Sir Poguy panu po i resolve this problem ? Same problem din po sakin. Head Unit goes back to its original problem and can not read the distance giving me errors on all data on the left side screen. Help please... It is so irritating
Just bought a replacement battery, but it still hasn't solved the problem. The remote doesn't work at all. Isasama ko na lang sa list of things na ipapaayos ko sa casa c/o warranty (including tint and body damage caused by casa).
For those na naghahanap ng battery (CR2354), hard to find nga siya. Wala sa hardware, electronics store or national bookstore, but found it sa isang battery kiosk in market market sa tapat ng foodcourt sa 4th floor.
copied from page 105 of old thread originally from pogy_uy:
To reset:
1. off engine
2. long press Negative sign and Up sign at the same time while turning on the key.
3. release upon seeing the mitsu logo on the screen.
4. head unit successfully reset
no need to buy new battery
Sir zix888
Sir do i need to remove the positive and negative terminals of the battery?
If you're in NCR, you can visit na lang yung Autovention Corp, sister company ng Winterpine, sa No. 41 Aurora Blvd. katabi sya ng Central Colleges at across LTO San Juan. It's better that they see your unit para yung mga technicians nila ang mag-ayos or magpalit ng HU mo, if need be. HTH.
[SIZE=2]Problem solved by removing the main battery terminal for five minutes... Hope maka help sa inyo mga sir...Thanks to sir zix888
[/SIZE]
Totoo na problema ang oem wiper ng monti ko kahapon lang nasabak ako sa ulan nakakahiya sa mga kasama ko. I have to find gas station to clean my wipers,at pagkatapos malinisan in few km. away in Nlex bumalik uli problema, papalitan ko na talaga wiper blades. pdwe kay i claim ito? Nasa 4500 km pa lang GTV ko.
What do u remove? the negative terminal? or the positive terminal?
(Resetting the HU only works for the steering remote. I hope this one works for the incorrect datas on the left side screen.). A technician from winterpine changed something from my headunit (i don't know the term but its function is to read the distance travelled). After that, my datas on the left side screen were perfect until 2 weeks after the replacement SAME OLD PROBLEM WENT TO HAUNT ME BACK.
Actually the reason i installed the cr plus is for my 28", ang laki kasi ng additional weight pagmounted to my gtv. It will definitely improve not just the power but also the smoking issue, because it perfects the mixture needed at all rev point. About the pajero oems, same lang ng stock ng gtv, 17"x7.5".
this symbol with the gas pump actually measures the distance remaining until you need to gas up taking into consideration the current average speed and fuel consumption. this data varies from time to time depending figures for the average speed and fuel consumption
all data in the car info always resets to zero at the start of the day (or at least when the car is parked overnight) thus it really only considers your travel for that day
Thanks! but i wasnt referring to that. it was something from the inside of the HU that was replaced. It's function was to read the distance traveled. Before replacing it, the 1000km PMS didnt flash on my screen even if i was beyond the 1000km mark. After replacing, everything went back to normal.
But now, all datas in the left side are inaccurate. and the data on the gas pump just reads ---- all day, everyday, full tank or less.
*zix888: i will try your suggestion sir.
