (newbie)...
- Jan 2010
- 371
December 14th, 2012 09:32 AM #3562
- Nov 2009
- 1,745
December 14th, 2012 09:45 AM #3563
Pwede namang isabay yan sa PMS lalo kung sa province ng pwede mong makita yung car during PMS. Ipadamay mo lang, hindi naman mahirap yun unless nasa pinakaloob yung adjustment.
Personally pwede no ring I-adjust, trace mo lang yung linya. Karaniwan nasa likod lang halos yun nung apakan ng clutch gawing taas.
- Sep 2008
- 77
December 14th, 2012 01:27 PM #3564
- Sep 2008
- 77
December 14th, 2012 01:33 PM #3565
December 14th, 2012 04:56 PM #3566
Actually I already did the adjustment you described to my preference. Mas maganda na ang engagement point at mas smooth na shifts ko at di na gaano namamatayan.
Kaso mataas pa rin yung pedal at its resting position. Eto gusto ko ibaba ng konti. Kapantay lang sana ng brake pedal.
- Sep 2008
- 77
December 14th, 2012 05:36 PM #3567
- Oct 2012
- 64
December 14th, 2012 05:48 PM #3568langya kick ako sa facebook, mirage pilipinas keep up the good work
December 14th, 2012 06:10 PM #3569
ako nga rin pre... anyare!? pero dummy account ko lng yung na kick nila kaya lurk mode lng muna sa group mwahahaha!
- Oct 2012
- 11
December 14th, 2012 06:14 PM #3570From FB Group Admin
"Narrowed down to 2 choices, see below. Now apparently, you can't change the group name anymore after it reaches 250 members. This means I'm going to have to remove members manually to go under 250 members and be able to change the name. (Facebook is retarded.) If you find that you've been removed from the group, just ask to be added back - that means you were one of the unlucky people. My apologies! I'll start the purge on Friday."
Noise barrage daw against MVIS: VOLUNTEERS Against Crime and Corruption... - CAMPI Clean Air...
[AI] Here's what they'll check during MVIS...
