Results 221 to 230 of 5877
- Apr 2008
- 66
August 21st, 2012 01:08 AM #222The Mirage was pretty spacious when I sat in both the driver and passenger seat. Am 5'10" and around 285, so I am really big. The legroom was really good.
I certainly hope that the price will remain the same since this will surely be a hit. Targeting the TOL manual version with all the cool toys for its price range.
- Jun 2012
- 4,447
August 21st, 2012 02:07 AM #223^ agree. this will be a hit. pumasok kami ng 2 friends ko sa likod, dalawang 5'7 isang 5'9 na medyo mataba, sakto lang. comfortable kami. not too cramped. sana kayanin ng mitsu ang demand at magkaroon ng standard discount para lalong bumaba price
- 54,281
August 21st, 2012 02:11 AM #224
- May 2008
- 242
August 21st, 2012 09:21 AM #225
- May 2008
- 242
August 21st, 2012 09:26 AM #226
August 21st, 2012 09:53 AM #227
August 21st, 2012 09:59 AM #228
2012 Mitsubishi Mirage (codename EL = Entry Level)
Price (as of August 16, 2012 * PIMS 2012)
GLX MT - 498K
GLX CVT - 548K
GLS MT - 588K
GLS CVT - 638K
Specifications based on the brochure handout:
Engine 1.2-litre three-cylinder engine (3A92)
Fuel System ECI-MULTI
Displacement 1193 cc
Bore x Stroke 75 x 90 mm
Compression Ratio 10.5 : 1
Max. Output 78 PS / 6000 RPM
Max Torque 100 N-m / 4000 RPM
Fuel Tank 35 Liters
Fuel KPL 21 kms per liter (*MMC test results usig EU Combined Cycle)
LxWxH 3710x1665x1500
Wheelbase 2450mm
Ground Clearance 160 mm
Turning Radius 4.4 meters
Curb Weight: 820 to 850 kgs
Tranny Gear Ratio 3.545 to 0.804 (5MT) / 4.007 to 0.550 (CVT)
Final Gear Ratio 4.055 (5MT) / 3.757 (CVT)
Tires & Wheels
GLX 14" Steel with Full Wheel Cover and 165/65 R14 Tires
GLS 15" Alloy with 175/55 R15 Tires
Suspension
GLX MacPherson Strut Coil Spring
GLS MacPherson Strut Coil Spring with Stabilizer
Steering
GLX 3-Spoke Urethane
GLS 3-Spoke Leather Wrapped
Aircon
GLX Manual Control
GLS Full Auto with Climate Control
COLORS
Lemonade Yellow Metallic
Pop Green Metallic
Majestic Red
Medium Blue Metallic
Savannah White
Cool SIlver Metallic
Eisen Gray Mica
Pyrenese Black
Standard Items (GLX & GLS)
Front Dual SRS Air Bags
Front 3P ELR Seatbelts with Pre-Tensioner and Adjustable Seatbelt Anchor
Multi-Info Display (trip computer)
INVECS-III CVT or 5-Speed MT
235 Liter Cargo Space
Rear Wiper & Washer
Rear Window Defogger
Roof Mounted Antenna
LED Type 3rd Brake Lamp
Laminated Green WIndshield
Side Impact Beams
Child Proof Lock
Additional Features (GLS only)
ABS + EBD Braking System
Rear Tonneau Cover (hard top)
Keyless Operation System + Engine Start/Stop Button
3rd Rear Seat 3-point ELR Seatbelt
High Grade Fabric Seats
Rear Spoiler
Fog Lamps
Some reviews from the net...
Mileage 4.1L/100km fuel economy using 91 RON fuel
Part of the requirement of a car getting an Eco-Car tag is that its fuel consumption needs to better than 5.0 litres/100 km (or 20 km/l), and the car has to meet Euro 4 emission levels. The Mirage’s 1.2 litre MIVEC engine has a fuel economy of 22 km/litres (or 4.5 l/100 km, if the online converters are right) and emits only 120 g/km of CO2.
Suspension - The suspension is neither feathery nor harsh. The system is a standard MacPherson front and torsion beam rear. What is important is that Mitsubishi has been able to dial back the body roll to make this small car chuckable around the corners without going out of sorts. And it feels stable no matter the kind of corners you throw it into. Tight hairpins, long sweepers and S-bends are executed with high scores !
Drag Co-Eff 0.29
Tranny Invecs III CVT 0r 5MT
GLS - DVD/Satellite, Bluetooth, Leather Steering Wheel
STD - Power windows, climate control, 6 airbags, ABS/ESC, Fog Lights
The Mirage comes with the standard cup holders, glove compartment and door pockets. Seats are wrapped in fabric, there’s the usual air conditioning and four-speaker stereo system.
Rear Seats - The rear seats are surprisingly spacious, with great head and legroom. They can easily accommodate four adults with a fifth possible if the need arises.
Total legroom for the Mirage is slightly more than 1,640 mm, which is more than the Swift, Mazda2 and March; only the Yaris gives more room to stretch !!!
August 21st, 2012 10:38 AM #229
Hey guys have you notice the Mirage display * PIMS, baliktad yung push button for entry na dapat sa driver's side napunta sa passenger side. Baka di pa nila na-aadjust for Philippines left hand drive set up.
here's the picture of Thailand Mirage right hand drive with the small black push button use for locking/unlocking the car located in the driver's side obliviously.
Driver side with black push button
Passenger side with no push button, only key hole entry
Here's the youtube video to see what i mean.
I checked all the pix and vids I got at PIMS baliktad pa nga. Have you notice the same?
Ma-correct kaya ng Mitsu ito before shipping the finished units here in the phils?
August 21st, 2012 10:41 AM #230
A relative of mine in Canada had his Scion FR-S PPF'd and then had it ceramic coated. He says it's...
Ceramic Coating vs PPF (Paint Protection Film)
