Sir Prince777, where do you bring your keys para magfit in keyfobs? Any shop recommedations?
Sir Ali/Zix, please keep us posted on the CEL issue and its cause para maiwasan nun iba. Thanks.
Sent from my SM-N9005 using Tsikot Forums Mobile App mobile app
GUys, we have a shock absorber that can improve the ride of your montero. to lessen the "tagtag" of your vehicle.
its from the same factory of ironman Australia. send me pm po for inquiries![]()
God bless
09228238823
kung ang cause ng CEL ay yung fuel filter, after mapalitan ay kusa na ring mawawala yung CEL. pero yung DTC or yung dignostic trouble code ay naka-save yan sa computer box (ECU) ng sasakyan mo. kung may OBD2 scanner ka ay pwede mo makita yung fault code at i-erase. dati casa lang at mga specialty shops may mga obd scanners but lately marami na yung mga plug and play (usb/bluetooth/wifi) na mga scanners with corresponding apps so madali na lang mag-trace ng cause ng CEL. HTH
PROBLEM SOLVED guys... removed negative terminal sa battery...clean MAF sensor...while drying up my MAF sensor, i change the fuel filter...then kabit ulit MAF sensor then kabit ang battery then paandar monty...then Boom! wala na CEL... diko pa sana schedule magpalit ng fuel filter and clean MAF sensor..anyway...lucky me....
anong fuel filter ng montero mo sir, yun bang detachable type or yung may filter casing na at filter filament na lang ang pinapalitan? mabuti naman at na-solb agad problema mo. mga consumables gaya ng fuel filter ay kahit wala pa sa schedule kung talagang madumi na ay kailangan na palitan.
Sir Prince777... Di pa. No time e. .hehehe
mga sir baka alam nyo yung dimension ng blanking plate
pati na yung laki ng butas paki send naman. tnx
much better siguro sir tanggalin mo yung metal gasket sa may egr pipe then yun mismo ang gawin mong pattern para eksakto. pero kung kagaya kitang nasa overseas at balak mong gumawa, pwede na yung drawing w/ dimensions kung may makapagbigay dito. umeksakto lang center to center at diameter ng butas saka tama ang lapad at ma-cover buong butas ng egr pipe ok na. saka na tabasin yung excess para di halata may blanking...![]()
. Question lang mga sir bakit ang naalala ko lang nagamit sa akin na plates ay yung 2pcs na 2holed,kelangan ba pati yung 4holed point?thanks
