Page 221 of 251 FirstFirst ... 121171211217218219220221222223224225231 ... LastLast
Results 4,401 to 4,420 of 5006
    Jun 2012
    #4401
    Quote Originally Posted by mike879 View Post
    ganon ba yun. i didnt know that... hm ok. so dapat yellow ang ipalit ko?
    Sent from my SM-N9005 using Tsikot Forums mobile app
    Try mo mag basa dito boss. http://tsikot.com/forums/car-lights-lamps-talk-155/
    Please dont install those plug n play, makakasilaw ka sa mga kasalubong at nasa harap mo na pwedeng mag cause ng accidents.
    just my 2 cents.
    Jan 2010
    #4402
    Quote Originally Posted by garyg2014 View Post
    Mga sir nagpapalit po ako ng coolant sa mechanic namin, ang dinrain lang niya ay iyong sa radiator. Halos 2 liters lang ang napalitan. Kailangan rin po bang madrain iyong nasa engine? Kasi sabi sa manual halos 8.2 liters ang coolant ng Monterosport GLS-V.
    * sir garyg2014, i am also planning to do a DIY of my engine coolant change... ang diskarte ko is to drain the coolant from the radiator, which is mga 2 liters nga lang because the other old coolant will be left inside the engine cooling system and lines... then fill the radiator with distilled water, start the engine to flush it with with distilled water and drain it again,,, i will do this cycle for at least 4 times siguro until clear na yung water na na-drain sa radiator to make sure na fully diluted na yung old coolant.... then saka ko na ibuhos sa radiator yung concentrated coolant na at least 3 liters para humalo sa distilled water, mga 36% po siguro ang final coolant concentration... clean na rin yung reservoir tank and fill to the correct coolant level....
    Feb 2007
    #4403
    Here's what the manual says how:
    Sent from my iPad using Tsikot Car Forums
    Jan 2014
    #4404
    Quote Originally Posted by kutangbato View Post
    this is what carland is offering me at 2.8k and at tsikot for only 2.5k. sobra liwanag nga kahit gabi nyan.
    goodam po..san banda pwede pakabit? fairview area kasi ako.. thankss
    Mar 2012
    #4405
    Very informative naman nito boss.:happy
    Jan 2010
    #4406
    thank you sir prince for sharing, nakita ko rin ito sa workshop manual ng montero, but i opted to do the old school of engine coolant draining and flushing, medyo matagal nga lang proseso, parang mahirap kasi ma-access yung engine oil cooler water feed hose, and baka di ko maibalik ng maayos ay magkaroon pa ng leak.... I doubt kasi kung sa casa ay ganito rin ang practice nila kapag nagpapalit sila ng coolant... di rin ako sigurado kung distilled water ang gamit nila pang dilute ng concentrated coolant....
    May 2011
    #4407
    Heads-up guys! GPS map update 2.6 is now available for download.
    Sent from my iPad using Tsikot Forums
    #4408
    Quote Originally Posted by jayteecie View Post
    Thanks jayteecie.....could you help me on how to update the GPS map. 2013 GLS V ang MS ko.
    May 2011
    #4409
    It's pretty straightforward actually. Just backup your old data first, go to http://www.inav.ph/genuine_OEM.php, download the update for your MS which actually is an executable installer. Just double-click it and it will self-extract then run by itself. Then a command-prompt window will open & just follow the instructions. Wait for it to finish. That's it.
    #4410
    Thanks again jayteecie.
    Jul 2011
    #4411
    Mga sir baka may kilala kayo or alam na nagbbenta ng Lenso RT7 dark gray or black size 20" +20offset. Please pm me.. thanks..
    Sent from my GT-I9505 using Tapatalk
    #4412
    Quote Originally Posted by choppercapt View Post
    FYI....Just got my GPS Map updated to a version 3.0 by a Winterpine techie in Valle Verde.
    May 2009
    #4413
    Guys,
    Any idea of the kind and make of this mags and where it can be sourced out locally?
    Thanks much!
    Rev
    Feb 2014
    #4414
    Mga sir,
    Anyone who knows the PMS Code for 40k KMS? Balak ko kasi sanang out of casa nalang gawin changeoil etc. Thanks sirs! I have a 2011 GLS-V.
    Jul 2012
    #4415
    3280 o 6923 try mo.
    Sent from my GT-I9100 using Tapatalk
    Feb 2014
    #4416
    Quote Originally Posted by mangkas1178 View Post
    3280 o 6923 try mo.
    Sir, thank you. 3280 worked with my unit. 👍
    Mar 2011
    #4417
    magkano po paupdate ng gps? the last time it updated was a year ago ata sa citimotors. tapos everytime i try to navigate, nagcrash siya...
    Posted via Tsikot Mobile App
    Feb 2007
    #4418
    F R E E . . .
    Sent from my Nokia 5110 using Tsikot Forums
    Mar 2011
    #4419
    paano po sya iupgrade? i mean apart from the download sa inav... thanks sa reply.
    Apr 2012
    #4420
    Boss Mike, after downloading and running the update, the program will automatically look for your current inav files. Just follow the instruction and it will be updated na.
2011 Mitsubishi Montero Sport [continued]
