Page 53 of 251 FirstFirst ... 34349505152535455565763103153 ... LastLast
Results 1,041 to 1,060 of 5006
    #1041
    Share ko lang, i have been using this wiper-ups for 15 years now to all my rides and it has protected my windshield plus wipers since then. Pag hindi ginagamit yung wipers, hindi siya nakasayad sa windshield, hindi nag accumulate ng dirt/alikabok. The rubber of the wipers avoid over heating especially under direct sunlight. Price is reasonable, just p500 per pair.. Although talagang medyo panis yung oem wipers natin, i suggest na palitan ng japan/us made wipers then protect it with wiper-ups
    Apr 2011
    #1042
    Quote Originally Posted by dohcvtec View Post
    [SIZE=2]Problem solved by removing the main battery terminal for five minutes... Hope maka help sa inyo mga sir...Thanks to sir zix888
    [/SIZE]
    The same problem occurred again after a day. The range of the fuel distance has no display again. My god do i need to remove the terminal again?
    Mar 2011
    #1043
    Quote Originally Posted by zix888 View Post
    may space pala talaga yung dugtungan ng black plastic cover ng wiper motor assembly.
    Feb 2007
    #1044
    Quote Originally Posted by gundam View Post
    sir what do you mean? saan po banda yun?...di po ba yung wiper motor nasa may bandang engine bay?
    Jan 2011
    #1045
    my fellow GTV owners, did you experienced this on your MID? it just happen this morning. any idea how to return this to normal?
    Apr 2011
    #1046
    What's that alcapone?
    Jan 2011
    #1047
    i have no tpms readings! how do i fix it?
    Apr 2011
    #1048
    Try to remove the positive battery terminal sir.
    Apr 2011
    #1049
    15 minutes sir
    Apr 2011
    #1050
    Anong brand ng wiper-ups yan and where did you buy it? Thanks!
    Jan 2011
    #1051
    15 minutes sir
    i tried it but its still the same... i even removed the negative terminal...
    Feb 2011
    #1052
    Mga Ka-Monty do you have "kalampag" in your dashboard? It is very irritating considering that the car is new! Mine is a GLS-V model bought only last February of this year.
    I removed everything in the glove compartment and center console, but the "minor-yet irritating clanking" is still there. For those who experienced the same, what solution did you make or what recommendation can you give?
    The sounds seem to come from all over the dashboard. Meron sa may mga gauges, meron sa may MID, at parang meron din sa may aircon controls. Pag daan mo sa unpaved road, dinig na dinig mo at ramdam mo sa steering wheel.
    Another issue is the steering wheel, may sound din na parang "robotic" as described by one of the forumer here. I had it checked already, and the casa told me that they put some grease, but the sound is still there up to now.
    I asked these questions para pag balik ko sa casa, may idea na ako ng mga ipapagawa at hindi lang aasa sa mga technician nila. Time consuming at very inconvenient kasi ang pabalik balik lang sa casa then wala naman sila solutions to the problems. Thanks in advance mga gurus!
    Apr 2011
    #1053
    Quote Originally Posted by md_alcapone View Post
    Sir the best thing we can do is to bring it to winterpine.claim natin warranty
    Sep 2010
    #1054
    Hope 2mrw i still have the readings! i just re calibrated my compass. i don't want to reset, recalibrate and remove terminals routinely!
    I have already complain this to my Service Advisor. I hope you guys have complained about this as well.... But damn! No quick solutions have been given, thanks to this forum theres a band aid fix!
    Sep 2010
    #1055
    Quote Originally Posted by monterick View Post
    I just opt to listen to the radio, that way i can't hear that robotic/servo sound coming from my steering wheel. Hahay! daming issues!
    Jul 2004
    #1056
    Quote Originally Posted by pogy_uy View Post
    regarding the MIS, when it gave me problems, i just went to winterpine, who pointed me to autovention at 41 aurora blvd, where i claimed my warranty. they put in a new touch screen and its been problem free every since
    re the steering wheel robotic sound, i have not experienced this but thanks for the heads up. i will monitor. if ever this comes out, then i will claim warranty again
    on the rattle, there is some rattle but mine seems to come from the door sills. or perhaps i am wrong. its not irritating me though since the rattle of the diesel engine tends to overcome it. will have the casa check this on the 5K PMS unless it gets too irritating for me, hehehehe
    for me, the advantage of getting a new vehicle is its warranty coverage and i intend to make the most of it while i am still covered
    Jul 2004
    #1057
    i would be very mad if this happened to me. this is actually one of the features that i love about the MIS
    have you tried a manual reset of the MIS. try pressing with the tip of the pen a small button located at the left hand side of the unit. as per the manual, this is the quick fix if there is anything wrong with the MIS
    if doing a reset still does not solve it, then best to bring it in for warranty check. this is what i did after successive resets did not solve my problem with my touch screen
    could be the wiring or the sensors of the wheels. best to be sure rather than a DIY. in my case, when i had my rear cameras installed by the casa, the MIS readings went haywire when i left the case. thinking it was a fluke, i let it stand for two days and did some resets.
    when the problem was not solved, i immediately went back to the casa. they checked it and the wirings to the ECU were just loose. now it is working fine
    buti nalang i got my rear view cams from the casa so they had no choice but to acknowledge that it was their fault in not returning the MIS wires properly after installing the rear view cam
    again, my advise for brand new cars is to claim the warranty. if despite this it is still not fixed, then you can escalate this and with the proper demand letter, perhaps a new vehicle or money back? hehehehe :naughty2:
    of course, driver's error excepted. theft also excepted like in my case where my headlamp washer was stolen so i had to pay for the brand new replacement part and most likely pay for installing this also, grrrrr
    #1058
    Quote Originally Posted by bjreyesmd View Post
    Concorde ko nabili, cant remember the brand, but this is the simplest one
    Apr 2011
    #1059
    I also hear some faint rattling coming from the dash whenever the road gets uneven, not irritating enough though....also some sound on my door sills when the road gets bumpy. With regards to the steering wheel, I don't hear any robotic sound.....but thanks for the heads up
    Apr 2011
    #1060
    111prez, isn't it a coincidence that a member of MSCP also had his headlight washer stolen on his GTV? Or are you one and the same? hehehe
2011 Mitsubishi Montero Sport [continued]
