[QUOTE=dct;1965944]so pag walang aircon hindi gaganun? lagi kasi open ang aircon e. hehe. actually sir, pinacheck na namin yun shift from N to D. they said it's normal. but i just want to make sure kung kayo rin po bang mga merong monty, ganun din.
1k rpm pero stop po?[/QUOTE
Normal yan sa A/T, yung naririnig mo gearing ng differential na pumipigil sa pagikot ng propeller kasi naka hand brake o naka apak sa brake upon shifting from N to D. Pag naka on aircon mas mataas ang idling RPM kaya mas malakas thug sound. RWD sa hulihan maririnig. FWD sa harapan.
Mga sir, ilan po tire pressure ng montero nyo? Ilan po ba ang pinaka ok na pressure? Thanks in advance
mga sirs...tanong lng po... done checking 1K PMS...does it mean after the checking wla ba kong dapat galawin muna since it is still under casa maintain? panu ung coolant or water sa radiator? ung steering oil? engine oil? brake oil? hindi ko ba muna gagalawin mga un para magdagdag ako since it was check already by casa on its 1Kpms...nasanay kc ako sa lumang itlog ko..normally kc pag luma magdadagdag nalng ng engine oil or brake oil etc etc... first time ko po kc mag ka brand new vehicle, montero pa... thanks in advance mga sirs...
Usually, you dont have to do anything except for occassional top-up on washer's water tank.
Although I still do a visual check on radiator, engine oil and break fluids, i never had a need to top-up.
Nasanay din ako sa dati kong 2nd hand lancer itlog at Kia Shame, na may occassional overheat issues.
I've had 4 brand new cars eversince pero lagi pa rin akong may baon na isang bote ng tubig sa may likod, just in case.
Old habits I guess. Nakaranas kasi akong tumirik sa SLEx half a decade ago, with my Kia Shame.
*dct: I get good fuel consumption with tire pressure of 36psi on all tires.
*sirhcacal: If you maintain the oil in your 1Tkms PMS, replace your mineral oil at your 5Tkms PMS checkup. Some go the synthetic oil route as early as the 1Tkms checkup.
Yes Zix. Sa 1k PM din ako magpapa upgrade.
Btw, the audio control unit malfunctioned again late last night. Apparently, when my wify paired the blutooth of her blackberry, the audio control stopped working. She remembers that it was the same scenario when the audio control failed to function after pairing the blutooth. This time around, i turned-off the blutooth and did a reset (pinning the hole). It did restore the connection of the audio control.
The SA told me that they will check the HU of the monty on the 1k service.
Whew! im glad its my wify's ride or else ill really be annoyed with these hiccups (audio control and annoying sounds from the dash, pillars and panels and delay in acceleration) considering its bnew. It might be petty, but buying a 1.4m car, you should expect nothing but perfection. im glad i didnt have probs with my new FTuner (for now)![]()
Maganda talaga ride at steering response yung recomended tire pressure, front 29 at 31 to 32 sa rear. Problema tama ba guage na gagamitin natin, ibat ibang guage iba iba reading. alin dito tama o mali. Ginawa ko bumili ako sarili kung guage, kung anong reading na nawala tagtag sa front tire plus 2 ang sa hulihan. Kapag di responsive kung kabigin manibela sign ng over inflated. Sa umaga lang check ng tire pressure para accurate.
Mga bossing,
My Wife and I are planning to get a GLX Non-VGT AT as soon as we dispose of our 2007 Tucson.
We stay at Mandaluyong On weekdays and go back home to Cavite on Weekends
Anong mitsu dealer near Mandaluyong ang pinaka OK na kunan ng Monty?
Anybody with experience they can share regarding Citimotors Makati?
Mukha kasing convenient sya, at least for PMS.
Puwedeng convoy lang kami ni Misis pag weekend, drop off ang (future) monty for PMS, uwi Cavite via elantra, then pickup ang Monty bago bumalik sa Mandaluyong
mandaluyong, nearest would be diamond greenhills - along edsa fronting in between galleria and megamall. one of the posters here bought his montero there and had it delivered in pangasinan. facilities are new, service is ok as well. its where we brought our montero for 1000km check up. non vgt at.
we got our montero at citimotors makati pero pinaservice namin sa diamond greenhills, though im from marikina and the dealer near to us is diamond marcos hiway
